See <https://build.geoserver.org/job/geoserver-java11/1167/display/redirect>
[...truncated 2.40 MB...]
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.pom (2.1 kB at 347 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-app-schema/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-app-schema/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/23-SNAPSHOT/maven-metadata.xml (1.4 kB at 67 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/23-SNAPSHOT/gt-app-schema-23-20190911.105535-11.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/23-SNAPSHOT/gt-app-schema-23-20190911.105535-11.pom (9.3 kB at 664 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/commons-digester/commons-digester/1.7/commons-digester-1.7.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/commons-digester/commons-digester/1.7/commons-digester-1.7.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/commons-digester/commons-digester/1.7/commons-digester-1.7.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-digester/commons-digester/1.7/commons-digester-1.7.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-digester/commons-digester/1.7/commons-digester-1.7.pom (6.6 kB at 1.6 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-mongodb/23-SNAPSHOT/gt-mongodb-23-20190911.105542-11.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/23-SNAPSHOT/gt-app-schema-23-20190911.105535-11.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/commons-digester/commons-digester/1.7/commons-digester-1.7.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-mongodb/23-SNAPSHOT/gt-mongodb-23-20190911.105542-11.jar (99 kB at 5.8 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-app-schema/23-SNAPSHOT/gt-app-schema-23-20190911.105535-11.jar (298 kB at 11 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/commons-digester/commons-digester/1.7/commons-digester-1.7.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/commons-digester/commons-digester/1.7/commons-digester-1.7.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/commons-digester/commons-digester/1.7/commons-digester-1.7.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/commons-digester/commons-digester/1.7/commons-digester-1.7.jar (140 kB at 23 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/mongodb/mongo-java-driver/3.3.0/mongo-java-driver-3.3.0.jar (1.5 MB at 44 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-mongodb ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-mongodb ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-mongodb ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-mongodb ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/mongodb/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/mongodb/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-mongodb ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/mongodb/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/mongodb/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-mongodb ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-mongodb ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/mongodb/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/mongodb/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-mongodb ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-mongodb ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-mongodb ---
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 36.492 s]
[INFO] Core Platform Module ............................... SUCCESS [ 29.266 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.509 s]
[INFO] Main Module ........................................ SUCCESS [01:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.075 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:27 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [ 1.952 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 23.910 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.583 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.135 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.234 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 1.051 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:13 min]
[INFO] Web Map Service Module ............................. FAILURE [01:00 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 7.341 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. FAILURE [ 0.784 s]
[INFO] gs-restconfig-wfs .................................. FAILURE [ 0.031 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.116 s]
[INFO] Core UI Module ..................................... SUCCESS [01:08 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... FAILURE [ 1.724 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ FAILURE [ 1.513 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... FAILURE [ 0.033 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.030 s]
[INFO] Printing Module .................................... FAILURE [ 29.655 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.521 s]
[INFO] ArcSDE DataStore Extension ......................... FAILURE [ 2.475 s]
[INFO] H2 DataStore Extension ............................. FAILURE [ 0.033 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.849 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.600 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.425 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.248 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 15.853 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 5.518 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.017 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.387 s]
[INFO] OGR WFS ............................................ FAILURE [ 0.267 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.016 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ FAILURE [ 13.084 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.600 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.575 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.539 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.853 s]
[INFO] GeoServer Layer Querying filter functions .......... FAILURE [ 9.049 s]
[INFO] Teradata DataStore Extension ....................... FAILURE [ 0.282 s]
[INFO] GeoServer Monitor Extensions ....................... FAILURE [ 0.231 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... FAILURE [ 0.030 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 3.168 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. FAILURE [ 0.045 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.017 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... FAILURE [ 18.962 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. FAILURE [ 2.107 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:22 min (Wall Clock)
[INFO] Finished at: 2019-09-12T00:51:51Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-querylayer: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/querylayer/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-dxf-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ogr-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ogr/ogr-wfs/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-excel: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/excel/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-web-sec: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wfs/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-arcsde: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/arcsde/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-teradata: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/teradata/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-grib: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/grib/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-api: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wcs2_0/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-monitor: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sec-jdbc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/jdbc/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-restconfig-wcs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig-wcs/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-restconfig-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig-wfs/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-rest: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/rest/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-h2: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/h2/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-xslt: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/xslt/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-printing: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/printing/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-mongodb: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/mongodb/pom.xml> isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
