[Geoserver-devel] Build failed in Jenkins: geoserver-2.9.x #52
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/52/changes&gt;
Changes:
[andrea.aime] [GEOS-7553] GWC building tiles with requests failing at KVP parsing causes control-flow to lock up
[andrea.aime] [GEOS-7580] git-commit-id plugin is run 3 times for each module
[andrea.aime] [GEOS-7457] Stop using System.out.println, use logger instead
[...truncated 20355 lines...]
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/15-SNAPSHOT/maven-metadata.xml
571/571 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/modules/15-SNAPSHOT/maven-metadata.xml (571 B at 3.6 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/geotools/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/15-SNAPSHOT/maven-metadata.xml
572/572 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/geotools/15-SNAPSHOT/maven-metadata.xml (572 B at 2.6 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/15-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/15-SNAPSHOT/maven-metadata.xml (2 KB at 8.3 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/15-SNAPSHOT/maven-metadata.xml
958/958 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/15-SNAPSHOT/maven-metadata.xml (958 B at 6.8 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/15-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/15-SNAPSHOT/maven-metadata.xml (957 B at 3.9 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml (2 KB at 7.6 KB/sec)
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/ws/src/target/geoserver-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/maven-metadata.xml
790/790 B
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/maven-metadata.xml (790 B at 9.0 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-20160618.141116-567.pom
2/58 KB
4/58 KB
6/58 KB
8/58 KB
10/58 KB
12/58 KB
14/58 KB
16/58 KB
18/58 KB
20/58 KB
22/58 KB
24/58 KB
26/58 KB
28/58 KB
30/58 KB
32/58 KB
34/58 KB
36/58 KB
38/58 KB
40/58 KB
42/58 KB
44/58 KB
46/58 KB
48/58 KB
50/58 KB
52/58 KB
54/58 KB
56/58 KB
58/58 KB
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 5.878 s]
[INFO] Core Platform Module ............................... SKIPPED
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] Groovy Scripting Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 9.705 s
[INFO] Finished at: 2016-06-18T14:11:17+00:00
[INFO] Final Memory: 113M/333M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to deploy artifacts: Could not transfer artifact org.geoserver:geoserver:pom:2.9-20160618.141116-567 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-20160618.141116-567.pom. Return code is: 500, ReasonPhrase: Internal Server Error. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/53/changes&gt;
Changes:
[andrea.aime] [GEOS-7530] Style editor does not escape style replacement confirmation errors, fails in languages using single quote
[...truncated 20339 lines...]
Downloading: http://maven.geo-solutions.it/org/geotools/modules/15-SNAPSHOT/maven-metadata.xml
571/571 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/modules/15-SNAPSHOT/maven-metadata.xml (571 B at 1.9 KB/sec)
572/572 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/geotools/15-SNAPSHOT/maven-metadata.xml (572 B at 3.5 KB/sec)
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/15-SNAPSHOT/maven-metadata.xml (2 KB at 7.4 KB/sec)
958/958 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/15-SNAPSHOT/maven-metadata.xml (958 B at 3.6 KB/sec)
957/957 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/15-SNAPSHOT/maven-metadata.xml (957 B at 6.5 KB/sec)
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-main/15-SNAPSHOT/maven-metadata.xml (2 KB at 5.0 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
790/790 B
Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/maven-metadata.xml (790 B at 0.8 KB/sec)
Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-20160619.144227-567.pom
2/58 KB
4/58 KB
6/58 KB
8/58 KB
10/58 KB
12/58 KB
14/58 KB
16/58 KB
18/58 KB
20/58 KB
22/58 KB
24/58 KB
26/58 KB
28/58 KB
30/58 KB
32/58 KB
34/58 KB
36/58 KB
38/58 KB
40/58 KB
42/58 KB
44/58 KB
46/58 KB
48/58 KB
50/58 KB
52/58 KB
54/58 KB
56/58 KB
58/58 KB
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 8.237 s]
[INFO] Total time: 11.815 s
[INFO] Finished at: 2016-06-19T14:42:28+00:00
[INFO] Final Memory: 114M/345M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to deploy artifacts: Could not transfer artifact org.geoserver:geoserver:pom:2.9-20160619.144227-567 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.9-SNAPSHOT/geoserver-2.9-20160619.144227-567.pom. Return code is: 500, ReasonPhrase: Internal Server Error. -> [Help 1]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.9.x/54/&gt;
