[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x #97
See <https://build.geoserver.org/job/geoserver-2.15.x/97/display/redirect?page=changes&gt;
Changes:
[Daniele Romagnoli] updating to imageio-ext-1.2.2
[...truncated 1.27 MB...]
  at java.lang.reflect.Method.invoke(Method.java:498)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.426 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.665 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src&gt;
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.135 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.307 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.831 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.299 s]
[INFO] Main Module ........................................ SUCCESS [ 56.178 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.094 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:01 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 28.039 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.509 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.847 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 22.510 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.571 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:09 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:17 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:41 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 20.035 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.115 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 50.331 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:04 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.822 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.638 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.166 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.094 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.459 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 7.690 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.637 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.513 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.072 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:17 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:19 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 8.141 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.533 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.053 s]
[INFO] Printing Module .................................... SUCCESS [ 8.337 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:22 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.202 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.758 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.549 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.749 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.584 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.206 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.203 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.189 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.884 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.268 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.035 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.607 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.020 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.042 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 57.923 s]
[INFO] OGR WPS ............................................ SUCCESS [ 12.139 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.780 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.426 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.619 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.445 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.120 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.618 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 20.292 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.892 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.398 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.028 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.334 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.882 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.352 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.051 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.196 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.080 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.900 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.976 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.056 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.679 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.244 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.047 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.729 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.499 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.596 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.088 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.949 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 32.270 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 9.554 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.718 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.576 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.497 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 29.100 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.156 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.643 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.570 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 21.487 s]
[INFO] GeoFence Server .................................... SUCCESS [ 25.951 s]
[INFO] BUILD FAILURE
[INFO] Total time: 14:05 min (Wall Clock)
[INFO] Finished at: 2019-05-06T10:37:03+00:00
[INFO] Final Memory: 336M/1413M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-2.15.x/98/display/redirect?page=changes&gt;
Changes:
[maurobartolomeoli] GEOS-9137: Add WMS configuration options for densification on
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.676 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.995 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.617 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.051 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.879 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.998 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.329 s]
[INFO] Main Module ........................................ SUCCESS [ 55.122 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.070 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:02 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 28.678 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.168 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.739 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.493 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.694 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:42 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.204 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.154 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 49.265 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.337 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.664 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.245 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.068 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.686 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.932 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.479 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.662 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.068 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:18 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:00 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 8.246 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.565 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.051 s]
[INFO] Printing Module .................................... SUCCESS [ 8.009 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:12 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.413 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.413 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.608 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.763 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.561 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.214 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.250 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.177 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.783 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.270 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.065 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.527 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.958 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.043 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 59.102 s]
[INFO] OGR WPS ............................................ SUCCESS [ 12.113 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.532 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.440 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.928 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.426 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.953 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.762 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 21.269 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.820 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.638 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.089 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.482 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.224 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.732 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.055 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.327 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.143 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 26.478 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.721 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.028 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.531 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.226 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.035 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.275 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.472 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.486 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.099 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.458 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 32.744 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 9.483 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.688 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.469 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.820 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 28.297 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.524 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.372 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.318 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.940 s]
[INFO] GeoFence Server .................................... SUCCESS [ 25.885 s]
[INFO] Total time: 13:39 min (Wall Clock)
[INFO] Finished at: 2019-05-06T12:23:15+00:00
[INFO] Final Memory: 321M/1484M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Not sending mail to unregistered user maurobartolomeoli@anonymised.com
Seems like the GWC build is failing (due to an OfflineS3BlobStoreIntegrationTest failure) so it is not deploying the latest pom containing a new imageio-ext version.
The gs-gwc is failing for a missing method of an imageio-ext library so it looks like it is still using the old dependency.
A new GWC build has been triggered and I’m monitoring that to see if things get back to normal.
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
See <https://build.geoserver.org/job/geoserver-2.15.x/99/display/redirect&gt;
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/src/test/java/org/geoserver/importer/web/ImportTaskTableTest.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/surefire-reports&gt;
T E S T S
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.693 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.859 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.939 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Processed 33 files (0 non-complying).
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.959 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.901 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.179 s]
[INFO] Main Module ........................................ SUCCESS [ 54.104 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.079 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:04 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 28.856 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.399 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.866 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.515 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.938 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.992 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.260 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 49.502 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:03 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.311 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.647 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.328 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.100 s]
[INFO] Core UI Module ..................................... SUCCESS [01:01 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.825 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.913 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.511 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.417 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:01 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.829 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.457 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 8.096 s]
[INFO] Community Space .................................... SUCCESS [ 0.034 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.393 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.486 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.459 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.756 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.570 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.278 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.430 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.754 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.277 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.064 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.555 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.881 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.054 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.087 s]
[INFO] OGR WPS ............................................ SUCCESS [ 12.372 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.531 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.455 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.726 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.427 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.187 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.023 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 20.739 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.717 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.583 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.049 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.048 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.153 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.359 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.039 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.405 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.050 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.995 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.222 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 26.121 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.100 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.024 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.446 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.197 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.287 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.357 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.465 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.085 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.564 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 32.302 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.503 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.599 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.400 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.641 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 29.411 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.551 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.304 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.387 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.932 s]
[INFO] GeoFence Server .................................... SUCCESS [ 25.995 s]
[INFO] Total time: 13:38 min (Wall Clock)
[INFO] Finished at: 2019-05-06T15:18:28+00:00
[INFO] Final Memory: 354M/1493M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
