See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$geoserver/212/changes>
Changes:
[ben] Upgrade git-commit-id-plugin to 2.2.0
<===[JENKINS REMOTING CAPACITY]===> channel started
Executing Maven: -B -f <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$geoserver/ws/pom.xml> -Djava.awt.headless=true -Prelease clean install -DconfigDirectory=..\..\..\data -U
[INFO] Scanning for projects...
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-ogr-wps:jar:2.8-SNAPSHOT
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.geoserver.extension:gs-ogr-wfs:jar:tests -> duplicate declaration of version ${gs.version} @ line 51, column 21
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-wps-core:jar:2.8-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-core:${gs.version}, C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\wps\wps-core\pom.xml, line 21, column 14
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-wps-cluster-hazelcast:jar:2.8-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-cluster-hazelcast:${gs.version}, C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\wps\wps-cluster-hazelcast\pom.xml, line 19, column 12
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-web-wps:jar:2.8-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-web-wps:${gs.version}, C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\wps\web-wps\pom.xml, line 21, column 14
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Coverage Service 2.0 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] REST UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] OGR parent
[INFO] OGR CORE
[INFO] OGR WFS
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] OGR WPS
[INFO] Excel Output Format
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web process status sharing with Hazelcast
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] GeoServer Release Module
[INFO]
[INFO] Building GeoServer 2.8-SNAPSHOT
Downloading: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.pom
Downloaded: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.pom (12 KB at 40.0 KB/sec)
Downloading: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.jar
Downloaded: http://repo.maven.apache.org/maven2/pl/project13/maven/git-commit-id-plugin/2.2.0/git-commit-id-plugin-2.2.0.jar (117 KB at 2469.8 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-api/14-SNAPSHOT/maven-metadata.xml (953 B at 0.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/library/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/library/14-SNAPSHOT/maven-metadata.xml (571 B at 1.5 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/modules/14-SNAPSHOT/maven-metadata.xml (571 B at 1.2 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml (572 B at 1.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-referencing/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/14-SNAPSHOT/maven-metadata.xml (2 KB at 2.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-metadata/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/14-SNAPSHOT/maven-metadata.xml (958 B at 2.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/14-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-opengis/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/14-SNAPSHOT/maven-metadata.xml (957 B at 2.0 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/maven-metadata.xml (2 KB at 3.0 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.8-SNAPSHOT/maven-metadata.xml (2 KB at 4.3 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geowebcache/geowebcache/1.8-SNAPSHOT/maven-metadata.xml (791 B at 2.9 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geoserver ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/org.geoserver$geoserver/ws/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ geoserver ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[JENKINS] Archiving disabled
log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
log4j:WARN Please initialize the log4j system properly.
