See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/25/changes>
Changes:
[andrea.aime] [GEOS-7549] XSS: Reflected Cross Site Script Vulnerability
[...truncated 118284 lines...]
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-coverage-api/15-SNAPSHOT/maven-metadata.xml (962 B at 4.2 KB/sec)
May 23, 2016 10:56:06 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http://www.hibernatespatial.org:80: Connection reset
INFO: Retrying request to {}->http://www.hibernatespatial.org:80
May 23, 2016 11:00:52 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
May 23, 2016 11:05:31 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
[WARNING] Could not transfer metadata org.geotools:gt-coverage-api:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connection reset
[WARNING] Failure to transfer org.geotools:gt-coverage-api:15-SNAPSHOT/maven-metadata.xml from http://www.hibernatespatial.org/repository was cached in the local repository, resolution will not be reattempted until the update interval of hibspat has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-coverage-api:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository\): Connection reset
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-mbtiles/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-mbtiles/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-mbtiles/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-mbtiles/15-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-mbtiles/15-SNAPSHOT/maven-metadata.xml (957 B at 3.6 KB/sec)
May 23, 2016 11:14:50 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
[WARNING] Could not transfer metadata org.geotools:gt-mbtiles:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-mbtiles:15-SNAPSHOT/maven-metadata.xml from http://www.hibernatespatial.org/repository was cached in the local repository, resolution will not be reattempted until the update interval of hibspat has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-mbtiles:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository\): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-geopkg/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geopkg/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-geopkg/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-geopkg/15-SNAPSHOT/maven-metadata.xml
956/956 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-geopkg/15-SNAPSHOT/maven-metadata.xml (956 B at 3.0 KB/sec)
[WARNING] Could not transfer metadata org.geotools:gt-geopkg:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-geopkg:15-SNAPSHOT/maven-metadata.xml from http://www.hibernatespatial.org/repository was cached in the local repository, resolution will not be reattempted until the update interval of hibspat has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-geopkg:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository\): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml
956/956 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml (956 B at 4.3 KB/sec)
[WARNING] Could not transfer metadata org.geotools:gt-geobuf:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-geobuf:15-SNAPSHOT/maven-metadata.xml from http://www.hibernatespatial.org/repository was cached in the local repository, resolution will not be reattempted until the update interval of hibspat has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-geobuf:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository\): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml (957 B at 4.3 KB/sec)
[WARNING] Could not transfer metadata org.geotools:gt-ogr-jni:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-ogr-jni:15-SNAPSHOT/maven-metadata.xml from http://www.hibernatespatial.org/repository was cached in the local repository, resolution will not be reattempted until the update interval of hibspat has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-ogr-jni:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository\): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml
570/570 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml (570 B at 2.4 KB/sec)
[WARNING] Could not transfer metadata org.geotools:gt-ogr:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml (2 KB at 5.8 KB/sec)
[WARNING] Could not transfer metadata org.geotools:gt-ogr-core:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-ogr-core:15-SNAPSHOT/maven-metadata.xml from http://www.hibernatespatial.org/repository was cached in the local repository, resolution will not be reattempted until the update interval of hibspat has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-ogr-core:15-SNAPSHOT/maven-metadata.xml from/to hibspat (http://www.hibernatespatial.org/repository\): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [17:50 min]
[INFO] Core Platform Module ............................... SUCCESS [ 1.834 s]
[INFO] Open Web Service Module ............................ SUCCESS [22:14 min]
[INFO] Main Module ........................................ SUCCESS [ 01:14 h]
[INFO] GeoServer Security Modules ......................... SUCCESS [01:04 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.321 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.330 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.143 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [17:12 min]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.501 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.545 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:04 min]
[INFO] Web Map Service Module ............................. SUCCESS [05:17 min]
[INFO] KML support for GeoServer .......................... SUCCESS [07:06 min]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [42:40 min]
[INFO] REST Support Module ................................ SUCCESS [ 1.186 s]
[INFO] REST Configuration Service Module .................. SUCCESS [02:08 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.623 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.029 s]
[INFO] WMS UI Module ...................................... SUCCESS [01:04 min]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.546 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.114 s]
[INFO] Demos Module ....................................... SUCCESS [01:04 min]
[INFO] WCS UI Module ...................................... SUCCESS [05:48 min]
[INFO] Security UI Modules ................................ SUCCESS [ 0.651 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.749 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [07:16 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:04 min]
[INFO] REST UI Module ..................................... SUCCESS [ 1.198 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 36.289 s]
[INFO] Community Space .................................... SUCCESS [ 2.602 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.789 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.204 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [01:07 min]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.866 s]
[INFO] Aggregating Data Store ............................. SUCCESS [01:06 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.629 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.633 s]
[INFO] Web Processing Service Module ...................... SUCCESS [27:16 min]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.713 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.687 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.769 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [01:07 min]
[INFO] Groovy Scripting Extension ......................... FAILURE [ 01:30 h]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 05:30 h
[INFO] Finished at: 2016-05-23T23:21:08+00:00
[INFO] Final Memory: 147M/390M
[ERROR] Failed to execute goal on project gs-script-groovy: Could not resolve dependencies for project org.geoserver.script:gs-script-groovy:jar:2.9-SNAPSHOT: Failed to collect dependencies at org.geoscript:geoscript-groovy:jar:1.7-SNAPSHOT -> no.ecc.vectortile:java-vector-tile:jar:1.0.9: Failed to read artifact descriptor for no.ecc.vectortile:java-vector-tile:jar:1.0.9: Could not transfer artifact no.ecc.vectortile:java-vector-tile:pom:1.0.9 from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-script-groovy
