[Geoserver-devel] Build failed in Jenkins: geoserver-2.6.x #38
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/38/changes&gt;
Changes:
[andrea.aime] Adding docs for the 'partials' labelling vendor option
[...truncated 11512 lines...]
    service = WCS
    version = 2.0.1
    baseUrl = http://localhost:8080/geoserver/
    coverageId = wcs__BlueMarble
    format = image/tiff
30 Sep 12:03:57 INFO [geoserver.wcs] -
Request: getServiceInfo
Request: getCoverage
    extension:
        contents[0]:
            name = subsettingCrs
            namespace = http://www.opengis.net/wcs/service-extension/crs/1.0
            simpleContent = http://www.opengis.net/def/crs/EPSG/0/3857contents\[0\]:
            name = outputCrs
    service = WCS
    version = 2.0.1
    dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionTrimTypeImpl@anonymised.com (dimension: http://www.opengis.net/def/axis/OGC/0/X, cRS: null) (trimLow: 1.6308305401213994E7, trimHigh: 1.6475284637403902E7)dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionTrimTypeImpl@anonymised.com (dimension: http://www.opengis.net/def/axis/OGC/0/Y, cRS: null) (trimLow: -5543147.203861462, trimHigh: -5311971.846945147)
    dimensionSubset[0]:
        dimension = http://www.opengis.net/def/axis/OGC/0/X
        trimLow = 1.6308305401213994E7
        trimHigh = 1.6475284637403902E7dimensionSubset[0]:
        dimension = http://www.opengis.net/def/axis/OGC/0/Y
        trimLow = -5543147.203861462
        trimHigh = -5311971.846945147
    format = image/tiff
    extension:
        contents[0]:
            simpleContent = http://www.opengis.net/def/crs/EPSG/0/4326contents\[0\]:
            name = outputCrs
    service = WCS
    version = 2.0.1
    dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionTrimTypeImpl@anonymised.com (dimension: http://www.opengis.net/def/axis/OGC/0/Long, cRS: null) (trimLow: 146.5, trimHigh: 147.0)dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionTrimTypeImpl@anonymised.com (dimension: http://www.opengis.net/def/axis/OGC/0/Lat, cRS: null) (trimLow: -43.5, trimHigh: -43.0)
    dimensionSubset[0]:
        dimension = http://www.opengis.net/def/axis/OGC/0/Long
        trimLow = 146.5
        trimHigh = 147.0dimensionSubset[0]:
        dimension = http://www.opengis.net/def/axis/OGC/0/Lat
        trimLow = -43.5
        trimHigh = -43.0
    format = image/tiff
Request: getCapabilities
    service = WCS
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.294s]
[INFO] Core Platform Module .............................. SUCCESS [14.258s]
[INFO] Open Web Service Module ........................... SUCCESS [15.400s]
[INFO] Main Module ....................................... SUCCESS [3:22.959s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.821s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.404s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [50.983s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.710s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.257s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.922s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [4:34.904s]
[INFO] Web Map Service Module ............................ FAILURE [5:13.978s]
[INFO] REST Support Module ............................... SUCCESS [46.500s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.345s]
[INFO] Core UI Module .................................... SUCCESS [2:31.052s]
[INFO] WFS UI Module ..................................... SUCCESS [41.212s]
[INFO] Security UI Modules ............................... SUCCESS [0.246s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.195s]
[INFO] Printing Module ................................... SUCCESS [38.967s]
[INFO] Community Space ................................... SUCCESS [0.338s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.077s]
[INFO] Application Schema Support ........................ SUCCESS [0.169s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.597s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.853s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.641s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.097s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.571s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.470s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.202s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.154s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.524s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.499s]
[INFO] Excel Output Format ............................... SUCCESS [40.691s]
[INFO] Chart external graphics support ................... SUCCESS [1.962s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.303s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.927s]
[INFO] OWS request flow controller ....................... SUCCESS [27.869s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.270s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.341s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.972s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.030s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.303s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.393s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.275s]
[INFO] DXF WFS output format ............................. SUCCESS [40.150s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.187s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:21.981s (Wall Clock)
[INFO] Finished at: Tue Sep 30 12:03:58 UTC 2014
[INFO] Final Memory: 57M/193M
30 Sep 12:03:58 INFO [geoserver.wcs] -
30 Sep 12:03:58 ERROR [geoserver.ows] -
org.geoserver.wcs2_0.exception.WCS20Exception: Error in service name, epected value: WCS
HTTPcode:400
  at org.geoserver.wcs2_0.util.RequestUtils.checkService(RequestUtils.java:364)
  at org.geoserver.wcs2_0.DefaultWebCoverageService20.getCapabilities(DefaultWebCoverageService20.java:74)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at com.sun.proxy.$Proxy36.getCapabilities(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:792)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:274)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1421)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1440)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1375)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:924)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:907)
  at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:892)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1218)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1153)
  at org.geoserver.wcs2_0.kvp.CRSExtentionKVPTest.capabilties(CRSExtentionKVPTest.java:36)
30 Sep 12:03:58 WARN [geoserver.ows] - OWS20SEH: handling org.geoserver.wcs2_0.exception.WCS20Exception: Error in service name, epected value: WCS
HTTPcode:400
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/39/changes&gt;
