See <https://build.geoserver.org/job/geoserver-java11-qa/618/display/redirect>
[...truncated 1.93 MB...]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-ogr-wps ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-ogr-wps ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-ogr-wps ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src>
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ogr-wps ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-ogr-wps ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-ogr-wps ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-ogr-wps ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/test-classes>
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-ogr-wps ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-ogr-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-ogr-wps ---
[INFO] Copying gt-main-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/dependency/gt-main-22-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/dependency/gwc-core-1.16-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-ogr-wps ---
[debug] Using AOSP style
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-ogr-wps >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-ogr-wps ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-importer-web ---
[INFO] Copying gt-main-22-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/dependency/gt-main-22-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.16-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/dependency/gwc-core-1.16-SNAPSHOT.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-web >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-web ---
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-ogr-wps <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-ogr-wps ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-ogr-wps >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-ogr-wps ---
[INFO] Fork Value is true
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-web ---
[INFO]
[INFO]
[INFO] >>> spotbugs-maven-plugin:3.1.10:check (default) > :spotbugs @ gs-importer-web >>>
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:spotbugs (spotbugs) @ gs-importer-web ---
[INFO] Done SpotBugs Analysis....
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-ogr-wps <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-ogr-wps ---
[INFO] BugInstance size is 0
[INFO] Error size is 0
[INFO] No errors/warnings found
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-ogr-wps ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-ogr-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.16-SNAPSHOT/gs-ogr-wps-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.16-SNAPSHOT/gs-ogr-wps-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.16-SNAPSHOT/gs-ogr-wps-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.16-SNAPSHOT/gs-ogr-wps-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/ogr/ogr-wps/target/gs-ogr-wps-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/extension/gs-ogr-wps/2.16-SNAPSHOT/gs-ogr-wps-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] <<< spotbugs-maven-plugin:3.1.10:check (default) < :spotbugs @ gs-importer-web <<<
[INFO]
[INFO]
[INFO] --- spotbugs-maven-plugin:3.1.10:check (default) @ gs-importer-web ---
[INFO]
[INFO] --- maven-checkstyle-plugin:3.0.0:check (default) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/pom.xml> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-java11-qa/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-java11-qa/ws/m2/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary for GeoServer Extensions 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer Extensions ............................... SUCCESS [ 6.288 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.142 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 18.460 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.863 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.778 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.580 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.594 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.861 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.458 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.766 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 11.681 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.938 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.906 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.061 s]
[INFO] OGR CORE ........................................... SUCCESS [ 6.541 s]
[INFO] OGR WFS ............................................ SUCCESS [ 7.666 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.097 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 32.717 s]
[INFO] OGR WPS ............................................ SUCCESS [ 6.881 s]
[INFO] Excel Output Format ................................ SUCCESS [ 10.018 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.067 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.022 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.298 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.038 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.593 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 12.169 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 6.245 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 5.747 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.120 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.803 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.084 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 12.837 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.081 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.934 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 8.946 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 10.027 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.216 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.078 s]
[INFO] Catalog Services for the Web interfaces ............ FAILURE [ 3.184 s]
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.054 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.706 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.073 s]
[INFO] Printing Module .................................... SUCCESS [ 24.948 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.048 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.782 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 6.614 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.326 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.464 s]
[INFO] Importer Core Module ............................... SUCCESS [ 20.923 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 13.722 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 8.985 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.561 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.104 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 11.528 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 15.101 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 22.121 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.849 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 8.336 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.750 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 15.155 s]
[INFO] GeoFence Server .................................... SUCCESS [ 36.281 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 11.411 s]
[INFO] BUILD FAILURE
[INFO] Total time: 04:38 min (Wall Clock)
[INFO] Finished at: 2019-08-29T20:03:14Z
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-csw-api: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:check failed. ArrayIndexOutOfBoundsException: Index 19 out of bounds for length 10 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-api
