[Geoserver-devel] Build failed in Jenkins: geoserver-2.4.x #194
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/194/changes&gt;
Changes:
[andrea.aime] [GEOS-5511] Help icons on various GWC pages do nothing (icons removed, they have been confusing users long enough)
[...truncated 41132 lines...]
testSaveNew(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest) Time elapsed: 76 sec <<< ERROR!
org.apache.wicket.WicketRuntimeException: path: 'form:panel' does not exist for page: GeoServerErrorPage
  at org.apache.wicket.util.tester.BaseWicketTester.fail(BaseWicketTester.java:1523)
  at org.apache.wicket.util.tester.BaseWicketTester.getComponentFromLastRenderedPage(BaseWicketTester.java:489)
  at org.apache.wicket.util.tester.BaseWicketTester.isComponent(BaseWicketTester.java:572)
  at org.apache.wicket.util.tester.WicketTester.assertComponent(WicketTester.java:369)
  at org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest.testSaveNew(LayerCacheOptionsTabPanelTest.java:137)
testPageLoad(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest) Time elapsed: 1 sec <<< FAILURE!
java.lang.AssertionError
  at org.junit.Assert.fail(Assert.java:86)
  at org.junit.Assert.assertTrue(Assert.java:41)
  at org.junit.Assert.assertNotNull(Assert.java:621)
  at org.junit.Assert.assertNotNull(Assert.java:631)
  at org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest.setUpInternal(LayerCacheOptionsTabPanelTest.java:47)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
Running org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.686 sec
Running org.geoserver.gwc.web.layer.NewCachedLayerPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.407 sec
Results :
Failed tests: testPageLoad(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest)
Tests in error:
  testSaveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): path: 'form:panel' does not exist for page: GeoServerErrorPage
  testRemoveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): path: 'form:panel' does not exist for page: GeoServerErrorPage
  testSaveNew(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): path: 'form:panel' does not exist for page: GeoServerErrorPage
Tests run: 27, Failures: 1, Errors: 3, Skipped: 0
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.620s]
[INFO] Core Platform Module .............................. SUCCESS [6.807s]
[INFO] Open Web Service Module ........................... SUCCESS [12.942s]
[INFO] Main Module ....................................... SUCCESS [2:09.643s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:10.425s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.541s]
[INFO] Web Map Service Module ............................ SUCCESS [3:33.694s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.843s]
[INFO] Core UI Module .................................... SUCCESS [1:36.486s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.274s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:23.668s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [56.728s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [53.129s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:00.554s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:06.252s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:25.686s]
[INFO] REST Support Module ............................... SUCCESS [32.334s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:21.404s]
[INFO] WMS UI Module ..................................... SUCCESS [51.307s]
[INFO] GWC UI Module ..................................... FAILURE [1:10.124s]
[INFO] WFS UI Module ..................................... SUCCESS [35.816s]
[INFO] Demoes Module ..................................... SUCCESS [55.307s]
[INFO] Security UI Modules ............................... SUCCESS [0.272s]
[INFO] Security UI Core Module ........................... SUCCESS [3:19.499s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.527s]
[INFO] Printing Module ................................... SUCCESS [20.193s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.952s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.324s]
[INFO] Application Schema Support ........................ SUCCESS [0.299s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.578s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [25.193s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.141s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.127s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.811s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.098s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.638s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.692s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.167s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.014s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.822s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [27.944s]
[INFO] Excel Output Format ............................... SUCCESS [35.316s]
[INFO] Validation Module ................................. SUCCESS [3.502s]
[INFO] Chart external graphics support ................... SUCCESS [1.452s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.411s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.922s]
[INFO] OWS request flow controller ....................... SUCCESS [17.203s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.320s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:59.918s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [42.469s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.279s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.303s]
[INFO] Core Monitor Extension ............................ SUCCESS [19.869s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [43.010s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [29.581s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.240s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [19.950s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [13.589s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:22.492s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF parent module ................................. SUCCESS [0.305s]
[INFO] DXF output format ................................. SUCCESS [30.403s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [36.568s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.320s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:03.380s (Wall Clock)
[INFO] Finished at: Wed Mar 19 17:48:17 UTC 2014
[INFO] Final Memory: 58M/223M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project web-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/web/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :web-gwc
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/195/changes&gt;
