[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #467
See <https://build.geoserver.org/job/geoserver-java11/467/display/redirect&gt;
[...truncated 1.05 MB...]
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Mar 23, 2019 12:25:11 PM com.hazelcast.internal.cluster.ClusterService
Members {size:2, ver:2} [
  Member [127.0.0.1]:5701 - e5b4d6c8-4285-4960-b859-6b323811944c this
  Member [127.0.0.1]:5702 - 06023c0e-9b83-4560-8d80-22c82b4c9b1d
INFO: [127.0.0.1]:5702 [dev] [3.11.1]
  Member [127.0.0.1]:5702 - 06023c0e-9b83-4560-8d80-22c82b4c9b1d this
Running org.geoserver.wps.ppio.DXFPPIOTest
Mar 23, 2019 12:25:12 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Mar 23, 2019 12:25:12 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Mar 23, 2019 12:25:12 PM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Mar 23, 2019 12:25:12 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 136
Mar 23, 2019 12:25:12 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
Mar 23, 2019 12:25:12 PM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Mar 23, 2019 12:25:12 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 06023c0e-9b83-4560-8d80-22c82b4c9b1d
Mar 23, 2019 12:25:12 PM com.hazelcast.internal.cluster.ClusterService
Members {size:1, ver:3} [
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
Mar 23, 2019 12:25:12 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 06023c0e-9b83-4560-8d80-22c82b4c9b1d
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Mar 23, 2019 12:25:12 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 211 ms.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 17 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.464 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.16-SNAPSHOT/gs-wps-cluster-hazelcast-2.16-SNAPSHOT-test-sources.jar&gt;
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.16-SNAPSHOT/gs-dxf-wps-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.101 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.029 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.391 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.114 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:30 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.665 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.056 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.994 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.009 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.497 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [04:13 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:20 min]
[INFO] Web Map Service Module ............................. FAILURE [01:46 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 10.290 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:02 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.690 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 16.169 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.093 s]
[INFO] Core UI Module ..................................... SUCCESS [ 58.132 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 8.424 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:06 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 50.416 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.722 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.532 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.062 s]
[INFO] Printing Module .................................... SUCCESS [ 7.840 s]
[INFO] Community Space .................................... SUCCESS [ 0.043 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.096 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.391 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.635 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.470 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.132 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.119 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.111 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.111 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.077 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.074 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.040 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.540 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.663 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.060 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 59.034 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.274 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.454 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.153 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.455 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.125 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.470 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.363 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.894 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.648 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.058 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.507 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.039 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.542 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.000 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.052 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.423 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.404 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 27.989 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.509 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.071 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.600 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.358 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.038 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.440 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.867 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.440 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.086 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:09 min (Wall Clock)
[INFO] Finished at: 2019-03-23T12:25:16+00:00
[INFO] Final Memory: 206M/697M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-java11/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-java11/468/display/redirect&gt;
