[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #385
See <https://build.geoserver.org/job/geoserver-java11/385/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Adding checks for unclosed sql closeables, but no failure was fuond
[Andrea Aime] Fixing the docs build
[...truncated 1.53 MB...]
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Feb 28, 2019 7:55:53 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
  at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
  at org.geoserver.importer.Importer.addTasks(Importer.java:472)
  at org.geoserver.importer.Importer.init(Importer.java:440)
  at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
  at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
  at jdk.internal.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
  at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
  at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
  at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
  at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
  at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
  at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
  at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
  at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.487 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.484 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 13.827 s]
[INFO] Core Platform Module ............................... SUCCESS [ 30.002 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 23.230 s]
[INFO] Main Module ........................................ SUCCESS [02:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.208 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:34 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [01:07 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 11.153 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.344 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 33.702 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.920 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [06:04 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:48 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:23 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 35.712 s]
[INFO] gs-rest ............................................ SUCCESS [ 23.660 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:19 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:23 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 19.218 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 24.136 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.649 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.235 s]
[INFO] Core UI Module ..................................... SUCCESS [01:53 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.541 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.920 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 27.019 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.927 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.609 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.123 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:35 min]
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SUCCESS [ 10.546 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.910 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.098 s]
[INFO] Printing Module .................................... SUCCESS [ 16.405 s]
[INFO] Community Space .................................... SUCCESS [ 0.059 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.068 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:24 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 24.799 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 22.685 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.871 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.755 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.395 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.383 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.303 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.072 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 7.238 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.274 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.117 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.813 s]
[INFO] OGR WFS ............................................ SUCCESS [ 17.829 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.087 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:14 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.054 s]
[INFO] Excel Output Format ................................ SUCCESS [ 21.137 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.258 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.177 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.154 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 25.562 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.811 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.813 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 25.185 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 4.093 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.193 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.877 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.084 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 10.109 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.136 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.431 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.868 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 27.964 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.465 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.148 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 16.897 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.725 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 36.154 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.501 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.051 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 24.145 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.375 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.070 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.802 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.809 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.305 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.214 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.929 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 37.262 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.649 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.764 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 32.722 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 18.046 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 42.723 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 15.685 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 11.431 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.835 s]
[INFO] REST SLD service ................................... SUCCESS [ 19.044 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 24.249 s]
[INFO] GeoFence Server .................................... SUCCESS [ 36.658 s]
[INFO] BUILD FAILURE
[INFO] Total time: 27:41 min (Wall Clock)
[INFO] Finished at: 2019-02-28T07:55:55+00:00
[INFO] Final Memory: 435M/1467M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:check (default) on project gs-sec-jdbc: You have 68 PMD violations. For more details see: <https://build.geoserver.org/job/geoserver-java11/ws/src/security/jdbc/target/pmd.xml&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.11.0:check (default) on project gs-kml: You have 6 PMD violations. For more details see: <https://build.geoserver.org/job/geoserver-java11/ws/src/kml/target/pmd.xml&gt; -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-sec-jdbc
See <https://build.geoserver.org/job/geoserver-java11/386/display/redirect&gt;
[...truncated 1.91 MB...]
