[Geoserver-devel] Build failed in Jenkins: geoserver-2.5.x-nightly #200
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/200/&gt;
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/&gt;
Checkout:geoserver-2.5.x / <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision ea96bbc6e4414ae1ae8db6482e40de7d53ff8f92 (origin/2.5.x)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision ea96bbc6e4414ae1ae8db6482e40de7d53ff8f92 (origin/2.5.x)
Checking out Revision ea96bbc6e4414ae1ae8db6482e40de7d53ff8f92 (origin/2.5.x)
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson1235719572650759267.sh
+ ver=2.5.x
+ dist=/var/www/geoserver/2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-04
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=200 -P release,communityRelease clean install
Exception in thread "main" java.lang.NoClassDefFoundError: org/codehaus/classworlds/Launcher
Caused by: java.lang.ClassNotFoundException: org.codehaus.classworlds.Launcher
  at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
Could not find the main class: org.codehaus.classworlds.Launcher. Program will exit.
+ cp target/release/geoserver-2.5-SNAPSHOT-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-04-bin.zip
+ cp target/release/geoserver-2.5-SNAPSHOT-war.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-latest-war.zip
+ cp target/release/geoserver-2.5-SNAPSHOT-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-latest-bin.zip
+ cd community
+ /opt/apache-maven-2.2.1/bin/mvn assembly:attached
+ [ ! -e /var/www/geoserver/2.5.x/ext-2014-09-04 ]
+ mkdir /var/www/geoserver/2.5.x/ext-2014-09-04
+ [ ! -e /var/www/geoserver/2.5.x/community-2014-09-04 ]
+ mkdir /var/www/geoserver/2.5.x/community-2014-09-04
+ cp target/release/geoserver-2.5-SNAPSHOT-aggregate-plugin.zip target/release/geoserver-2.5-SNAPSHOT-authkey-plugin.zip target/release/geoserver-2.5-SNAPSHOT-colormap-plugin.zip target/release/geoserver-2.5-SNAPSHOT-dds-plugin.zip target/release/geoserver-2.5-SNAPSHOT-ftp-plugin.zip target/release/geoserver-2.5-SNAPSHOT-geopkg-plugin.zip target/release/geoserver-2.5-SNAPSHOT-grib-plugin.zip target/release/geoserver-2.5-SNAPSHOT-groovy-plugin.zip target/release/geoserver-2.5-SNAPSHOT-javascript-plugin.zip target/release/geoserver-2.5-SNAPSHOT-jdbcconfig-plugin.zip target/release/geoserver-2.5-SNAPSHOT-mbtiles-plugin.zip target/release/geoserver-2.5-SNAPSHOT-netcdf-out-plugin.zip target/release/geoserver-2.5-SNAPSHOT-netcdf-plugin.zip target/release/geoserver-2.5-SNAPSHOT-printing-plugin.zip target/release/geoserver-2.5-SNAPSHOT-python-plugin.zip target/release/geoserver-2.5-SNAPSHOT-simpleFeatureService-plugin.zip target/release/geoserver-2.5-SNAPSHOT-spatialite-plugin.zip target/release/geoserver-2.5-SNAPSHOT-wms-eo-plugin.zip /var/www/geoserver/2.5.x/ext-2014-09-04
+ rm -rf /var/www/geoserver/2.5.x/ext-latest
+ mkdir /var/www/geoserver/2.5.x/ext-latest
+ cp target/release/geoserver-2.5-SNAPSHOT-aggregate-plugin.zip target/release/geoserver-2.5-SNAPSHOT-authkey-plugin.zip target/release/geoserver-2.5-SNAPSHOT-colormap-plugin.zip target/release/geoserver-2.5-SNAPSHOT-dds-plugin.zip target/release/geoserver-2.5-SNAPSHOT-ftp-plugin.zip target/release/geoserver-2.5-SNAPSHOT-geopkg-plugin.zip target/release/geoserver-2.5-SNAPSHOT-grib-plugin.zip target/release/geoserver-2.5-SNAPSHOT-groovy-plugin.zip target/release/geoserver-2.5-SNAPSHOT-javascript-plugin.zip target/release/geoserver-2.5-SNAPSHOT-jdbcconfig-plugin.zip target/release/geoserver-2.5-SNAPSHOT-mbtiles-plugin.zip target/release/geoserver-2.5-SNAPSHOT-netcdf-out-plugin.zip target/release/geoserver-2.5-SNAPSHOT-netcdf-plugin.zip target/release/geoserver-2.5-SNAPSHOT-printing-plugin.zip target/release/geoserver-2.5-SNAPSHOT-python-plugin.zip target/release/geoserver-2.5-SNAPSHOT-simpleFeatureService-plugin.zip target/release/geoserver-2.5-SNAPSHOT-spatialite-plugin.zip target/release/geoserver-2.5-SNAPSHOT-wms-eo-plugin.zip /var/www/geoserver/2.5.x/ext-latest
+ cp community/target/release/geoserver-*-plugin.zip /var/www/geoserver/2.5.x/community-2014-09-04
cp: cannot stat `community/target/release/geoserver-*-plugin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/201/changes&gt;
Changes:
[lago.88] [GEOS-6628] NullPointerException when setting empty ParameterFilter
[jody.garnett] (c) 2014 Open Source Geospatial Foundation (GSIP-118)
[jody.garnett] Missed a few (GSIP-118)
Started by timer
Commencing build of Revision 26ebf99bc86bc5312d1cc8f6f8399ac878e88ac4 (origin/2.5.x)
Checking out Revision 26ebf99bc86bc5312d1cc8f6f8399ac878e88ac4 (origin/2.5.x)
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson8943686608511642658.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-05
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=201 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-05-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/202/&gt;
Started by timer
Last Built Revision: Revision 26ebf99bc86bc5312d1cc8f6f8399ac878e88ac4 (origin/2.5.x)
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson77332412421539242.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-06
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=202 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-06-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/203/&gt;
Started by timer
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson5363234086952486585.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-07
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=203 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-07-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/204/&gt;
Started by timer
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson2239405494084871143.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-08
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=204 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-08-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/205/&gt;
Started by timer
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson860055726243615156.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-09
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=205 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-09-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/206/&gt;
