[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #1261
See <https://build.geoserver.org/job/geoserver-java11/1261/display/redirect&gt;
[...truncated 1.78 MB...]
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/ows-1.0/1.0.0-2/ows-1.0-1.0.0-2.jar (20 kB at 57 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/gml-3.2/3.2.1-1/gml-3.2-3.2.1-1.jar (94 kB at 193 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/iso-19139-2007/1.0.0-1/iso-19139-2007-1.0.0-1.jar (47 kB at 57 kB/s)
[INFO] Downloaded from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/gml-3.1/3.1.1-4/gml-3.1-3.1.1-4.jar (103 kB at 122 kB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-csw-api ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-csw-api ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-csw-api ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-csw-api ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 reformatted).
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-csw-api ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/src/main/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-csw-api ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-csw-api ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-csw-api ---
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-csw-api ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-csw-api ---
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping CSW UI Module
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 29.494 s]
[INFO] Core Platform Module ............................... SUCCESS [ 24.369 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.262 s]
[INFO] Main Module ........................................ SUCCESS [01:13 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.040 s]
[INFO] GeoServer Security Tests Module .................... FAILURE [01:03 min]
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.530 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.560 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.850 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.753 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 1.108 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:09 min]
[INFO] Web Map Service Module ............................. FAILURE [ 19.442 s]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 7.774 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... FAILURE [ 7.790 s]
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.286 s]
[INFO] Core UI Module ..................................... SUCCESS [01:01 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... FAILURE [ 1.706 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ FAILURE [ 0.216 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.024 s]
[INFO] Printing Module .................................... FAILURE [ 17.341 s]
[INFO] Community Space .................................... SUCCESS [ 0.020 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.020 s]
[INFO] Sample DataAccess Integration Test ................. FAILURE [ 10.456 s]
[INFO] ArcSDE DataStore Extension ......................... FAILURE [ 2.051 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.423 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.162 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.897 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.244 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.177 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.509 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.014 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.398 s]
[INFO] OGR WFS ............................................ FAILURE [ 0.223 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.014 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ FAILURE [ 3.191 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.517 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.681 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.513 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.082 s]
[INFO] GeoServer Layer Querying filter functions .......... FAILURE [ 0.040 s]
[INFO] Teradata DataStore Extension ....................... FAILURE [ 0.238 s]
[INFO] GeoServer Monitor Extensions ....................... FAILURE [ 0.221 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.042 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 3.195 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. FAILURE [ 0.036 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.013 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... FAILURE [ 12.998 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 05:20 min (Wall Clock)
[INFO] Finished at: 2019-09-18T07:51:48Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-security-tests: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/security/security-tests/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-sample-data-access-test: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/app-schema/sample-data-access-test/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-excel: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/excel/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-querylayer: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/querylayer/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-dxf-core: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/dxf/core/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-ogr-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/ogr/ogr-wfs/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-web-wfs: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/wfs/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-web-sec: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/security/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wms: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wms/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-arcsde: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/arcsde/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-teradata: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/teradata/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-grib: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/grib/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-printing: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/printing/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-wcs2_0: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/wcs2_0/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:test-jar (default) on project gs-monitor: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/monitor/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:2.4:jar (default-jar) on project gs-csw-api: Error assembling JAR: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/csw/api/pom.xml&gt; isn't a file. -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-security-tests
See <https://build.geoserver.org/job/geoserver-java11/1262/display/redirect&gt;
[...truncated 2.91 MB...]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.111 s]
[INFO] WMS-EO ............................................. SUCCESS [ 1.429 s]
[INFO] ColorMap ........................................... SUCCESS [ 1.115 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 1.471 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 1.279 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 0.618 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 1.088 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 0.914 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 0.911 s]
[INFO] DownloadProcess .................................... SUCCESS [ 3.791 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.152 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 9.904 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.645 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 6.819 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.079 s]
