[Geoserver-devel] Build failed in Jenkins: geoserver-java11 #871
See <https://build.geoserver.org/job/geoserver-java11/871/display/redirect&gt;
[...truncated 1.18 MB...]
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.138 s - in org.geoserver.web.WebXmlTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/gs-web-app-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/gs-web-app-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/gs-web-app-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [189 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/geoserver.war&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/gs-web-app-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/gs-web-app-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/web/app/target/geoserver.war&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/web/gs-web-app/2.16-SNAPSHOT/gs-web-app-2.16-SNAPSHOT.war&gt;
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [99/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 reformatted).
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 270.342 s - in org.geoserver.importer.bdb.BDBImportStoreTest
[INFO] Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.411 s - in org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.504 s - in org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11/ws/geoserver/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 2.702 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.495 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.721 s]
[INFO] Main Module ........................................ SUCCESS [ 55.368 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.041 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:22 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.691 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.206 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.008 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.612 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.766 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:19 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:08 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:43 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 16.817 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.898 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 51.467 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:18 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.452 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.313 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.936 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.055 s]
[INFO] Core UI Module ..................................... SUCCESS [ 52.544 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.831 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:00 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.965 s]
[INFO] Demos Module ....................................... SUCCESS [06:23 min]
[INFO] WCS UI Module ...................................... SUCCESS [ 7.909 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [05:25 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.299 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.531 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] Printing Module .................................... SUCCESS [ 7.100 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 4.267 s]
[INFO] Community Space .................................... SUCCESS [ 0.031 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.032 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.483 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.423 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.872 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.114 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.111 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.170 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.058 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.712 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.390 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.064 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.367 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.215 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:53 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.398 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.182 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.062 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.334 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.102 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.892 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 6.936 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 16.001 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.693 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.353 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.031 s]
[INFO] Core Monitor Extension ............................. SUCCESS [01:29 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.440 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.524 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.820 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 18.446 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 8.941 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.032 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 3.613 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.996 s]
[INFO] Catalog Services for the Web core module ........... FAILURE [ 0.058 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.758 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.373 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.604 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [03:34 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.654 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.043 s]
[INFO] Importer Core Module ............................... SUCCESS [ 23.689 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 27.011 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [04:34 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.127 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.313 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [06:28 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [04:48 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.461 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.260 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.365 s]
[INFO] REST SLD service ................................... SUCCESS [02:15 min]
[INFO] GeoFence security integration ...................... SUCCESS [08:15 min]
[INFO] GeoFence Server .................................... SUCCESS [08:57 min]
[INFO] Authentication by unique url key ................... SUCCESS [06:26 min]
[INFO] BUILD FAILURE
[INFO] Total time: 44:16 min (Wall Clock)
[INFO] Finished at: 2019-08-22T22:44:25Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:format (default) on project gs-csw-core: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:format failed. ArrayIndexOutOfBoundsException: Index 43 out of bounds for length 22 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-core
See <https://build.geoserver.org/job/geoserver-java11/872/display/redirect&gt;
