See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/176/changes>
Changes:
[andrea.aime] [GEOS-6368] CSW regression: record type handling is not namespace aware anymore
[...truncated 14705 lines...]
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-csw/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-csw/10-SNAPSHOT/maven-metadata.xml
316/316 B
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-csw/10-SNAPSHOT/maven-metadata.xml (316 B at 8.3 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-complex/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-complex/10-SNAPSHOT/maven-metadata.xml
312/312 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-complex/10-SNAPSHOT/maven-metadata.xml (312 B at 4.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-app-schema-resolver/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-app-schema-resolver/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-app-schema-resolver/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-app-schema-resolver/10-SNAPSHOT/maven-metadata.xml
324/324 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-app-schema-resolver/10-SNAPSHOT/maven-metadata.xml (324 B at 39.6 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/app-schema/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/app-schema/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/app-schema/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/app-schema/10-SNAPSHOT/maven-metadata.xml
312/312 B
Downloaded: http://repo.opengeo.org/org/geotools/app-schema/10-SNAPSHOT/maven-metadata.xml (312 B at 11.7 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ csw-api ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/api/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ csw-api ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ csw-api ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6368] CSW regression: record type handling is not namespace aware anymore
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 28.02.2014 @ 10:55:54 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 28-Feb-2014 12:13
[INFO] [GitCommitIdMojo] build.build.time = 28.02.2014 @ 12:20:48 UTC
[INFO] [GitCommitIdMojo] build.branch = 7dc1a05294dabf7adfc0e6e49da7020e9ff96da7
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7dc1a05
[INFO] [GitCommitIdMojo] build.commit.id = 7dc1a05294dabf7adfc0e6e49da7020e9ff96da7
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6368] CSW regression: record type handling is not namespace aware anymore
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ csw-api ---
[INFO] Copying 0 resource
[INFO] Copying 90 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ csw-api ---
[INFO] Compiling 28 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/api/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.4:testResources (default-testResources) @ css ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/css/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ css ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/css/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ csw-api ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/api/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ csw-api ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/api/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ css ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/css/target/surefire-reports>
T E S T S
Running org.geoserver.community.css.web.CssDemoTest
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/api/src/test/java/org/geoserver/csw/records/AbstractCatalogStoreTest.java>:\[115,20\] cannot find symbol
symbol : method verifySpatialFilters(org.opengis.filter.Filter)
location: class org.geoserver.csw.records.CSWRecordDescriptor
[INFO] 1 error
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping ogr2ogr Output Format
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping DXF output format
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.178s]
[INFO] Core Platform Module .............................. SUCCESS [4.248s]
[INFO] Open Web Service Module ........................... SUCCESS [16.162s]
[INFO] Main Module ....................................... SUCCESS [2:11.038s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:08.564s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.108s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.497s]
[INFO] Core UI Module .................................... SUCCESS [1:41.304s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [54.974s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:00.934s]
[INFO] REST Support Module ............................... SUCCESS [30.723s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.575s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.325s]
[INFO] Printing Module ................................... SUCCESS [20.958s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.203s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.232s]
[INFO] Application Schema Support ........................ SUCCESS [0.231s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.640s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.419s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.799s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.829s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.601s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.569s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [4.224s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.655s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [4.363s]
[INFO] Chart external graphics support ................... SUCCESS [1.052s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.707s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.101s]
[INFO] OWS request flow controller ....................... SUCCESS [18.246s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.329s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.812s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.516s]
[INFO] Catalog Services for the Web interfaces ........... FAILURE [5.725s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF parent module ................................. SUCCESS [0.339s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 7:23.068s (Wall Clock)
[INFO] Finished at: Fri Feb 28 12:20:57 UTC 2014
[INFO] Final Memory: 46M/201M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project csw-api: Compilation failure
[ERROR] symbol : method verifySpatialFilters(org.opengis.filter.Filter)
[ERROR] location: class org.geoserver.csw.records.CSWRecordDescriptor
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :csw-api
