See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/399/changes>
Changes:
[emerkle] Log errors creating GeoGig index
[...truncated 14904 lines...]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-rest ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-rest ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.9-SNAPSHOT/gs-jms-geoserver-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.9-SNAPSHOT/gs-backup-restore-extension-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.9-SNAPSHOT/gs-backup-restore-rest-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.9-SNAPSHOT/gs-backup-restore-web-2.9-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 8.581 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 11.763 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.908 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.794 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.396 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.440 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 3.179 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.127 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.261 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.627 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 20.774 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.276 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.417 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.726 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.405 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.284 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.770 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.684 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.321 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.394 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.916 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.477 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.047 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.702 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.223 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 7.952 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 5.388 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 14.972 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.688 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.555 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.561 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.723 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.603 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.892 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.748 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.860 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.806 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.579 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.717 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.024 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.047 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.564 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 3.995 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.775 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 44.643 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 4.722 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.875 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.072 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 7.073 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.480 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.462 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.442 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 19.184 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 4.582 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 4.579 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 4.423 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.379 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.338 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.525 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 03:58 min (Wall Clock)
[INFO] Finished at: 2017-03-16T19:22:15+00:00
[INFO] Final Memory: 135M/701M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/community/geogig/src/test/java/org/geogig/geoserver/GeoGigTestData.java>:\[394,45\] error: incompatible types: SimpleFeatureType cannot be converted to RevFeatureType
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
