[Geoserver-devel] Build failed in Jenkins: geoserver-2.4.x-nightly #160
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/160/changes&gt;
Changes:
[andrea.aime] [GEOS-6347] csw release packages misses the web-csw jar
[...truncated 7505 lines...]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/dependency/gwc-core-1.5.0.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-rest/2.4-SNAPSHOT/importer-rest-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-rest/2.4-SNAPSHOT/importer-rest-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-rest/2.4-SNAPSHOT/importer-rest-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/rest/target/importer-rest-2.4-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-rest/2.4-SNAPSHOT/importer-rest-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Importer Berkley DB Persistence Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6347] csw release packages misses the web-csw jar
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.02.2014 @ 18:06:08 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Feb-2014 03:17
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2014 @ 03:34:46 UTC
[INFO] [GitCommitIdMojo] build.branch = aa7a1a86e9141512d5ace4b0f5fe7b4a1f92f538
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = aa7a1a8
[INFO] [GitCommitIdMojo] build.commit.id = aa7a1a86e9141512d5ace4b0f5fe7b4a1f92f538
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6347] csw release packages misses the web-csw jar
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/src/test/resources&gt;
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/dependency/gwc-core-1.5.0.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-bdb/2.4-SNAPSHOT/importer-bdb-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-bdb/2.4-SNAPSHOT/importer-bdb-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-bdb/2.4-SNAPSHOT/importer-bdb-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/bdb/target/importer-bdb-2.4-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-bdb/2.4-SNAPSHOT/importer-bdb-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Importer Web UI Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2014 @ 03:34:51 UTC
[INFO] Copying 27 resources
[INFO] Copying 14 resources
[INFO] Compiling 33 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/src/test/resources&gt;
[INFO] No sources to compile
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/importer-web-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/importer-web-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/importer-web-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/dependency/gwc-core-1.5.0.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/importer-web-2.4-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-web/2.4-SNAPSHOT/importer-web-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/importer-web-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-web/2.4-SNAPSHOT/importer-web-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/importer/web/target/importer-web-2.4-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/importer-web/2.4-SNAPSHOT/importer-web-2.4-SNAPSHOT-sources.jar
[INFO] Building GeoServer Release Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/release/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2014 @ 03:34:56 UTC
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/release/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/release/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-vpf:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-vpf:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.csw:gs-web-csw:2.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.csw:gs-web-csw:2.4-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/csw/gs-web-csw/2.4-SNAPSHOT/gs-web-csw-2.4-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.csw:gs-web-csw:pom:2.4-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/csw/gs-web-csw/2.4-SNAPSHOT/gs-web-csw-2.4-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.csw:gs-web-csw:pom:2.4-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/csw/gs-web-csw/2.4-SNAPSHOT/gs-web-csw-2.4-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.csw:gs-web-csw:jar:2.4-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/csw/gs-web-csw/2.4-SNAPSHOT/gs-web-csw-2.4-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.csw:gs-web-csw:jar:2.4-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.csw:gs-web-csw:jar:2.4-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geoserver.csw -DartifactId=gs-web-csw -Dversion=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geoserver.csw -DartifactId=gs-web-csw -Dversion=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:release:jar:2.4-SNAPSHOT
    2) org.geoserver.csw:gs-web-csw:jar:2.4-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 17 minutes 35 seconds
[INFO] Finished at: Wed Feb 19 03:35:14 UTC 2014
[INFO] Final Memory: 139M/295M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-02-19-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/161/changes&gt;
Changes:
[planablediglet] fix broken test and behavior in LayerResource
[planablediglet] handle missing/disabled target store better
[planablediglet] cleanup, error handling, remove broken user tracking
[planablediglet] add attributes to layer representation
[planablediglet] use ValidationException when reading transforms
[planablediglet] allow serial binding to be used via system property
[planablediglet] be more explicit about updatemode, add javadoc
[planablediglet] fix advanceId in memoryimportstore, test coverage
[planablediglet] remove failing postgis tests, need to move
[planablediglet] write out json attribute binding correctly
[planablediglet] check client provided workspace and store exist
[planablediglet] move style computation ahead of other checks
[planablediglet] remove print stmt generating large xml output
[planablediglet] copy resource properties specifically
[maurobartolomeoli] GEOS-6351 fixed context bean id conflicting with css module
[...truncated 7612 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #486 from mbarto/24x_geos_6351
[INFO] [GitCommitIdMojo] build.commit.time = 19.02.2014 @ 08:15:15 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Feb-2014 03:24
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2014 @ 03:34:52 UTC
[INFO] [GitCommitIdMojo] build.branch = 8350c718b902d1b196afcbb820a8482d56f6ef3b
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8350c71
[INFO] [GitCommitIdMojo] build.commit.id = 8350c718b902d1b196afcbb820a8482d56f6ef3b
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #486 from mbarto/24x_geos_6351
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2014 @ 03:34:57 UTC
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2014 @ 03:35:01 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 10 minutes 9 seconds
[INFO] Finished at: Thu Feb 20 03:35:02 UTC 2014
[INFO] Final Memory: 142M/310M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-02-20-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/162/&gt;
[...truncated 7619 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 21-Feb-2014 03:51
[INFO] [GitCommitIdMojo] build.build.time = 21.02.2014 @ 04:00:44 UTC
[INFO] [GitCommitIdMojo] build.build.time = 21.02.2014 @ 04:00:49 UTC
[INFO] [GitCommitIdMojo] build.build.time = 21.02.2014 @ 04:00:54 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 9 minutes 13 seconds
[INFO] Finished at: Fri Feb 21 04:00:55 UTC 2014
[INFO] Final Memory: 144M/332M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-02-21-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/163/&gt;
[...truncated 7577 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 22-Feb-2014 03:46
[INFO] [GitCommitIdMojo] build.build.time = 22.02.2014 @ 03:55:39 UTC
[INFO] [GitCommitIdMojo] build.build.time = 22.02.2014 @ 03:55:45 UTC
[INFO] [GitCommitIdMojo] build.build.time = 22.02.2014 @ 03:55:49 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 9 minutes 2 seconds
[INFO] Finished at: Sat Feb 22 03:55:50 UTC 2014
[INFO] Final Memory: 145M/354M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-02-22-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/164/&gt;
[...truncated 7620 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 23-Feb-2014 03:25
[INFO] [GitCommitIdMojo] build.build.time = 23.02.2014 @ 03:34:01 UTC
[INFO] [GitCommitIdMojo] build.build.time = 23.02.2014 @ 03:34:06 UTC
[INFO] [GitCommitIdMojo] build.build.time = 23.02.2014 @ 03:34:12 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 9 minutes 12 seconds
[INFO] Finished at: Sun Feb 23 03:34:12 UTC 2014
[INFO] Final Memory: 146M/375M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-02-23-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/165/&gt;
[INFO] [GitCommitIdMojo] build.timestamp = 24-Feb-2014 03:25
[INFO] [GitCommitIdMojo] build.build.time = 24.02.2014 @ 03:39:01 UTC
[INFO] [GitCommitIdMojo] build.build.time = 24.02.2014 @ 03:39:06 UTC
[INFO] [GitCommitIdMojo] build.build.time = 24.02.2014 @ 03:39:12 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 13 minutes 24 seconds
[INFO] Finished at: Mon Feb 24 03:39:13 UTC 2014
[INFO] Final Memory: 146M/400M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-02-24-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/166/changes&gt;
