See <https://build.geoserver.org/job/geoserver-java11/1236/display/redirect?page=changes>
Changes:
[Andrea Aime] Adding tile matrix set declarations
[...truncated 1.99 MB...]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xom/xom/1.0b3/xom-1.0b3.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xom/xom/1.0b3/xom-1.0b3.pom (1.1 kB at 360 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.17-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/extension/gs-h2/2.17-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/extension/gs-h2/2.17-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.17-SNAPSHOT/maven-metadata.xml (1.4 kB at 13 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/xom/xom/1.1/xom-1.1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/xerces/xmlParserAPIs/2.6.2/xmlParserAPIs-2.6.2.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/xerces/xercesImpl/2.11.0/xercesImpl-2.11.0.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/jaxen/jaxen/1.1-beta-8/jaxen-1.1-beta-8.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.17-SNAPSHOT/gs-h2-2.17-20190916.052621-292.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.17-SNAPSHOT/gs-h2-2.17-20190916.052621-292.jar (7.1 kB at 196 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/xom/xom/1.1/xom-1.1.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/xerces/xmlParserAPIs/2.6.2/xmlParserAPIs-2.6.2.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/xerces/xercesImpl/2.11.0/xercesImpl-2.11.0.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/jaxen/jaxen/1.1-beta-8/jaxen-1.1-beta-8.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/xom/xom/1.1/xom-1.1.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/xerces/xmlParserAPIs/2.6.2/xmlParserAPIs-2.6.2.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/xerces/xercesImpl/2.11.0/xercesImpl-2.11.0.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/jaxen/jaxen/1.1-beta-8/jaxen-1.1-beta-8.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xom/xom/1.1/xom-1.1.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xerces/xmlParserAPIs/2.6.2/xmlParserAPIs-2.6.2.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/xerces/xercesImpl/2.11.0/xercesImpl-2.11.0.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/jaxen/jaxen/1.1-beta-8/jaxen-1.1-beta-8.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xerces/xmlParserAPIs/2.6.2/xmlParserAPIs-2.6.2.jar (125 kB at 18 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/jaxen/jaxen/1.1-beta-8/jaxen-1.1-beta-8.jar (232 kB at 29 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar (314 kB at 35 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xom/xom/1.1/xom-1.1.jar (432 kB at 36 MB/s)
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/xerces/xercesImpl/2.11.0/xercesImpl-2.11.0.jar (1.4 MB at 39 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-sldservice ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sldservice ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-sldservice ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-sldservice ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sldservice ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-sldservice ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sldservice ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-sldservice ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-sldservice ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sldservice ---
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 01:34 h]
[INFO] Core Platform Module ............................... SUCCESS [ 23.536 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.063 s]
[INFO] Main Module ........................................ SUCCESS [01:15 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.062 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:24 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 43.904 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.289 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.579 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.551 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.820 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:32 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:17 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:52 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 13.068 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.121 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 10.155 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:50 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.684 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.429 s]
[INFO] gs-restconfig-wms .................................. FAILURE [ 13.498 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.096 s]
[INFO] Core UI Module ..................................... SUCCESS [01:07 min]
[INFO] WMS UI Module ...................................... FAILURE [ 14.535 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 15.816 s]
[INFO] Demos Module ....................................... FAILURE [ 0.897 s]
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.041 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:06 min]
[INFO] Security UI JDBC Module ............................ FAILURE [ 0.599 s]
[INFO] Security UI LDAP Module ............................ FAILURE [ 1.447 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.902 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.026 s]
[INFO] Printing Module .................................... SUCCESS [ 46.346 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.891 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 20.137 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.227 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 3.330 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.987 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.881 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.231 s]
[INFO] ImageMap Output Format ............................. FAILURE [ 0.702 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.834 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 4.171 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.014 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.392 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.679 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.014 s]
[INFO] Web Processing Service Module ...................... FAILURE [ 1.193 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.021 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.561 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.606 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.667 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.058 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.420 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.560 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.032 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... FAILURE [ 0.031 s]
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.265 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.028 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.169 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.243 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 1.324 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.015 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 27.245 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.013 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions FAILURE [ 0.795 s]
[INFO] GeoServer libjpeg-turbo Module ..................... FAILURE [ 0.122 s]
[INFO] GeoServer Data Importer ............................ FAILURE [ 4.402 s]
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 34.468 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 1.690 s]
[INFO] Vector Tiles ....................................... FAILURE [ 6.549 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.805 s]
[INFO] REST SLD service ................................... FAILURE [ 2.119 s]
[INFO] GeoFence security integration ...................... FAILURE [ 0.422 s]
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... FAILURE [ 1.412 s]
[INFO] BUILD FAILURE
[INFO] Total time: 01:46 h (Wall Clock)
[INFO] Finished at: 2019-09-16T09:31:52Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-kml: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/kml/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-restconfig-wms: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig-wms/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-demo: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/demo/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wms: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wms/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-libjpeg-turbo: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/libjpeg-turbo/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-imagemap: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/imagemap/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-netcdf: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/netcdf/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-importer: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-jdbc: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/jdbc/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-sec-ldap: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/ldap/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-security: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:3.0.2:jar (default-jar) on project gs-geofence: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/geofence/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-authkey: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/authkey/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-vectortiles: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/vectortiles/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0-eo-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wcs2_0-eo/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wps-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/wps/wps-core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/core/pom.xml> isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sldservice: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/sldService/pom.xml> isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
