See <http://build.geoserver.org/job/geoserver-java11/577/display/redirect>
Started by upstream project "geowebcache-java11" build number 202
originally caused by:
Started by upstream project "geotools-java11" build number 239
Started by user Jody Garnett
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-java11/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-java11/lastSuccessful
at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
at java.nio.file.Files.deleteIfExists(Files.java:1165)
at hudson.Util.createSymlink(Util.java:1193)
at hudson.model.Run.createSymlink(Run.java:1955)
at hudson.model.Run.updateSymlinks(Run.java:1936)
at hudson.model.Run.execute(Run.java:1814)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-java11/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-java11/lastStable
at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on i-0075247cc3e84e5c2 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-java11/ws/>
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from git://github.com/geoserver/geoserver.git
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:894)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1161)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1192)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1816)
Caused by: hudson.plugins.git.GitException: Command "git config remote.origin.url git://github.com/geoserver/geoserver.git" returned status code 4:
stdout:
stderr: error: failed to write new configuration file <http://build.geoserver.org/job/geoserver-java11/ws/.git/config.lock>
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2010)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2006)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1638)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1650)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.setRemoteUrl(CliGitAPIImpl.java:1284)
at hudson.plugins.git.GitAPI.setRemoteUrl(GitAPI.java:160)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:566)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.lang.Thread.run(Thread.java:834)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-0075247cc3e84e5c2
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:957)
at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
at com.sun.proxy.$Proxy88.setRemoteUrl(Unknown Source)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl.setRemoteUrl(RemoteGitImpl.java:295)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:882)
See <https://build.geoserver.org/job/geoserver-java11/578/display/redirect>
Started by upstream project "geowebcache-java11" build number 203
Started by upstream project "geotools-java11" build number 243
Started by upstream project "geotools-java11" build number 244
Started by an SCM change
Building remotely on FleetCloud i-0f6e5364e758d998a (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-java11/ws/>
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <https://build.geoserver.org/job/geoserver-java11/ws/geoserver> # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Command "git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: remote: Enumerating objects: 128, done.
remote: Counting objects: 0% (1/128) remote: Counting objects: 1% (2/128) remote: Counting objects: 2% (3/128) remote: Counting objects: 3% (4/128) remote: Counting objects: 4% (6/128) remote: Counting objects: 5% (7/128) remote: Counting objects: 6% (8/128) remote: Counting objects: 7% (9/128) remote: Counting objects: 8% (11/128) remote: Counting objects: 9% (12/128) remote: Counting objects: 10% (13/128) remote: Counting objects: 11% (15/128) remote: Counting objects: 12% (16/128) remote: Counting objects: 13% (17/128) remote: Counting objects: 14% (18/128) remote: Counting objects: 15% (20/128) remote: Counting objects: 16% (21/128) remote: Counting objects: 17% (22/128) remote: Counting objects: 18% (24/128) remote: Counting objects: 19% (25/128) remote: Counting objects: 20% (26/128) remote: Counting objects: 21% (27/128) remote: Counting objects: 22% (29/128) remote: Counting objects: 23% (30/128) remote: Counting objects: 24% (31/128) remote: Counting objects: 25% (32/128) remote: Counting objects: 26% (34/128) remote: Counting objects: 27% (35/128) remote: Counting objects: 28% (36/128) remote: Counting