[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #47
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/47/changes&gt;
Changes:
[Frank.Gasdorf] fix svn links in developers guide
[afabiani] - fix netcdf-out pom
[...truncated 18035 lines...]
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 28.10.2015 @ 16:54:46 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 28-Oct-2015 17:24
[INFO] [GitCommitIdMojo] build.build.time = 28.10.2015 @ 18:11:38 UTC
[INFO] [GitCommitIdMojo] build.branch = 3d342172de461012647e40166a3f480a55dc2ba7
[INFO] [GitCommitIdMojo] build.commit.user.email = alessio.fabiani@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = afabiani
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3d34217
[INFO] [GitCommitIdMojo] build.commit.id = 3d342172de461012647e40166a3f480a55dc2ba7
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge branch '2.8.x' of https://github.com/geoserver/geoserver into 2.8.x
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf/target/gs-netcdf-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf/target/gs-netcdf-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf/target/gs-netcdf-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf/target/gs-netcdf-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/netcdf/target/gs-netcdf-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building WCS NetCDF output Module 2.8-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.pom
Downloading: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.pom
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.extensions:gs-netcdf:jar:2.8-SNAPSHOT is missing, no dependency information available
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-jts-wrapper/14-SNAPSHOT/maven-metadata.xml
Downloading: https://boundless.artifactoryonline.com/boundless/snapshot/org/geotools/gt-jts-wrapper/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-jts-wrapper/14-SNAPSHOT/maven-metadata.xml
970/970 B
Downloaded: https://boundless.artifactoryonline.com/boundless/snapshot/org/geotools/gt-jts-wrapper/14-SNAPSHOT/maven-metadata.xml (970 B at 3.9 KB/sec)
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-cql/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-coverage/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-data/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-jdbc/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-wfs-ng/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-complex/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-app-schema-resolver/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-wfs/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-fes/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/ogc/net.opengis.wfs/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/ogc/net.opengis.fes/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-metadata/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-opengis/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-property/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-epsg-hsql/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-wms/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-render/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-sld/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-shapefile/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/jdbc/gt-jdbc-postgis/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-arcgrid/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-geotiff/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-gtopo30/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-image/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-referencing/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/ogc/net.opengis.ows/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-ows/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-core/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-graph/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-gml3/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-gml2/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-filter/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/xsd/gt-xsd-wcs/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-xml/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/ogc/org.w3.xlink/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-imagemosaic/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.jar
Downloading: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.jar
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/extensions/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.867s]
[INFO] Core Platform Module .............................. SUCCESS [24.931s]
[INFO] Open Web Service Module ........................... SUCCESS [24.305s]
[INFO] Main Module ....................................... SUCCESS [3:16.912s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.598s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [53.446s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:35.786s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.100s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [36.762s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [46.224s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:11.995s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:05.498s]
[INFO] Web Map Service Module ............................ SUCCESS [2:31.456s]
[INFO] KML support for GeoServer ......................... SUCCESS [49.167s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:31.810s]
[INFO] REST Support Module ............................... SUCCESS [23.446s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:41.542s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.080s]
[INFO] Core UI Module .................................... SUCCESS [1:09.545s]
[INFO] WMS UI Module ..................................... SUCCESS [36.325s]
[INFO] GWC UI Module ..................................... SUCCESS [58.114s]
