See <http://ares.opengeo.org/jenkins/job/geoserver-master/1552/changes>
Changes:
[groldan] Disable gutter for vector tiles.
[...truncated 18098 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Disable gutter for vector tiles.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 02.07.2015 @ 17:18:25 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 02-Jul-2015 17:46
[INFO] [GitCommitIdMojo] build.build.time = 02.07.2015 @ 18:21:27 UTC
[INFO] [GitCommitIdMojo] build.branch = 18b2a07c74753e728ac312e34efa1f1306e4f640
[INFO] [GitCommitIdMojo] build.commit.user.email = groldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 18b2a07
[INFO] [GitCommitIdMojo] build.commit.id = 18b2a07c74753e728ac312e34efa1f1306e4f640
[INFO] [GitCommitIdMojo] build.commit.message.full = Disable gutter for vector tiles.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT-sources.jar
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.535 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.145 sec
Results :
Tests run: 55, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] build.build.time = 02.07.2015 @ 18:21:45 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.031s]
[INFO] Core Platform Module .............................. SUCCESS [16.136s]
[INFO] Open Web Service Module ........................... SUCCESS [24.421s]
[INFO] Main Module ....................................... SUCCESS [2:36.897s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.668s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:11.465s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:01.841s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.274s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [41.611s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.247s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:53.970s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.743s]
[INFO] Web Map Service Module ............................ SUCCESS [6:51.462s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:16.512s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [13.794s]
[INFO] REST Support Module ............................... SUCCESS [41.084s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:40.512s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.504s]
[INFO] Core UI Module .................................... SUCCESS [1:51.396s]
[INFO] WMS UI Module ..................................... SUCCESS [57.067s]
[INFO] WFS UI Module ..................................... SUCCESS [33.239s]
[INFO] Demoes Module ..................................... SUCCESS [51.787s]
[INFO] WCS UI Module ..................................... SUCCESS [38.206s]
[INFO] Security UI Modules ............................... SUCCESS [0.395s]
[INFO] Security UI Core Module ........................... SUCCESS [2:39.398s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:12.056s]
[INFO] Security UI LDAP Module ........................... SUCCESS [41.817s]
[INFO] REST UI Module .................................... SUCCESS [32.113s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.230s]
[INFO] Printing Module ................................... SUCCESS [38.933s]
[INFO] Community Space ................................... SUCCESS [0.161s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.919s]
[INFO] Application Schema Support ........................ SUCCESS [0.184s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:35.161s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.147s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.458s]
[INFO] GeoSearch Index Module ............................ SUCCESS [30.231s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.274s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.275s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.512s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.142s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.491s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.366s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [4.381s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.962s]
[INFO] OGR parent ........................................ SUCCESS [0.281s]
[INFO] OGR WFS ........................................... SUCCESS [26.030s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.349s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:10.421s]
[INFO] OGR WPS ........................................... SUCCESS [25.840s]
[INFO] Excel Output Format ............................... SUCCESS [45.667s]
[INFO] Chart external graphics support ................... SUCCESS [2.520s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.367s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.399s]
[INFO] OWS request flow controller ....................... SUCCESS [30.314s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [26.278s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:14.762s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.025s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.505s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.407s]
[INFO] Core Monitor Extension ............................ SUCCESS [29.427s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [20.554s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.288s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [13.798s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.342s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [5.881s]
[INFO] XLST based WFS output format ...................... SUCCESS [54.788s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [50.841s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.300s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.248s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.011s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.397s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:31.559s]
[INFO] CSW UI Module ..................................... SUCCESS [31.101s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.301s]
[INFO] DXF WFS output format ............................. SUCCESS [36.888s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [27.196s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.168s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [57.386s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [41.255s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [24.639s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.284s]
[INFO] Importer Core Module .............................. SUCCESS [1:35.765s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:21.134s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [53.561s]
[INFO] Importer Web UI Module ............................ SUCCESS [8.938s]
[INFO] BUILD FAILURE
[INFO] Total time: 35:12.604s (Wall Clock)
[INFO] Finished at: Thu Jul 02 18:21:46 UTC 2015
[INFO] Final Memory: 87M/256M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java>:\[645,35\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