objects: 29% (38/128) remote: Counting objects: 30% (39/128) remote: Counting objects: 31% (40/128) remote: Counting objects: 32% (41/128) remote: Counting objects: 33% (43/128) remote: Counting objects: 34% (44/128) remote: Counting objects: 35% (45/128) remote: Counting objects: 36% (47/128) remote: Counting objects: 37% (48/128) remote: Counting objects: 38% (49/128) remote: Counting objects: 39% (50/128) remote: Counting objects: 40% (52/128) remote: Counting objects: 41% (53/128) remote: Counting objects: 42% (54/128) remote: Counting objects: 43% (56/128) remote: Counting objects: 44% (57/128) remote: Counting objects: 45% (58/128) remote: Counting objects: 46% (59/128) remote: Counting objects: 47% (61/128) remote: Counting objects: 48% (62/128) remote: Counting objects: 49% (63/128) remote: Counting objects: 50% (64/128) remote: Counting objects: 51% (66/128) remote: Counting objects: 52% (67/128) remote: Counting objects: 53% (68/128) remote: Counting objects: 54% (70/128) remote: Counting objects: 55% (71/128) remote: Counting objects: 56% (72/128) remote: Counting objects: 57% (73/128) remote: Counting objects: 58% (75/128) remote: Counting objects: 59% (76/128) remote: Counting objects: 60% (77/128) remote: Counting objects: 61% (79/128) remote: Counting objects: 62% (80/128) remote: Counting objects: 63% (81/128) remote: Counting objects: 64% (82/128) remote: Counting objects: 65% (84/128) remote: Counting objects: 66% (85/128) remote: Counting objects: 67% (86/128) remote: Counting objects: 68% (88/128) remote: Counting objects: 69% (89/128) remote: Counting objects: 70% (90/128) remote: Counting objects: 71% (91/128) remote: Counting objects: 72% (93/128) remote: Counting objects: 73% (94/128) remote: Counting objects: 74% (95/128) remote: Counting objects: 75% (96/128) remote: Counting objects: 76% (98/128) remote: Counting objects: 77% (99/128) remote: Counting objects: 78% (100/128) remote: Counting objects: 79% (102/128) remote: Counting objects: 80% (103/128) remote: Counting objects: 81% (104/128) remote: Counting objects: 82% (105/128) remote: Counting objects: 83% (107/128) remote: Counting objects: 84% (108/128) remote: Counting objects: 85% (109/128) remote: Counting objects: 86% (111/128) remote: Counting objects: 87% (112/128) remote: Counting objects: 88% (113/128) remote: Counting objects: 89% (114/128) remote: Counting objects: 90% (116/128) remote: Counting objects: 91% (117/128) remote: Counting objects: 92% (118/128) remote: Counting objects: 93% (120/128) remote: Counting objects: 94% (121/128) remote: Counting objects: 95% (122/128) remote: Counting objects: 96% (123/128) remote: Counting objects: 97% (125/128) remote: Counting objects: 98% (126/128) remote: Counting objects: 99% (127/128) remote: Counting objects: 100% (128/128) remote: Counting objects: 100% (128/128), done.
remote: Compressing objects: 1% (1/89) remote: Compressing objects: 2% (2/89) remote: Compressing objects: 3% (3/89) remote: Compressing objects: 4% (4/89) remote: Compressing objects: 5% (5/89) remote: Compressing objects: 6% (6/89) remote: Compressing objects: 7% (7/89) remote: Compressing objects: 8% (8/89) remote: Compressing objects: 10% (9/89) remote: Compressing objects: 11% (10/89) remote: Compressing objects: 12% (11/89) remote: Compressing objects: 13% (12/89) remote: Compressing objects: 14% (13/89) remote: Compressing objects: 15% (14/89) remote: Compressing objects: 16% (15/89) remote: Compressing objects: 17% (16/89) remote: Compressing objects: 19% (17/89) remote: Compressing objects: 20% (18/89) remote: Compressing objects: 21% (19/89) remote: Compressing objects: 22% (20/89) remote: Compressing objects: 23% (21/89) remote: Compressing objects: 24% (22/89) remote: Compressing objects: 25% (23/89) remote: Compressing objects: 26% (24/89) remote: Compressing objects: 28% (25/89) remote: Compressing objects: 29% (26/89) remote: Compressing objects: 30% (27/89) remote: Compressing objects: 31% (28/89) remote: Compressing objects: 32% (29/89) remote: Compressing objects: 33% (30/89) remote: Compressing objects: 34% (31/89) remote: Compressing objects: 35% (32/89) remote: Compressing objects: 37% (33/89) remote: Compressing objects: 38% (34/89) remote: Compressing objects: 39% (35/89) remote: Compressing objects: 