[INFO] WFS UI Module ..................................... SUCCESS [18.028s]
[INFO] Demoes Module ..................................... SUCCESS [33.829s]
[INFO] WCS UI Module ..................................... SUCCESS [23.645s]
[INFO] Security UI Modules ............................... SUCCESS [0.170s]
[INFO] Security UI Core Module ........................... SUCCESS [1:50.212s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:25.806s]
[INFO] Security UI LDAP Module ........................... SUCCESS [27.653s]
[INFO] REST UI Module .................................... SUCCESS [20.281s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.081s]
[INFO] Printing Module ................................... SUCCESS [22.452s]
[INFO] Community Space ................................... SUCCESS [0.081s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.890s]
[INFO] GeoServer Web Application ......................... SUCCESS [7.950s]
[INFO] Application Schema Support ........................ SUCCESS [0.139s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:41.486s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [21.921s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.725s]
[INFO] GeoSearch Index Module ............................ SUCCESS [21.080s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.551s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.375s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.167s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.376s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.373s]
[INFO] ImageMap Output Format ............................ SUCCESS [17.513s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.507s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.362s]
[INFO] OGR parent ........................................ SUCCESS [0.135s]
[INFO] OGR CORE .......................................... SUCCESS [4.322s]
[INFO] OGR WFS ........................................... SUCCESS [17.277s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.084s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:43.804s]
[INFO] OGR WPS ........................................... SUCCESS [19.403s]
[INFO] Excel Output Format ............................... SUCCESS [25.292s]
[INFO] Chart external graphics support ................... SUCCESS [0.426s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.915s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.326s]
[INFO] OWS request flow controller ....................... SUCCESS [17.900s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [32.286s]
[INFO] Web Processing Service GUI ........................ SUCCESS [47.831s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [31.385s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.394s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.169s]
[INFO] Core Monitor Extension ............................ SUCCESS [23.036s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.074s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.180s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [9.553s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.192s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.280s]
[INFO] XLST based WFS output format ...................... SUCCESS [33.147s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [41.325s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [25.262s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.204s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.400s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [17.613s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:00.022s]
[INFO] CSW UI Module ..................................... SUCCESS [16.026s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.101s]
[INFO] DXF WFS output format ............................. SUCCESS [23.527s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [17.295s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.073s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [31.981s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [20.206s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [14.969s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.203s]
[INFO] Importer Core Module .............................. SUCCESS [1:11.496s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:03.630s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [33.658s]
[INFO] Importer Web UI Module ............................ SUCCESS [5.333s]
[INFO] GRIB Coverage Format .............................. SUCCESS [28.146s]
[INFO] NetCDF Coverage format ............................ SUCCESS [22.792s]
[INFO] WCS NetCDF output Module .......................... FAILURE [6.559s]
[INFO] BUILD FAILURE
[INFO] Total time: 47:42.001s
[INFO] Finished at: Wed Oct 28 18:11:45 UTC 2015
[INFO] Final Memory: 99M/248M
[ERROR] Failed to execute goal on project gs-netcdf-out: Could not resolve dependencies for project org.geoserver.extension:gs-netcdf-out:jar:2.8-SNAPSHOT: Could not find artifact org.geoserver.extensions:gs-netcdf:jar:2.8-SNAPSHOT in unidata (https://artifacts.unidata.ucar.edu/content/repositories/unidata/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/48/&gt;
[...truncated 18253 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 28-Oct-2015 21:19
[INFO] [GitCommitIdMojo] build.build.time = 28.10.2015 @ 22:07:43 UTC
[INFO]
[INFO]
[INFO]
[INFO]
970/970 B
Downloaded: https://boundless.artifactoryonline.com/boundless/snapshot/org/geotools/gt-jts-wrapper/14-SNAPSHOT/maven-metadata.xml (970 B at 4.9 KB/sec)
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.396s]
[INFO] Core Platform Module .............................. SUCCESS [20.782s]
[INFO] Open Web Service Module ........................... SUCCESS [25.947s]
