[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-nightly #219
See <https://build.geoserver.org/job/geoserver-2.15.x-nightly/219/display/redirect?page=changes&gt;
Changes:
[daniele.romagnoli] Follow up on scale/offset imageio-ext and gt support
[...truncated 321.81 KB...]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-core ---
[INFO] Copying 18 resources
[INFO] Copying 337 resources
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (process-resources) @ gs-web-core ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[INFO] Executed tasks
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-core ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 274 source files to <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/target/classes&gt;
[WARNING] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/admin/StatusPanel.java&gt;:\[270,46\] sun.java2d.pipe.RenderingEngine is internal proprietary API and may be removed in a future release
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/ReorderableTablePanel.java&gt;: Some input files use or override a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/ReorderableTablePanel.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/GeoServerTablePanel.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/GeoServerTablePanel.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-core ---
[INFO] Copying 12 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-core ---
[INFO] Compiling 87 source files to <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/GeoServerAboutPageTest.java&gt;: Some input files use or override a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/GeoServerAboutPageTest.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/data/layer/LayerPageTest.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/data/layer/LayerPageTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/data/resource/ResourceConfigurationPageTest.java&gt;:\[12,1\] cannot find symbol
  symbol: static RESCALE_PIXELS
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/data/resource/ResourceConfigurationPageTest.java&gt;:\[203,32\] cannot find symbol
  symbol: variable RESCALE_PIXELS
  location: class org.geoserver.web.data.resource.ResourceConfigurationPageTest
[INFO] 2 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.104 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.041 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.558 s]
[INFO] Main Module ........................................ SUCCESS [ 16.756 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.044 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 1.185 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 0.770 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.674 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.374 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.215 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.112 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.429 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 4.179 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.546 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.112 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.598 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 3.892 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 2.149 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 0.574 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 0.422 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 0.547 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.022 s]
[INFO] Core UI Module ..................................... FAILURE [ 3.907 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] GeoWebCache Azure blob ............................. SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer Security Community Modules ............... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SKIPPED
[INFO] GeoServer Keycloak Security Plugin ................. SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] NSG Profiles ....................................... SKIPPED
[INFO] NSG WMTS 1.0 Profile ............................... SKIPPED
[INFO] NSG WFS 2.0 Profile ................................ SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF GHRSST encoder .............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] WFS 3 prototype .................................... SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer Task Manager ............................. SKIPPED
[INFO] GeoServer Task Manager Core ........................ SKIPPED
[INFO] GeoServer Task Manager S3 .......................... SKIPPED
[INFO] GeoServer Quality of Service GetCapabilities module SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] System Status Extension ............................ SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:04 min
[INFO] Finished at: 2019-08-27T01:52:07Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-core: Compilation failure: Compilation failure:
[ERROR] symbol: static RESCALE_PIXELS
[ERROR] location: class
[ERROR] symbol: variable RESCALE_PIXELS
[ERROR] location: class org.geoserver.web.data.resource.ResourceConfigurationPageTest
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
Skipped archiving because build is not successful
See <https://build.geoserver.org/job/geoserver-2.15.x-nightly/220/display/redirect&gt;
[...truncated 321.93 KB...]
[INFO]
main:
[INFO]
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/browser/GeoServerFileChooser.java&gt;: Some input files use or override a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/browser/GeoServerFileChooser.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/GeoServerBasePage.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/main/java/org/geoserver/web/GeoServerBasePage.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO]
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/GeoServerBasePageTest.java&gt;: Some input files use or override a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/GeoServerBasePageTest.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/wicket/CRSPanelTest.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/wicket/CRSPanelTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO] 2 errors
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.605 s]
[INFO] Core Platform Module ............................... SUCCESS [ 4.831 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.480 s]
[INFO] Main Module ........................................ SUCCESS [ 15.879 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.048 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 1.107 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 0.673 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.727 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.472 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.259 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.145 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.482 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.633 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.481 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 0.991 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.606 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 4.168 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 2.066 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 0.507 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 0.410 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 0.502 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.020 s]
[INFO] Core UI Module ..................................... FAILURE [ 3.855 s]
[INFO] Total time: 01:03 min
[INFO] Finished at: 2019-08-28T01:28:31Z
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x-nightly/221/display/redirect&gt;
[...truncated 322.05 KB...]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/wicket/WKTToCRSModelTest.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/wicket/WKTToCRSModelTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO] 2 errors
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.159 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.105 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.683 s]
[INFO] Main Module ........................................ SUCCESS [ 16.027 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.040 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 1.106 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.752 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.510 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.273 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.100 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.416 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 3.717 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 6.029 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.021 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.595 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 4.036 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 1.934 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 0.563 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 0.418 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 0.532 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.024 s]
[INFO] Core UI Module ..................................... FAILURE [ 3.817 s]
[INFO] Finished at: 2019-08-29T02:02:55Z
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x-nightly/222/display/redirect&gt;
[...truncated 321.83 KB...]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/wicket/browser/FileDataViewTest.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/src/web/core/src/test/java/org/geoserver/web/wicket/browser/FileDataViewTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO] 2 errors
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.214 s]
[INFO] Core Platform Module ............................... SUCCESS [ 4.732 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 3.631 s]
[INFO] Main Module ........................................ SUCCESS [ 16.179 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.039 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 1.229 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 0.633 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.643 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.426 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.364 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.088 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.336 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 4.309 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.684 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.089 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.592 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 4.076 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 2.036 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 0.557 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 0.437 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 0.501 s]
[INFO] Core UI Module ..................................... FAILURE [ 3.831 s]
[INFO] Finished at: 2019-08-30T02:22:09Z
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x-nightly/223/display/redirect&gt;
