See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/146/changes>
Changes:
[andrea.aime] [GEOS-7603] Add support for dynamically choosing jpeg or png
[andrea.aime] Remove jpeg-png from the list of mime types used for wms 1.3 cite
[...truncated 6894 lines...]
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
Aug 08, 2016 1:52:48 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
Aug 08, 2016 1:52:48 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 15 ms.
Aug 08, 2016 1:52:48 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Aug 08, 2016 1:52:48 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
Aug 08, 2016 1:52:48 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Aug 08, 2016 1:52:48 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Aug 08, 2016 1:52:48 PM com.hazelcast.cluster.ClusterService
Members [2] {
Member [127.0.0.1]:5012
Members [2] {
Member [127.0.0.1]:5012 this
Aug 08, 2016 1:52:49 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Aug 08, 2016 1:52:49 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Aug 08, 2016 1:52:49 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.419 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.9-SNAPSHOT/gs-dxf-wps-2.9-SNAPSHOT-test-sources.jar
Aug 08, 2016 1:52:55 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Aug 08, 2016 1:52:55 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Aug 08, 2016 1:52:55 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Aug 08, 2016 1:52:55 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 18 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 13 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.944 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.9-SNAPSHOT/gs-wps-cluster-hazelcast-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.761 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.848 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.501 s]
[INFO] Main Module ........................................ SUCCESS [02:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.049 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 50.865 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [01:58 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.010 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.524 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.523 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 44.232 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:34 min]
[INFO] Web Map Service Module ............................. FAILURE [ 7.116 s]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 15.219 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.059 s]
[INFO] Core UI Module ..................................... SUCCESS [01:08 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.705 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] Printing Module .................................... SUCCESS [ 13.258 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.109 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.879 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.932 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.063 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.492 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.241 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 4.644 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.402 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.263 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.013 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.846 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:28 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.363 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.882 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.509 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.199 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.545 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.476 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.518 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.145 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.849 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.037 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.585 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.401 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 38.850 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.311 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.034 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.423 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.433 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.671 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.711 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 16.823 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 14.246 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 33.224 s]
[INFO] BUILD FAILURE
[INFO] Total time: 10:28 min (Wall Clock)
[INFO] Finished at: 2016-08-08T13:52:55+00:00
[INFO] Final Memory: 112M/339M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wms: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/wms/src/main/java/org/geoserver/wms/map/MetatileMapOutputFormat.java>:\[40,29\] error: cannot find symbol
[ERROR] package it.geosolutions.jaiext
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/wms/src/main/java/org/geoserver/wms/map/MetatileMapOutputFormat.java>:\[295,35\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
