See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/25/changes>
Changes:
[jared.erickson] Fix failing RestConfig StyleTest due to file locking issues on Windows
[jared.erickson] OWS FilePublisherTest fails on Windows due to file encoding issues
[...truncated 21307 lines...]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-dds ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/community/dds/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-dds ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/community/dds/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-dds ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/community/dds/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-dds ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/community/dds/target/surefire-reports>
T E S T S
Running org.geoserver.wms.worldwind.BilTest
Tests run: 2, Failures: 1, Errors: 1, Skipped: 0, Time elapsed: 19.253 sec <<< FAILURE!
testLargeRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 18767 sec <<< ERROR!
java.io.IOException: Could not load aus_dem.tif from scope class org.geoserver.wms.worldwind.BilTest.
at org.geoserver.platform.GeoServerResourceLoader.copyFromClassPath(GeoServerResourceLoader.java:541)
at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:709)
at org.geoserver.wms.worldwind.BilTest.onSetUp(BilTest.java:47)
at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:216)
at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:152)
at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:151)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
testStandardRequest(org.geoserver.wms.worldwind.BilTest) Time elapsed: 168 sec <<< FAILURE!
java.lang.AssertionError: testStandardRequest expected:<9377> but was:<357>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:555)
at org.geoserver.wms.worldwind.BilTest.testStandardRequest(BilTest.java:64)
Running org.geoserver.wms.worldwind.DDSMapProducerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.759 sec
Results :
Failed tests: testStandardRequest(org.geoserver.wms.worldwind.BilTest): testStandardRequest expected:<9377> but was:<357>
Tests in error:
testLargeRequest(org.geoserver.wms.worldwind.BilTest): Could not load aus_dem.tif from scope class org.geoserver.wms.worldwind.BilTest.
Tests run: 6, Failures: 1, Errors: 1, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.558s]
[INFO] Core Platform Module .............................. SUCCESS [19.051s]
[INFO] Open Web Service Module ........................... SUCCESS [19.373s]
[INFO] Main Module ....................................... SUCCESS [3:45.625s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.309s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [43.906s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [40.263s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.141s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [54.099s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [56.242s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:31.997s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:35.815s]
[INFO] Web Map Service Module ............................ SUCCESS [3:38.951s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:07.756s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:00.966s]
[INFO] REST Support Module ............................... SUCCESS [32.817s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:23.046s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.149s]
[INFO] Core UI Module .................................... SUCCESS [1:56.906s]
[INFO] WMS UI Module ..................................... SUCCESS [53.304s]
[INFO] GWC UI Module ..................................... SUCCESS [1:07.337s]
[INFO] WFS UI Module ..................................... SUCCESS [30.324s]
[INFO] Demoes Module ..................................... SUCCESS [47.140s]
[INFO] WCS UI Module ..................................... SUCCESS [40.282s]
[INFO] Security UI Modules ............................... SUCCESS [0.215s]
[INFO] Security UI Core Module ........................... SUCCESS [2:52.639s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:55.775s]
[INFO] Security UI LDAP Module ........................... SUCCESS [53.292s]
[INFO] REST UI Module .................................... SUCCESS [33.714s]
[INFO] GeoServer Web Application ......................... SUCCESS [23.703s]
[INFO] Community Space ................................... SUCCESS [0.174s]
[INFO] Authentication by unique url key .................. SUCCESS [1:08.787s]
[INFO] WorldWind Format Module ........................... FAILURE [30.189s]
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 37:06.324s
[INFO] Finished at: Sat Sep 13 20:56:27 UTC 2014
[INFO] Final Memory: 61M/182M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-dds: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/community/dds/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-dds
