See <https://build.geoserver.org/job/geoserver-java11/431/display/redirect>
[...truncated 1.32 MB...]
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Mar 16, 2019 5:22:07 PM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.IllegalArgumentException: input == null!
at java.desktop/javax.imageio.ImageIO.getImageReaders(ImageIO.java:647)
at org.geotools.gce.image.WorldImageFormat.accepts(WorldImageFormat.java:245)
at org.geotools.coverage.grid.io.GridFormatFinder.findFormats(GridFormatFinder.java:153)
at org.geotools.coverage.grid.io.GridFormatFinder.findFormats(GridFormatFinder.java:131)
at org.geoserver.importer.DataFormat.lookup(DataFormat.java:71)
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:133)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
at jdk.internal.reflect.GeneratedMethodAccessor294.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.862 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.679 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/pom.xml> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.395 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.502 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.016 s]
[INFO] Main Module ........................................ SUCCESS [01:10 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.198 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:54 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.282 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.557 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.970 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.890 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.342 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [04:30 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:48 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:00 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 26.722 s]
[INFO] gs-rest ............................................ SUCCESS [ 12.266 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:13 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.090 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 20.014 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.555 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.147 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.144 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 58.292 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.830 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.464 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.577 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.062 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:33 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:16 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 11.157 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.578 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.112 s]
[INFO] Printing Module .................................... SUCCESS [ 7.626 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.771 s]
[INFO] Community Space .................................... SUCCESS [ 0.116 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.095 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:41 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.045 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.262 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.879 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.446 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.286 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.241 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.169 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 6.488 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.602 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.187 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.089 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.314 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.865 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.060 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:36 min]
[INFO] Excel Output Format ................................ SUCCESS [ 9.565 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.172 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.025 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.146 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 13.765 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.036 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.810 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.062 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 22.517 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.053 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.786 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.090 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.030 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.000 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.850 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.766 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.037 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.786 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.984 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.804 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.700 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.052 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.221 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.047 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.748 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 16.763 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.665 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.226 s]
[INFO] Importer Core Module ............................... SUCCESS [01:06 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 58.041 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 27.024 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 14.600 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 20.066 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 23.703 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:00 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.556 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 11.762 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.150 s]
[INFO] REST SLD service ................................... SUCCESS [ 19.803 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 21.617 s]
[INFO] GeoFence Server .................................... SUCCESS [ 49.433 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:35 min (Wall Clock)
[INFO] Finished at: 2019-03-16T17:22:08+00:00
[INFO] Final Memory: 333M/1134M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
