See <http://ares.opengeo.org/jenkins/job/geoserver-master/1413/changes>
Changes:
[tbarsballe] [GEOS-7038] Added support for prettyPrint to REST GET Style
[...truncated 26019 lines...]
[INFO] [GitCommitIdMojo] build.build.time = 22.05.2015 @ 20:07:49 UTC
[INFO] [GitCommitIdMojo] build.branch = dd32734593abc9c78e64eadf5167629793261eac
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = dd32734
[INFO] [GitCommitIdMojo] build.commit.id = dd32734593abc9c78e64eadf5167629793261eac
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1079 from tbarsballe/prettyPrint
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1079 from tbarsballe/prettyPrint
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.05.2015 @ 19:30:13 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 22-May-2015 19:33
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-sources.jar
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.203 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.332 sec
Results :
Tests run: 53, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] build.build.time = 22.05.2015 @ 20:08:09 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.717s]
[INFO] Core Platform Module .............................. SUCCESS [16.621s]
[INFO] Open Web Service Module ........................... SUCCESS [22.296s]
[INFO] Main Module ....................................... SUCCESS [2:30.823s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.022s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:10.091s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:02.793s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.224s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.420s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:01.437s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:54.684s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:27.772s]
[INFO] Web Map Service Module ............................ SUCCESS [6:30.668s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:19.407s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:24.102s]
[INFO] REST Support Module ............................... SUCCESS [41.546s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:37.847s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.799s]
[INFO] Core UI Module .................................... SUCCESS [1:54.731s]
[INFO] WMS UI Module ..................................... SUCCESS [55.172s]
[INFO] GWC UI Module ..................................... SUCCESS [1:27.670s]
[INFO] WFS UI Module ..................................... SUCCESS [35.222s]
[INFO] Demoes Module ..................................... SUCCESS [54.894s]
[INFO] WCS UI Module ..................................... SUCCESS [40.633s]
[INFO] Security UI Modules ............................... SUCCESS [0.332s]
[INFO] Security UI Core Module ........................... FAILURE [2:44.661s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [36.174s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.264s]
[INFO] Printing Module ................................... SUCCESS [37.572s]
[INFO] Community Space ................................... SUCCESS [0.173s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.446s]
[INFO] Application Schema Support ........................ SUCCESS [0.184s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:47.087s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.268s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [28.695s]
[INFO] GeoSearch Index Module ............................ SUCCESS [38.807s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.690s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.414s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.878s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.571s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.506s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.890s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.181s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.831s]
[INFO] OGR parent ........................................ SUCCESS [0.275s]
[INFO] OGR WFS ........................................... SUCCESS [25.913s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.385s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:54.597s]
[INFO] OGR WPS ........................................... SUCCESS [31.277s]
[INFO] Excel Output Format ............................... SUCCESS [42.322s]
[INFO] Chart external graphics support ................... SUCCESS [3.071s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.468s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.186s]
[INFO] OWS request flow controller ....................... SUCCESS [28.693s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [36.430s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [56.879s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.459s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.249s]
[INFO] Core Monitor Extension ............................ SUCCESS [33.596s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [18.542s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [52.158s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [49.030s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [35.499s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.325s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.541s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.383s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:37.466s]
[INFO] CSW UI Module ..................................... SUCCESS [36.033s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.364s]
[INFO] DXF WFS output format ............................. SUCCESS [38.610s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [20.747s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.299s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [52.859s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.057s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [24.140s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.198s]
[INFO] Importer Core Module .............................. SUCCESS [1:36.394s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:21.778s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [53.133s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.249s]
[INFO] BUILD FAILURE
[INFO] Total time: 34:38.427s (Wall Clock)
[INFO] Finished at: Fri May 22 20:08:09 UTC 2015
[INFO] Final Memory: 83M/250M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-sec-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