[ERROR] symbol: class File
[ERROR] location: class org.geoserver.wcs.responses.NetCDFCoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,52\] cannot find symbol
[ERROR] symbol: class OutputStream
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,80\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[147,39\] cannot find symbol
[ERROR] symbol: class ApplicationContext
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[147,85\] cannot find symbol
[ERROR] symbol: class BeansException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[152,31\] cannot find symbol
[ERROR] symbol: class GridCoverage2D
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[30,13\] cannot find symbol
[ERROR] symbol: class GranuleStack
[ERROR] location: interface org.geoserver.wcs.responses.NetCDFEncoderFactory
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[11,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[13,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[14,21\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/apache/httpcomponents/httpcore/4.4.10/httpcore-4.4.10.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[14,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[15,37\] package org.geoserver.wcs2_0.response does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[16,28\] cannot access org.geoserver.wcs2_0.util
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[16,33\] package org.geoserver.wcs2_0.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,8\] cannot access ucar
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,12\] cannot access ucar.ma2
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,16\] import requires canonical name for <any>.InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[43,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[33,38\] cannot find symbol
[ERROR] symbol: class InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,8\] cannot access javax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,13\] cannot access javax.measure
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,21\] import requires canonical name for <any>.Unit
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[14,21\] cannot access javax.measure.format
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[14,28\] package javax.measure.format does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,25\] import requires canonical name for <any>.Component
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[16,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[16,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[17,30\] cannot access org.apache.wicket.ajax.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[17,35\] package org.apache.wicket.ajax.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,25\] cannot access org.apache.wicket.extensions
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,36\] cannot access org.apache.wicket.extensions.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,66\] import requires canonical name for <any>.markup.html.autocomplete.AutoCompleteTextField
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,43\] import requires canonical name for <any>.basic.Label
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[20,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[20,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[21,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java&gt;:\[5,1\] cannot access org.geoserver.geofence.server.rest
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/apache/xmlgraphics/batik-anim/1.10/batik-anim-1.10.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java&gt;:\[5,1\] cannot access org.geoserver.geofence.web
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java&gt;:\[5,1\] cannot access org.geoserver.geofence.internal
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;:\[24,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;:\[24,46\] cannot find symbol
[ERROR] symbol: class GeoServerSecuredPage
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[19,8\] cannot access org.geoserver.geofence
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[19,46\] cannot find symbol
[ERROR] symbol: class GeoServerDataProvider
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[19,68\] cannot find symbol
[ERROR] symbol: class ShortAdminRule
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;:\[30,13\] cannot find symbol
[ERROR] symbol: class GeoServerTablePanel
[ERROR] location: class org.geoserver.geofence.web.GeofenceServerAdminPage
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;:\[30,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;:\[32,13\] cannot find symbol
[ERROR] symbol: class AjaxLink
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;:\[32,22\] cannot find symbol
[ERROR] symbol: class Object
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[49,25\] cannot find symbol
[ERROR] symbol: class Property
[ERROR] location: class org.geoserver.geofence.web.GeofenceAdminRulesModel
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[49,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[52,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[52,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[55,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[55,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[58,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[58,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[61,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[61,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[64,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[64,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[66,20\] cannot find symbol
[ERROR] symbol: class AdminRuleAdminService
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[70,15\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[70,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[78,56\] cannot find symbol
[ERROR] symbol: class SortParam
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[78,15\] cannot find symbol
[ERROR] symbol: class Comparator
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[78,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[83,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[89,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[89,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[89,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[94,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[94,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[98,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[119,24\] cannot find symbol
[ERROR] symbol: class Collection
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[119,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[126,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[130,24\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[139,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[143,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[152,25\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[152,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[159,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[177,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[184,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;:\[184,62\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-csw: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java;&gt; <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/387/display/redirect&gt;
[...truncated 1.47 MB...]
