[Geoserver-devel] Build failed in Jenkins: geoserver-2.4.x #272
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/272/changes&gt;
Changes:
[jdeolive] Updated repository settings for new boundless maven repo.
[...truncated 13149 lines...]
ERROR: 'Could not find the specified coverage: plop'
13 Aug 17:19:35 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:37)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
  at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:902)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1228)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1163)
  at org.geoserver.wcs.DescribeCoverageTest.testDescribeUnknownCoverageKvp(DescribeCoverageTest.java:72)
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:716)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:313)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
  at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:35)
  ... 55 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
  at org.geoserver.wcs.response.DescribeCoverageTransformer$WCS111DescribeCoverageTranslator.encode(DescribeCoverageTransformer.java:148)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:1026)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:636)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:707)
  ... 60 more
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [13.540s]
[INFO] Core Platform Module .............................. SUCCESS [4.152s]
[INFO] Open Web Service Module ........................... SUCCESS [15.401s]
[INFO] Main Module ....................................... SUCCESS [2:16.384s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:08.366s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.348s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.585s]
[INFO] Core UI Module .................................... SUCCESS [1:36.801s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [53.158s]
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SUCCESS [31.181s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.338s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.962s]
[INFO] Printing Module ................................... FAILURE [2.197s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.276s]
[INFO] Application Schema Support ........................ SUCCESS [0.350s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.396s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.580s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.553s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.559s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.919s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.771s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [3.099s]
[INFO] Chart external graphics support ................... SUCCESS [1.981s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.291s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.150s]
[INFO] OWS request flow controller ....................... SUCCESS [19.658s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.535s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.361s]
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF parent module ................................. SUCCESS [0.491s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:30.765s (Wall Clock)
[INFO] Finished at: Wed Aug 13 17:19:39 UTC 2014
13 Aug 17:19:40 ERROR [geoserver.ows] -
java.io.IOException
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1367)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1131)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1066)
  at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1046)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1316)
  at org.geoserver.wcs.DescribeCoverageTest.testDescribeUnknownCoverageXml(DescribeCoverageTest.java:104)
  ... 55 more
  ... 60 more
[INFO] Final Memory: 43M/217M
[ERROR] Failed to execute goal on project printing: Could not resolve dependencies for project org.geoserver.community:printing:jar:2.4-SNAPSHOT: Could not find artifact org.mapfish.print:print-lib:jar:1.2-20101018133712 in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :printing
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/273/&gt;
