See <http://ares.opengeo.org/jenkins/job/geoserver-master/1639/changes>
Changes:
[andrea.aime] [GEOS-7124] Remote Code Execution with Xstream
[andrea.aime] Work in progress on more whitelist authorization
[andrea.aime] Property to add to XStream whitelist
[andrea.aime] Make PropertyRule public and move to platform
[andrea.aime] Authorize wfsinfo and gmlinfo
[andrea.aime] Authorize WatermarkInfo
[andrea.aime] Adding a test for WPS xml service loading
[andrea.aime] Adding wcs whitelist bits too
[andrea.aime] Authorize SOLR configuration bits
[andrea.aime] Add better error message and descriptive log when a class is not in the whitelist
[...truncated 10245 lines...]
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[WARNING] *****************************************************************
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-wcs2_0-eo ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1169 from geoserver/xstream_security
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 31.07.2015 @ 17:47:30 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 31-Jul-2015 18:07
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 18:20:29 UTC
[INFO] [GitCommitIdMojo] build.branch = e26195b86c399e1d2f50d2f224c5b10473017c24
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e26195b
[INFO] [GitCommitIdMojo] build.commit.id = e26195b86c399e1d2f50d2f224c5b10473017c24
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1169 from geoserver/xstream_security
Xstream security fixes
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs2_0-eo ---
[INFO] Copying 3 resources
[INFO] Copying 10 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs2_0-eo ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs2_0-eo ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/surefire-reports>
T E S T S
Running org.geoserver.wcs2_0.eo.web.WCSEOAdminPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.329 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.41 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2015 @ 18:20:51 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.599s]
[INFO] Core Platform Module .............................. SUCCESS [15.532s]
[INFO] Open Web Service Module ........................... SUCCESS [19.929s]
[INFO] Main Module ....................................... SUCCESS [2:32.614s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.453s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:12.911s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:02.629s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.903s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.082s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.869s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.371s]
[INFO] Web Feature Service Module ........................ FAILURE [3:28.625s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [42.471s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.548s]
[INFO] Core UI Module .................................... SUCCESS [1:51.327s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.315s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.272s]
[INFO] Printing Module ................................... SUCCESS [37.579s]
[INFO] Community Space ................................... SUCCESS [0.305s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.594s]
[INFO] Application Schema Support ........................ SUCCESS [0.173s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.215s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.918s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.320s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.740s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.489s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.515s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.057s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.871s]
[INFO] OGR parent ........................................ SUCCESS [0.337s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.478s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.947s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.351s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.035s]
[INFO] OWS request flow controller ....................... SUCCESS [30.332s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.629s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.809s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.542s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [31.316s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.317s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:35.718s]
[INFO] CSW UI Module ..................................... SUCCESS [26.763s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.317s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.276s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [43.438s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [22.703s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 13:50.440s (Wall Clock)
[INFO] Finished at: Fri Jul 31 18:20:51 UTC 2015
[INFO] Final Memory: 60M/264M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