Feb 28, 2019 12:25:27 PM org.geoserver.importer.Importer init
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.668 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.632 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.072 s]
[INFO] Core Platform Module ............................... SUCCESS [ 31.366 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 24.949 s]
[INFO] Main Module ........................................ SUCCESS [02:32 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.238 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:51 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [01:14 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 10.596 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.971 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 32.810 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 42.857 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [06:28 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:57 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:51 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 32.110 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.306 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:30 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:48 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 25.134 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 25.479 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 11.914 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.156 s]
[INFO] Core UI Module ..................................... SUCCESS [02:04 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 44.527 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:08 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 28.344 s]
[INFO] Demos Module ....................................... SUCCESS [ 33.224 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 18.250 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.212 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:40 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.396 s]
[INFO] REST UI Module ..................................... SUCCESS [ 11.962 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.126 s]
[INFO] Printing Module .................................... SUCCESS [ 19.093 s]
[INFO] Community Space .................................... SUCCESS [ 0.099 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.167 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 19.803 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 19.751 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.630 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.587 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.262 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.323 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.319 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.929 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.205 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.350 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.118 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.814 s]
[INFO] OGR WFS ............................................ SUCCESS [ 14.357 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.076 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:58 min]
[INFO] OGR WPS ............................................ SUCCESS [ 15.930 s]
[INFO] Excel Output Format ................................ SUCCESS [ 21.124 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.127 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.288 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.057 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 23.407 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 20.260 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 37.306 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 28.219 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.351 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.222 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 36.742 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.126 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 11.847 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.223 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.417 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.619 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 46.278 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 22.655 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.111 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 17.694 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.302 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 58.952 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 14.125 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.073 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 28.240 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 12.655 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.866 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 20.044 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 15.236 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.226 s]
[INFO] Importer Core Module ............................... SUCCESS [01:06 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:01 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 24.752 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 22.943 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 25.304 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 30.496 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:02 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 26.120 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 18.803 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.991 s]
[INFO] REST SLD service ................................... SUCCESS [ 34.573 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 30.174 s]
[INFO] GeoFence Server .................................... SUCCESS [01:01 min]
[INFO] Total time: 32:48 min (Wall Clock)
[INFO] Finished at: 2019-02-28T12:25:30+00:00
[INFO] Final Memory: 514M/1730M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-kml: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/kml/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/388/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Follow up with documentation on the prime datasource option for OGR
Feb 28, 2019 12:52:33 PM org.geoserver.importer.Importer init
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.498 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.400 s]
[INFO] Core Platform Module ............................... SUCCESS [ 32.138 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 23.301 s]
[INFO] Main Module ........................................ SUCCESS [02:31 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.240 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:29 min]
[INFO] GeoServer JDBC Security Module ..................... FAILURE [01:23 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 9.364 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.394 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 30.203 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.875 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [06:00 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:47 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 28.289 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.888 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:06 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:18 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 18.304 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 20.761 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 10.575 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.137 s]
[INFO] Core UI Module ..................................... SUCCESS [01:52 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.836 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.113 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 26.012 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.380 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.897 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.127 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:05 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 10.449 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.821 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.255 s]
[INFO] Printing Module .................................... SUCCESS [ 15.886 s]
[INFO] Community Space .................................... SUCCESS [ 0.135 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.084 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:26 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 21.509 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 17.054 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.357 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.514 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.323 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.520 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.390 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.930 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.921 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.226 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.072 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.797 s]
[INFO] OGR WFS ............................................ SUCCESS [ 15.145 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.085 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:13 min]
[INFO] OGR WPS ............................................ SUCCESS [ 7.880 s]
[INFO] Excel Output Format ................................ SUCCESS [ 20.902 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.204 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.253 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.181 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 24.361 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.838 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.671 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 25.563 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.354 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.173 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 23.440 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.073 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.620 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.100 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.473 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.301 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 27.464 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 13.828 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.116 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 17.162 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.805 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 35.766 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.938 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.062 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 22.604 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.256 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.074 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.812 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.757 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.518 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.196 s]
[INFO] Importer Core Module ............................... SUCCESS [ 52.388 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 36.872 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.219 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.429 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 29.870 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 18.366 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.041 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 14.873 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 11.027 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.137 s]
[INFO] REST SLD service ................................... SUCCESS [ 18.886 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 23.447 s]
[INFO] GeoFence Server .................................... SUCCESS [ 36.461 s]
[INFO] Total time: 26:58 min (Wall Clock)
[INFO] Finished at: 2019-02-28T12:52:35+00:00
[INFO] Final Memory: 484M/1627M
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-java11/389/display/redirect?page=changes&gt;