[INFO] Main Module ....................................... SUCCESS [3:17.700s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.509s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [52.841s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:33.918s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.778s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [37.929s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [47.166s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:09.603s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:08.682s]
[INFO] Web Map Service Module ............................ SUCCESS [2:35.812s]
[INFO] KML support for GeoServer ......................... SUCCESS [48.342s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:31.006s]
[INFO] REST Support Module ............................... SUCCESS [24.442s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:39.747s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.084s]
[INFO] Core UI Module .................................... SUCCESS [1:13.472s]
[INFO] WMS UI Module ..................................... SUCCESS [35.650s]
[INFO] GWC UI Module ..................................... SUCCESS [58.386s]
[INFO] WFS UI Module ..................................... SUCCESS [19.244s]
[INFO] Demoes Module ..................................... SUCCESS [32.783s]
[INFO] WCS UI Module ..................................... SUCCESS [24.860s]
[INFO] Security UI Modules ............................... SUCCESS [0.174s]
[INFO] Security UI Core Module ........................... SUCCESS [1:52.483s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:25.702s]
[INFO] Security UI LDAP Module ........................... SUCCESS [28.533s]
[INFO] REST UI Module .................................... SUCCESS [21.262s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.084s]
[INFO] Printing Module ................................... SUCCESS [23.422s]
[INFO] Community Space ................................... SUCCESS [0.097s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.971s]
[INFO] GeoServer Web Application ......................... SUCCESS [11.016s]
[INFO] Application Schema Support ........................ SUCCESS [0.087s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:30.419s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [21.204s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.598s]
[INFO] GeoSearch Index Module ............................ SUCCESS [20.796s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.414s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.816s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.130s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.328s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.390s]
[INFO] ImageMap Output Format ............................ SUCCESS [11.790s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.521s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.555s]
[INFO] OGR parent ........................................ SUCCESS [0.117s]
[INFO] OGR CORE .......................................... SUCCESS [4.664s]
[INFO] OGR WFS ........................................... SUCCESS [15.149s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.123s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:42.168s]
[INFO] OGR WPS ........................................... SUCCESS [16.944s]
[INFO] Excel Output Format ............................... SUCCESS [24.738s]
[INFO] Chart external graphics support ................... SUCCESS [1.274s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.485s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.336s]
[INFO] OWS request flow controller ....................... SUCCESS [17.979s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.185s]
[INFO] Web Processing Service GUI ........................ SUCCESS [51.320s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [28.697s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.851s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.163s]
[INFO] Core Monitor Extension ............................ SUCCESS [23.011s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [12.340s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.167s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [9.416s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.194s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.634s]
[INFO] XLST based WFS output format ...................... SUCCESS [35.293s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [41.632s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [26.107s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.120s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [19.398s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [16.891s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:02.312s]
[INFO] CSW UI Module ..................................... SUCCESS [21.068s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.069s]
[INFO] DXF WFS output format ............................. SUCCESS [23.213s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [18.299s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.121s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [32.851s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [23.911s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [17.622s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.170s]
[INFO] Importer Core Module .............................. SUCCESS [1:15.164s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:04.244s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [35.124s]
[INFO] Importer Web UI Module ............................ SUCCESS [6.030s]
[INFO] GRIB Coverage Format .............................. SUCCESS [29.669s]
[INFO] NetCDF Coverage format ............................ SUCCESS [25.273s]
[INFO] WCS NetCDF output Module .......................... FAILURE [14.833s]
[INFO] Total time: 48:05.297s
[INFO] Finished at: Wed Oct 28 22:07:57 UTC 2015
[INFO] Final Memory: 99M/255M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/49/changes&gt;
Changes:
[tbarsballe] [GEOS-7227] Improve null handling for Import bounds calculation
[...truncated 18133 lines...]