Started by timer
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson6040529862706800575.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-10
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=206 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-10-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/207/&gt;
Started by timer
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson7918429903551891826.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-11
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=207 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-11-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/208/&gt;
Started by timer
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson3463585498830443525.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-12
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=208 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-12-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/209/&gt;
Started by timer
[geoserver-2.5.x] $ /bin/sh -xe /tmp/hudson7822783302999231001.sh
+ ver=2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-09-13
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=209 -P release,communityRelease clean install
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-09-13-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/210/&gt;
[...truncated 17740 lines...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-dds ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/dds/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-dds ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/dds/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-dds ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/dds/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wms.worldwind.BilTest
Tests run: 2, Failures: 1, Errors: 1, Skipped: 0, Time elapsed: 17.887 sec <<< FAILURE!
testLargeRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 17420 sec <<< ERROR!
java.io.IOException: Could not load aus_dem.tif from scope class org.geoserver.wms.worldwind.BilTest.
  at org.geoserver.platform.GeoServerResourceLoader.copyFromClassPath(GeoServerResourceLoader.java:598)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:707)
  at org.geoserver.wms.worldwind.BilTest.onSetUp(BilTest.java:47)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:223)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:159)
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:151)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
testStandardRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 262 sec <<< FAILURE!
java.lang.AssertionError: testStandardRequest expected:<9377> but was:<357>
  at org.junit.Assert.fail(Assert.java:88)
  at org.junit.Assert.failNotEquals(Assert.java:743)
  at org.junit.Assert.assertEquals(Assert.java:118)
  at org.junit.Assert.assertEquals(Assert.java:555)
  at org.geoserver.wms.worldwind.BilTest.testStandardRequest(BilTest.java:64)
Running org.geoserver.wms.worldwind.DDSMapProducerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.657 sec
Results :
Failed tests: testStandardRequest(org.geoserver.wms.worldwind.BilTest): testStandardRequest expected:<9377> but was:<357>
Tests in error:
  testLargeRequest(org.geoserver.wms.worldwind.BilTest): Could not load aus_dem.tif from scope class org.geoserver.wms.worldwind.BilTest.
Tests run: 6, Failures: 1, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.005s]
[INFO] Core Platform Module .............................. SUCCESS [5.296s]
[INFO] Open Web Service Module ........................... SUCCESS [12.018s]
[INFO] Main Module ....................................... SUCCESS [2:36.858s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.857s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.158s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [33.386s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.748s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.116s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [42.512s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:16.776s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:39.377s]
[INFO] Web Map Service Module ............................ SUCCESS [2:58.660s]
[INFO] KML support for GeoServer ......................... SUCCESS [48.667s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:49.472s]
[INFO] REST Support Module ............................... SUCCESS [22.651s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:55.573s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.281s]
[INFO] Core UI Module .................................... SUCCESS [1:27.011s]
[INFO] WMS UI Module ..................................... SUCCESS [39.238s]
[INFO] GWC UI Module ..................................... SUCCESS [50.641s]
[INFO] WFS UI Module ..................................... SUCCESS [23.395s]
[INFO] Demoes Module ..................................... SUCCESS [36.157s]
[INFO] WCS UI Module ..................................... SUCCESS [29.079s]
[INFO] Security UI Modules ............................... SUCCESS [0.413s]
[INFO] Security UI Core Module ........................... SUCCESS [2:34.303s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:53.698s]
[INFO] Security UI LDAP Module ........................... SUCCESS [41.103s]
[INFO] GeoServer Web Application ......................... SUCCESS [9.096s]
[INFO] Community Space ................................... SUCCESS [2.070s]
[INFO] Authentication by unique url key .................. SUCCESS [56.566s]
[INFO] WorldWind Format Module ........................... FAILURE [26.378s]
[INFO] Printing Module ................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 28:42.493s
[INFO] Finished at: Sat Sep 13 21:25:16 UTC 2014
[INFO] Final Memory: 57M/165M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-dds: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/dds/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-dds
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/211/&gt;
[...truncated 17456 lines...]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 2, Failures: 1, Errors: 1, Skipped: 0, Time elapsed: 16.987 sec <<< FAILURE!
testLargeRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 16252 sec <<< ERROR!
testStandardRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 501 sec <<< FAILURE!
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.371 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.290s]
[INFO] Core Platform Module .............................. SUCCESS [5.323s]
[INFO] Open Web Service Module ........................... SUCCESS [10.981s]
[INFO] Main Module ....................................... SUCCESS [2:43.417s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.807s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.909s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [32.468s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.689s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.695s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [45.625s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:14.770s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:39.288s]
[INFO] Web Map Service Module ............................ SUCCESS [2:52.763s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.097s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:47.726s]
[INFO] REST Support Module ............................... SUCCESS [22.776s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:52.563s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.219s]
[INFO] Core UI Module .................................... SUCCESS [1:27.270s]
[INFO] WMS UI Module ..................................... SUCCESS [38.731s]
[INFO] GWC UI Module ..................................... SUCCESS [53.343s]
[INFO] WFS UI Module ..................................... SUCCESS [23.765s]
[INFO] Demoes Module ..................................... SUCCESS [36.659s]
[INFO] WCS UI Module ..................................... SUCCESS [28.166s]
[INFO] Security UI Modules ............................... SUCCESS [0.297s]
[INFO] Security UI Core Module ........................... SUCCESS [2:32.047s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:51.873s]
[INFO] Security UI LDAP Module ........................... SUCCESS [42.058s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.684s]
[INFO] Community Space ................................... SUCCESS [0.317s]
[INFO] Authentication by unique url key .................. SUCCESS [31.073s]
[INFO] WorldWind Format Module ........................... FAILURE [25.694s]
[INFO] Total time: 28:09.239s
[INFO] Finished at: Sun Sep 14 15:57:03 UTC 2014
[INFO] Final Memory: 57M/223M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/212/&gt;
[...truncated 17408 lines...]
[INFO]
[INFO]
[INFO]
T E S T S
testLargeRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 17218 sec <<< ERROR!
testStandardRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 462 sec <<< FAILURE!
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.772 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.443s]
[INFO] Core Platform Module .............................. SUCCESS [5.037s]
[INFO] Open Web Service Module ........................... SUCCESS [16.381s]
[INFO] Main Module ....................................... SUCCESS [2:44.531s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.798s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [34.555s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [33.974s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.649s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.892s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [42.366s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:15.202s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:43.806s]
[INFO] Web Map Service Module ............................ SUCCESS [2:57.173s]
[INFO] KML support for GeoServer ......................... SUCCESS [49.633s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:53.186s]
[INFO] REST Support Module ............................... SUCCESS [22.581s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:53.845s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.223s]
[INFO] Core UI Module .................................... SUCCESS [1:23.644s]
[INFO] WMS UI Module ..................................... SUCCESS [40.408s]
[INFO] GWC UI Module ..................................... SUCCESS [51.218s]
[INFO] WFS UI Module ..................................... SUCCESS [22.889s]
[INFO] Demoes Module ..................................... SUCCESS [37.652s]
[INFO] WCS UI Module ..................................... SUCCESS [29.086s]
[INFO] Security UI Modules ............................... SUCCESS [0.290s]
[INFO] Security UI Core Module ........................... SUCCESS [2:34.697s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:51.838s]
[INFO] Security UI LDAP Module ........................... SUCCESS [43.296s]
[INFO] GeoServer Web Application ......................... SUCCESS [8.722s]
[INFO] Community Space ................................... SUCCESS [0.459s]
[INFO] Authentication by unique url key .................. SUCCESS [31.066s]
[INFO] WorldWind Format Module ........................... FAILURE [26.281s]
[INFO] Total time: 28:31.610s
[INFO] Finished at: Mon Sep 15 17:20:49 UTC 2014
[INFO] Final Memory: 57M/222M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/213/&gt;