[INFO] Solr Module ........................................ SUCCESS [ 8.576 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 1.212 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 20.307 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 1.166 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 1.149 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 0.844 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.726 s]
[INFO] GeoWebCache Azure blob ............................. SUCCESS [ 11.049 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.015 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 0.836 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 0.943 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 0.975 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 1.171 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.930 s]
[INFO] GeoServer Config Backup And Restore Core Module .... FAILURE [ 10.074 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. FAILURE [ 17.756 s]
[INFO] GeoServer Mapbox Styling ........................... FAILURE [ 3.836 s]
[INFO] WMTS Style editing extension ....................... SKIPPED
[INFO] GeoServer Security Community Modules ............... FAILURE [ 0.005 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SKIPPED
[INFO] GeoServer Keycloak Security Plugin ................. SKIPPED
[INFO] GeoServer SAMLv2 SSO Module ........................ FAILURE [ 8.893 s]
[INFO] gs-notification-common ............................. FAILURE [ 1.116 s]
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... FAILURE [ 0.024 s]
[INFO] JDBC Metrics Plugin ................................ FAILURE [ 0.022 s]
[INFO] OpenSearch EO parent ............................... FAILURE [ 0.004 s]
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] NSG Profiles ....................................... FAILURE [ 0.004 s]
[INFO] NSG WMTS 1.0 Profile ............................... SKIPPED
[INFO] NSG WFS 2.0 Profile ................................ SKIPPED
[INFO] NetCDF GHRSST encoder .............................. FAILURE [ 14.385 s]
[INFO] WFS 3 prototype .................................... SKIPPED
[INFO] MapML Support for GeoServer ........................ FAILURE [ 4.159 s]
[INFO] S3 Geotiff Support ................................. FAILURE [ 5.272 s]
[INFO] GeoServer Resource Browser ......................... FAILURE [ 0.657 s]
[INFO] GeoServer Task Manager ............................. FAILURE [ 3.724 s]
[INFO] GeoServer Task Manager Core ........................ SKIPPED
[INFO] GeoServer Task Manager S3 .......................... SKIPPED
[INFO] GeoServer Quality of Service GetCapabilities module FAILURE [ 1.159 s]
[INFO] OGR datastore panel ................................ FAILURE [ 1.156 s]
[INFO] gs-ogcapi .......................................... FAILURE [ 0.004 s]
[INFO] gs-ogcapi-core ..................................... SKIPPED
[INFO] gs-ogcapi-features ................................. SKIPPED
[INFO] gs-ogcapi-tiles .................................... SKIPPED
[INFO] gs-ogcapi-styles ................................... SKIPPED
[INFO] Catalog Services for the Web ISO metadata profile module FAILURE [ 4.661 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoStyler community module ......................... FAILURE [ 0.030 s]
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] GeoServer Metadata Customizer ...................... FAILURE [ 3.321 s]
[INFO] Total time: 03:16 min
[INFO] Finished at: 2019-09-18T09:22:25Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-backup-restore-core: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[10,38\] package org.springframework.batch.core does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[11,38\] package org.springframework.batch.core does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[12,38\] package org.springframework.batch.core does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[13,52\] package org.springframework.batch.core.scope.context does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[14,40\] package org.springframework.batch.repeat does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[24,28\] cannot find symbol
[ERROR] symbol: class StepExecution
[ERROR] location: class org.geoserver.backuprestore.ContinuableHandler
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[30,13\] cannot find symbol
[ERROR] symbol: class StepContribution
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[31,13\] cannot find symbol
[ERROR] symbol: class ChunkContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[32,13\] cannot find symbol
[ERROR] symbol: class JobExecution
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ContinuableHandler.java&gt;:\[29,12\] cannot find symbol
[ERROR] symbol: class RepeatStatus
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[7,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[8,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[9,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[11,32\] package com.thoughtworks.xstream does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[18,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[19,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[20,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[22,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[23,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[24,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[25,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[26,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[27,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[28,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[29,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[30,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[31,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[32,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/ResourceWriterTest.java&gt;:\[33,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[7,27\] package org.easymock does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[8,27\] package org.easymock does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[21,29\] package org.apache.commons.io does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[22,29\] package org.apache.commons.io does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[23,32\] package org.apache.commons.lang3 does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[24,32\] package org.custommonkey.xmlunit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[25,32\] package org.custommonkey.xmlunit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[26,32\] package org.custommonkey.xmlunit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[29,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[30,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[32,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[33,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[36,31\] package org.geoserver.data.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[37,31\] package org.geoserver.data.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[39,26\] package org.geoserver.test does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[40,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[41,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[42,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[43,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[44,28\] package org.geotools.feature does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[45,35\] package org.geotools.feature.simple does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[46,35\] package org.geotools.feature.simple does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[47,33\] package org.geotools.geometry.jts does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[48,32\] package org.geotools.referencing does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[49,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[50,31\] package org.locationtech.jts.io does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[51,34\] package org.opengis.feature.simple does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[54,47\] cannot find symbol
[ERROR] symbol: class GeoServerSystemTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[56,22\] cannot find symbol