40% (36/89) remote: Compressing objects: 41% (37/89) remote: Compressing objects: 42% (38/89) remote: Compressing objects: 43% (39/89) remote: Compressing objects: 44% (40/89) remote: Compressing objects: 46% (41/89) remote: Compressing objects: 47% (42/89) remote: Compressing objects: 48% (43/89) remote: Compressing objects: 49% (44/89) remote: Compressing objects: 50% (45/89) remote: Compressing objects: 51% (46/89) remote: Compressing objects: 52% (47/89) remote: Compressing objects: 53% (48/89) remote: Compressing objects: 55% (49/89) remote: Compressing objects: 56% (50/89) remote: Compressing objects: 57% (51/89) remote: Compressing objects: 58% (52/89) remote: Compressing objects: 59% (53/89) remote: Compressing objects: 60% (54/89) remote: Compressing objects: 61% (55/89) remote: Compressing objects: 62% (56/89) remote: Compressing objects: 64% (57/89) remote: Compressing objects: 65% (58/89) remote: Compressing objects: 66% (59/89) remote: Compressing objects: 67% (60/89) remote: Compressing objects: 68% (61/89) remote: Compressing objects: 69% (62/89) remote: Compressing objects: 70% (63/89) remote: Compressing objects: 71% (64/89) remote: Compressing objects: 73% (65/89) remote: Compressing objects: 74% (66/89) remote: Compressing objects: 75% (67/89) remote: Compressing objects: 76% (68/89) remote: Compressing objects: 77% (69/89) remote: Compressing objects: 78% (70/89) remote: Compressing objects: 79% (71/89) remote: Compressing objects: 80% (72/89) remote: Compressing objects: 82% (73/89) remote: Compressing objects: 83% (74/89) remote: Compressing objects: 84% (75/89) remote: Compressing objects: 85% (76/89) remote: Compressing objects: 86% (77/89) remote: Compressing objects: 87% (78/89) remote: Compressing objects: 88% (79/89) remote: Compressing objects: 89% (80/89) remote: Compressing objects: 91% (81/89) remote: Compressing objects: 92% (82/89) remote: Compressing objects: 93% (83/89) remote: Compressing objects: 94% (84/89) remote: Compressing objects: 95% (85/89) remote: Compressing objects: 96% (86/89) remote: Compressing objects: 97% (87/89) remote: Compressing objects: 98% (88/89) remote: Compressing objects: 100% (89/89) remote: Compressing objects: 100% (89/89), done.
Receiving objects: 0% (1/328978) fatal: write error: No space left on device
fatal: index-pack failed
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1761)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$400(CliGitAPIImpl.java:72)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:442)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:655)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-0f6e5364e758d998a
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.GeneratedMethodAccessor329.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy74.execute(Unknown Source)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1152)
See <https://build.geoserver.org/job/geoserver-java11/579/display/redirect>
Building remotely on FleetCloud i-097defbc6728da012 (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-java11/ws/>
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-097defbc6728da012
at hudson.FilePath.act(FilePath.java:1069)
at hudson.FilePath.act(FilePath.java:1058)
at hudson.FilePath.mkdirs(FilePath.java:1243)
at hudson.plugins.git.GitSCM.createClient(GitSCM.java:811)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
java.nio.file.FileSystemException: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver>: No space left on device
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:100)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116)
at sun.nio.fs.UnixFileSystemProvider.createDirectory(UnixFileSystemProvider.java:385)
at java.nio.file.Files.createDirectory(Files.java:689)
at java.nio.file.Files.createAndCheckIsDirectory(Files.java:796)
at java.nio.file.Files.createDirectories(Files.java:782)
at hudson.FilePath.mkdirs(FilePath.java:3229)
at hudson.FilePath.access$1300(FilePath.java:210)
at hudson.FilePath$Mkdirs.invoke(FilePath.java:1251)
at hudson.FilePath$Mkdirs.invoke(FilePath.java:1247)
at hudson.FilePath$FileCallableWrapper.call(FilePath.java:3042)
See <https://build.geoserver.org/job/geoserver-java11/580/display/redirect>
See <https://build.geoserver.org/job/geoserver-java11/581/display/redirect>
