See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/280/changes>
Changes:
[andrea.aime] [GEOS-7558] WMSValidator should use attributes() instead of
[...truncated 3297 lines...]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.659 sec
Running org.geoserver.wfs.v2_0.GetFeatureTest
Tests run: 48, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.271 sec
Running org.geoserver.wfs.v2_0.GetFeatureWithLockTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.133 sec
Running org.geoserver.wfs.v2_0.GetPropertyValueTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.424 sec
Running org.geoserver.wfs.v2_0.LockFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.433 sec
Running org.geoserver.wfs.v2_0.SrsNameRequestTest
Tests run: 25, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.104 sec
Running org.geoserver.wfs.v2_0.SrsNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.467 sec
Running org.geoserver.wfs.v2_0.StoredQueryTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.987 sec
Running org.geoserver.wfs.v2_0.TransactionCurveTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.535 sec
Running org.geoserver.wfs.v2_0.TransactionTest
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.472 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.355 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.639 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.54 sec
Running org.geoserver.wfs.xml.WFSURIHandlerTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.015 sec
Running org.geoserver.wfs.xml.v1_1.XMLParsingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Running org.geoserver.wfs.xml.xs.DateBindingTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Results :
Tests run: 590, Failures: 0, Errors: 0, Skipped: 1
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wfs ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wfs ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-wfs >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-wfs ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-wfs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wfs ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-wfs >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-wfs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wfs ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wfs ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.8-SNAPSHOT/gs-wfs-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.8-SNAPSHOT/gs-wfs-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.8-SNAPSHOT/gs-wfs-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.8-SNAPSHOT/gs-wfs-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/gs-wfs-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.8-SNAPSHOT/gs-wfs-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Map Service Module 2.8-SNAPSHOT
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-svg/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-svg/14-SNAPSHOT/maven-metadata.xml
953/953 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-svg/14-SNAPSHOT/maven-metadata.xml (953 B at 7.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-process/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-process/14-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-process/14-SNAPSHOT/maven-metadata.xml (957 B at 12.1 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-process-raster/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-process-raster/14-SNAPSHOT/maven-metadata.xml
964/964 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-process-raster/14-SNAPSHOT/maven-metadata.xml (964 B at 12.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-process-feature/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-process-feature/14-SNAPSHOT/maven-metadata.xml
965/965 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-process-feature/14-SNAPSHOT/maven-metadata.xml (965 B at 14.1 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-grid/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-grid/14-SNAPSHOT/maven-metadata.xml
954/954 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-grid/14-SNAPSHOT/maven-metadata.xml (954 B at 12.1 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-wms ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wms/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wms ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-wms ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wms ---
[INFO] Copying 1 resource
[INFO] Copying 68 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wms ---
[INFO] Compiling 192 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wms/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wms ---
[INFO] Copying 121 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wms ---
[INFO] Compiling 111 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wms/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wms/src/test/java/org/geoserver/wms/WMSValidatorTest.java>:\[37,57\] error: method andReturn in interface IExpectationSetters<T> cannot be applied to given types;
[ERROR]
T extends Object declared in interface IExpectationSetters
<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wms/src/test/java/org/geoserver/wms/WMSValidatorTest.java>:\[42,58\] error: method andReturn in interface IExpectationSetters<T> cannot be applied to given types;
[INFO] 2 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 18.026 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.716 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.090 s]
[INFO] Main Module ........................................ SUCCESS [02:18 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.233 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.365 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [01:12 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.073 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 22.760 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 25.910 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.865 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:30 min]
[INFO] Web Map Service Module ............................. FAILURE [ 15.440 s]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demoes Module ...................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] GeoSearch Index Module ............................. SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:26 min
[INFO] Finished at: 2016-07-09T12:32:07+00:00
[INFO] Final Memory: 105M/317M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wms: Compilation failure: Compilation failure:
[ERROR]
[ERROR] T extends Object declared in interface IExpectationSetters
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/wms/src/test/java/org/geoserver/wms/WMSValidatorTest.java>:\[42,58\] error: method andReturn in interface IExpectationSetters<T> cannot be applied to given types;
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
