See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/16/changes>
Changes:
[gabriel.roldan] Make GWCLifeCycleHandler behave correctly on application shutdown.
[...truncated 21837 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
... 97 more
./target/default4553629238067432138data/temp/wcs/usa_30775574608591486.tif
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.848 sec
Running org.geoserver.catalog.rest.DataStoreFileResourceTest
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.175 sec
Running org.geoserver.gwc.GWCTransactionListenerTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Running org.geoserver.gwc.RESTIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.8 sec
Running org.geoserver.catalog.rest.DataStoreFileUploadTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.098 sec
Running org.geoserver.gwc.ResponseUtilsURLManglerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.gwc.config.GWCConfigPersisterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.gwc.config.GWCConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.417 sec
Running org.geoserver.gwc.config.GWCInitializerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Running org.geoserver.gwc.layer.CatalogConfigurationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.371 sec
Running org.geoserver.gwc.layer.CatalogLayerEventListenerTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.424 sec
Running org.geoserver.gwc.layer.CatalogStyleChangeListenerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.059 sec
Running org.geoserver.gwc.layer.DefaultTileLayerCatalogTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.gwc.layer.GeoServerTileLayerInfoPersistenceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.052 sec
Running org.geoserver.gwc.layer.GeoServerTileLayerTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.827 sec
Running org.geoserver.gwc.layer.LegacyTileLayerInfoLoaderTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.gwc.layer.TileLayerInfoUtilTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.gwc.wms.CachingExtendedCapabilitiesProviderTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.225 sec
Running org.geoserver.catalog.rest.DataStoreTest
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.664 sec
Running org.geoserver.catalog.rest.FeatureTypeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.866 sec
Results :
Failed tests: testCachingHeadersSingleLayer(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
testDirectWMSIntegrationWithVirtualServices(org.geoserver.gwc.GWCIntegrationTest): expected:<cite:BasicPolygons> but was:<null>
testCachingHeadersNestedLayerGroup(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
testDirectWMSIntegrationResponseHeaders(org.geoserver.gwc.GWCIntegrationTest): expected:<cite:BasicPolygons> but was:<null>
testWorkspacedStyle(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
testPngIntegration(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
testDirectWMSIntegrationResponseHeaders13(org.geoserver.gwc.GWCIntegrationTest): expected:<cite:BasicPolygons> but was:<null>
testDirectWMSIntegrationIfModifiedSinceSupport(org.geoserver.gwc.GWCIntegrationTest)
testCachingHeadersFlatLayerGroup(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
testCachingHeadersSingleLayerNoHeaders(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
testDirectWMSIntegrationWithVirtualServicesAndWorkspacedStyle(org.geoserver.gwc.GWCIntegrationTest): expected:<testWorkspace:workspacedLayer> but was:<null>
testGutter(org.geoserver.gwc.GWCIntegrationTest): expected:<[image/png]> but was:<[text/html]>
testDirectWMSIntegrationMaxAge(org.geoserver.gwc.GWCIntegrationTest): expected:<max-age=3456> but was:<null>
Tests run: 155, Failures: 13, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping DXF WPS PPIO
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.215 sec
Running org.geoserver.catalog.rest.FreemarkerTemplateTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.451s]
[INFO] Core Platform Module .............................. SUCCESS [16.321s]
[INFO] Open Web Service Module ........................... SUCCESS [16.965s]
[INFO] Main Module ....................................... SUCCESS [3:16.189s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.865s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.111s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [47.342s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.432s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:05.413s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:22.615s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.902s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:43.867s]
[INFO] Web Map Service Module ............................ SUCCESS [5:22.353s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.900s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [2:40.828s]
[INFO] REST Support Module ............................... SUCCESS [45.201s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.495s]
[INFO] Core UI Module .................................... SUCCESS [2:31.671s]
[INFO] WFS UI Module ..................................... SUCCESS [47.304s]
[INFO] Security UI Modules ............................... SUCCESS [0.178s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.247s]
[INFO] Printing Module ................................... SUCCESS [37.713s]
[INFO] Community Space ................................... SUCCESS [0.235s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.080s]
[INFO] Application Schema Support ........................ SUCCESS [0.257s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.545s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.453s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.156s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.234s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.553s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.382s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.718s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.880s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.431s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.134s]
[INFO] Excel Output Format ............................... SUCCESS [42.519s]
[INFO] Chart external graphics support ................... SUCCESS [2.377s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.850s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.759s]
[INFO] OWS request flow controller ....................... SUCCESS [27.893s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.174s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:31.692s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.963s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.203s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.303s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [1:01.304s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.271s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.960s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.235s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.223s]
[INFO] DXF WFS output format ............................. SUCCESS [41.751s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.304s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:41.156s (Wall Clock)
[INFO] Finished at: Wed Sep 03 19:53:39 UTC 2014
[INFO] Final Memory: 61M/189M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