[ERROR] symbol: class Catalog
[ERROR] location: class org.geoserver.backuprestore.BackupRestoreTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[58,22\] cannot find symbol
[ERROR] symbol: class XpathEngine
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[64,5\] cannot find symbol
[ERROR] symbol: class GeoServerDataDirectory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[98,31\] cannot find symbol
[ERROR] symbol: class SystemTestData
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[106,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[168,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[320,21\] cannot find symbol
[ERROR] symbol: class FeatureStore
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[332,19\] cannot find symbol
[ERROR] symbol: class Resource
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[342,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupRestoreTestSupport.java&gt;:\[342,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[3,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[3,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[4,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[4,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[5,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[5,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[13,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[14,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[15,17\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupWithoutSettingsTest.java&gt;:\[16,38\] package org.springframework.batch.core does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/GenericListener.java&gt;:\[19,41\] cannot find symbol
[ERROR] location: class org.geoserver.backuprestore.GenericListener
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/GenericListener.java&gt;:\[31,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[7,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[7,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[8,27\] package org.hamcrest does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[9,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[10,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[11,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[12,24\] package org.junit does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[12,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[23,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[24,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/community/backup-restore/core/src/test/java/org/geoserver/backuprestore/BackupTest.java&gt;:\[27,30\] package org.geoserver.platform does not exist
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal on project gs-wmts-multi-dimensional: Could not resolve dependencies for project org.geoserver.community:gs-wmts-multi-dimensional:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-gwc:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver:gs-rest:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:tests:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-gwc:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-mbstyle: Could not resolve dependencies for project org.geoserver.community:gs-mbstyle:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-rest:jar:2.17-SNAPSHOT, org.geoserver:gs-restconfig:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:tests:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-main:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-security: Could not resolve dependencies for project org.geoserver.community:gs-security:pom:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-platform:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-saml: Could not resolve dependencies for project org.geoserver.community:gs-saml:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-main:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-notification-common: Could not resolve dependencies for project org.geoserver.community:gs-notification-common:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-platform:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-ows-simulate: Could not resolve dependencies for project org.geoserver.community:gs-ows-simulate:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-wms:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-wms:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-jdbc-metrics: Could not resolve dependencies for project org.geoserver.community:gs-jdbc-metrics:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-main:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-oseo: Could not resolve dependencies for project org.geoserver.community:gs-oseo:pom:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-platform:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-nsg-profiles: Could not resolve dependencies for project org.geoserver.community:gs-nsg-profiles:pom:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-platform:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-netcdf-ghrsst: Could not resolve dependencies for project org.geoserver.community:gs-netcdf-ghrsst:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-wcs:jar:2.17-SNAPSHOT, org.geoserver:gs-wcs2_0:jar:2.17-SNAPSHOT, org.geoserver:gs-wcs2_0:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-wcs1_1:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-main:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-mapml: Could not resolve dependencies for project org.geoserver.community:gs-mapml:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-rest:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-gwc:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-demo:jar:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-rest:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-s3-geotiff: Could not resolve dependencies for project org.geoserver.community:gs-s3-geotiff:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-web-resource: Could not resolve dependencies for project org.geoserver.community:gs-web-resource:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-taskmanager: Could not resolve dependencies for project org.geoserver.community:gs-taskmanager:pom:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-platform:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-qos: Could not resolve dependencies for project org.geoserver.community:gs-qos:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-restconfig:jar:2.17-SNAPSHOT, org.geoserver:gs-rest:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-gwc:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-main:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-web-ogr: Could not resolve dependencies for project org.geoserver.community:gs-web-ogr:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-ogcapi: Could not resolve dependencies for project org.geoserver.community:gs-ogcapi:pom:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-platform:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-csw-iso: Could not resolve dependencies for project org.geoserver.csw:gs-csw-iso:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-main:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-geostyler: Could not resolve dependencies for project org.geoserver.community:gs-geostyler:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver:gs-wms:jar:2.17-SNAPSHOT, org.geoserver:gs-wfs:jar:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR] Failed to execute goal on project gs-metadata: Could not resolve dependencies for project org.geoserver.community:gs-metadata:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver:gs-main:jar:2.17-SNAPSHOT, org.geoserver:gs-ows:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:2.17-SNAPSHOT, org.geoserver:gs-main:jar:tests:2.17-SNAPSHOT, org.geoserver.web:gs-web-core:jar:tests:2.17-SNAPSHOT, org.geoserver:gs-platform:jar:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-main:jar:2.17-SNAPSHOT -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-backup-restore-core
See <https://build.geoserver.org/job/geoserver-java11/1263/display/redirect&gt;
