[Geoserver-devel] Build failed in Jenkins: geoserver-master #1635
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1635/&gt;
[...truncated 17300 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Web Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-cas ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1167 from mbarto/geos_7131
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 31.07.2015 @ 08:26:09 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 31-Jul-2015 12:16
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 12:49:21 UTC
[INFO] [GitCommitIdMojo] build.branch = defe3b646a1dd45182979fe0073ce9326848b2f8
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = defe3b6
[INFO] [GitCommitIdMojo] build.commit.id = defe3b646a1dd45182979fe0073ce9326848b2f8
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1167 from mbarto/geos_7131
GEOS-7131: fixed formatting in credentialsfromheaders tutorial
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 12:49:24 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-sec-cas ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec-cas ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec-cas ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.634s]
[INFO] Core Platform Module .............................. SUCCESS [15.510s]
[INFO] Open Web Service Module ........................... SUCCESS [19.817s]
[INFO] Main Module ....................................... SUCCESS [2:31.650s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.486s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:13.084s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:59.737s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.054s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [42.681s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.003s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:55.338s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.032s]
[INFO] Web Map Service Module ............................ SUCCESS [6:56.844s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:22.128s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:21.621s]
[INFO] REST Support Module ............................... SUCCESS [42.319s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:35.245s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.675s]
[INFO] Core UI Module .................................... SUCCESS [1:49.585s]
[INFO] WMS UI Module ..................................... SUCCESS [56.262s]
[INFO] GWC UI Module ..................................... SUCCESS [1:33.456s]
[INFO] WFS UI Module ..................................... SUCCESS [31.848s]
[INFO] Demoes Module ..................................... SUCCESS [54.845s]
[INFO] WCS UI Module ..................................... SUCCESS [38.217s]
[INFO] Security UI Modules ............................... SUCCESS [0.511s]
[INFO] Security UI Core Module ........................... SUCCESS [2:44.953s]
[INFO] Security UI JDBC Module ........................... SUCCESS [2:05.735s]
[INFO] Security UI LDAP Module ........................... SUCCESS [40.608s]
[INFO] REST UI Module .................................... SUCCESS [34.446s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.338s]
[INFO] Printing Module ................................... SUCCESS [41.352s]
[INFO] Community Space ................................... SUCCESS [0.224s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [13.056s]
[INFO] Application Schema Support ........................ SUCCESS [0.199s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:44.352s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.081s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.951s]
[INFO] GeoSearch Index Module ............................ SUCCESS [32.507s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.177s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.435s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.729s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.560s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.527s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.853s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.054s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.735s]
[INFO] OGR parent ........................................ SUCCESS [0.448s]
[INFO] OGR WFS ........................................... SUCCESS [26.748s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.405s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SUCCESS [40.952s]
[INFO] Chart external graphics support ................... SUCCESS [1.936s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.625s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.095s]
[INFO] OWS request flow controller ....................... SUCCESS [31.549s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.314s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.389s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.383s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.061s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [20.588s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.257s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [11.220s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.513s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.124s]
[INFO] XLST based WFS output format ...................... SUCCESS [52.547s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [51.616s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.769s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.353s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.053s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.018s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.441s]
[INFO] CSW UI Module ..................................... SUCCESS [31.504s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.302s]
[INFO] DXF WFS output format ............................. SUCCESS [37.595s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.200s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [22.799s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.329s]
[INFO] Importer Core Module .............................. SUCCESS [1:52.172s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:38.520s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [56.710s]
[INFO] Importer Web UI Module ............................ SUCCESS [9.182s]
[INFO] BUILD FAILURE
[INFO] Total time: 32:45.156s (Wall Clock)
[INFO] Finished at: Fri Jul 31 12:49:24 UTC 2015
[INFO] Final Memory: 83M/268M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1636/&gt;
