See <http://ares.opengeo.org/jenkins/job/geoserver-master/1154/changes>
Changes:
[jeroen.dries] GEOS-6905 support WCS 2.0 requests embedded in WPS
[jeroen.dries] GEOS-6905 also support WCS version 2.0.0
[jeroen.dries] [WPS] Improved handling of unexpected WFS responses
[...truncated 20010 lines...]
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] *****************************************************************
[WARNING] The following plugins are not marked @threadSafe in Web Coverage Service 2.0 Earth Observation extensions:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wcs2_0-eo-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wcs2_0-eo-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs2_0-eo-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #941 from VitoTAP/feature/GEOS-6905
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 01.03.2015 @ 09:46:30 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 01-Mar-2015 09:48
[INFO] [GitCommitIdMojo] build.build.time = 01.03.2015 @ 10:07:25 UTC
[INFO] [GitCommitIdMojo] build.branch = d593613931dd2dd37c4a8e656a437c9179fbbdb4
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d593613
[INFO] [GitCommitIdMojo] build.commit.id = d593613931dd2dd37c4a8e656a437c9179fbbdb4
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #941 from VitoTAP/feature/GEOS-6905
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wcs2_0-eo-core ---
[INFO] Copying 1 resource
[INFO] Copying 17 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wcs2_0-eo-core ---
[INFO] Compiling 13 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/core/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 14 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 58 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wcs2_0-eo-core ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wcs2_0-eo-core ---
[INFO] Compiling 6 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/core/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteOnCoverageTest.java>:\[17,27\] error: cannot find symbol
[ERROR] package org.geoserver.wcs2_0
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteOnCoverageTest.java>:\[63,21\] error: cannot find symbol
[INFO] 2 errors
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wcs2_0-eo-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/core/target/surefire-reports>
T E S T S
Running org.geoserver.wcs2_0.eo.DescribeCoverageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.672s]
[INFO] Core Platform Module .............................. SUCCESS [14.322s]
[INFO] Open Web Service Module ........................... SUCCESS [16.455s]
[INFO] Main Module ....................................... SUCCESS [3:22.686s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.683s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.731s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [48.408s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.176s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.234s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.013s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:10.099s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:35.534s]
[INFO] Web Map Service Module ............................ SUCCESS [7:14.580s]
[INFO] REST Support Module ............................... SUCCESS [46.198s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.363s]
[INFO] Core UI Module .................................... SUCCESS [2:26.250s]
[INFO] WFS UI Module ..................................... SUCCESS [45.752s]
[INFO] Security UI Modules ............................... SUCCESS [0.257s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.217s]
[INFO] Printing Module ................................... SUCCESS [32.174s]
[INFO] Community Space ................................... SUCCESS [0.317s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.317s]
[INFO] Application Schema Support ........................ SUCCESS [0.192s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.731s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.005s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.282s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.605s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.587s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.598s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.543s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.974s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.496s]
[INFO] OGR parent ........................................ SUCCESS [0.269s]
[INFO] OGR WFS ........................................... SUCCESS [36.462s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.128s]
[INFO] Web Processing Service Module ..................... FAILURE [21.421s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [41.641s]
[INFO] Chart external graphics support ................... SUCCESS [1.253s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.286s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.935s]
[INFO] OWS request flow controller ....................... SUCCESS [31.067s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.055s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.223s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.417s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [44.567s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.438s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.072s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [24.570s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.263s]
[INFO] DXF WFS output format ............................. SUCCESS [38.836s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.224s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:26.106s (Wall Clock)
[INFO] Finished at: Sun Mar 01 10:07:39 UTC 2015
[INFO] Final Memory: 60M/258M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wps-core: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteOnCoverageTest.java>:\[63,21\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