[INFO] [GitCommitIdMojo] build.commit.time = 28.10.2015 @ 23:38:15 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 29-Oct-2015 03:29
[INFO] [GitCommitIdMojo] build.build.time = 29.10.2015 @ 04:23:16 UTC
[INFO] [GitCommitIdMojo] build.branch = 0f9798296de9ba0d1bd236a19e316dee5460aabd
[INFO] [GitCommitIdMojo] build.commit.user.email = tbarsballe@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Torben Barsbsballe
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0f97982
[INFO] [GitCommitIdMojo] build.commit.id = 0f9798296de9ba0d1bd236a19e316dee5460aabd
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7227] Improve null handling for Import bounds calculation
[INFO]
[INFO]
[INFO]
[INFO]
970/970 B
Downloaded: https://boundless.artifactoryonline.com/boundless/snapshot/org/geotools/gt-jts-wrapper/14-SNAPSHOT/maven-metadata.xml (970 B at 3.2 KB/sec)
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.565s]
[INFO] Core Platform Module .............................. SUCCESS [20.120s]
[INFO] Open Web Service Module ........................... SUCCESS [23.067s]
[INFO] Main Module ....................................... SUCCESS [2:37.785s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.420s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [53.145s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:25.802s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.964s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [37.678s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [44.018s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:06.330s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:07.141s]
[INFO] Web Map Service Module ............................ SUCCESS [2:44.109s]
[INFO] KML support for GeoServer ......................... SUCCESS [49.237s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:37.793s]
[INFO] REST Support Module ............................... SUCCESS [53.787s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:49.596s]
[INFO] GeoServer Web Modules ............................. SUCCESS [2.159s]
[INFO] Core UI Module .................................... SUCCESS [1:19.044s]
[INFO] WMS UI Module ..................................... SUCCESS [39.310s]
[INFO] GWC UI Module ..................................... SUCCESS [1:00.372s]
[INFO] WFS UI Module ..................................... SUCCESS [18.728s]
[INFO] Demoes Module ..................................... SUCCESS [37.309s]
[INFO] WCS UI Module ..................................... SUCCESS [24.555s]
[INFO] Security UI Modules ............................... SUCCESS [0.200s]
[INFO] Security UI Core Module ........................... SUCCESS [2:04.401s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:32.458s]
[INFO] Security UI LDAP Module ........................... SUCCESS [28.652s]
[INFO] REST UI Module .................................... SUCCESS [20.269s]
[INFO] GeoServer Extensions .............................. SUCCESS [1.059s]
[INFO] Printing Module ................................... SUCCESS [23.726s]
[INFO] Community Space ................................... SUCCESS [0.163s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.144s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.622s]
[INFO] Application Schema Support ........................ SUCCESS [2.301s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:03.094s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [20.339s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [20.058s]
[INFO] GeoSearch Index Module ............................ SUCCESS [20.889s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.918s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.474s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.153s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.453s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.406s]
[INFO] ImageMap Output Format ............................ SUCCESS [11.604s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.588s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.424s]
[INFO] OGR parent ........................................ SUCCESS [0.123s]
[INFO] OGR CORE .......................................... SUCCESS [3.158s]
[INFO] OGR WFS ........................................... SUCCESS [15.862s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.379s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:59.742s]
[INFO] OGR WPS ........................................... SUCCESS [31.974s]
[INFO] Excel Output Format ............................... SUCCESS [32.700s]
[INFO] Chart external graphics support ................... SUCCESS [9.810s]
[INFO] Feature Generalization Extension .................. SUCCESS [9.662s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.483s]
[INFO] OWS request flow controller ....................... SUCCESS [18.524s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [25.423s]
[INFO] Web Processing Service GUI ........................ SUCCESS [56.024s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [31.368s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.269s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.226s]
[INFO] Core Monitor Extension ............................ SUCCESS [47.524s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [55.596s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.249s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [12.439s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [1.191s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.313s]
[INFO] XLST based WFS output format ...................... SUCCESS [37.993s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [43.355s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [28.924s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [1.972s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [20.617s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [17.576s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:15.511s]
[INFO] CSW UI Module ..................................... SUCCESS [39.034s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.716s]
[INFO] DXF WFS output format ............................. SUCCESS [33.512s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [22.573s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.195s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [35.022s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [31.680s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [30.015s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.350s]
[INFO] Importer Core Module .............................. SUCCESS [1:39.812s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:12.355s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [48.205s]
[INFO] Importer Web UI Module ............................ SUCCESS [7.370s]
[INFO] GRIB Coverage Format .............................. SUCCESS [53.536s]
[INFO] NetCDF Coverage format ............................ SUCCESS [23.272s]
[INFO] WCS NetCDF output Module .......................... FAILURE [6.167s]
[INFO] Total time: 53:55.305s
[INFO] Finished at: Thu Oct 29 04:23:22 UTC 2015
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/50/changes&gt;
