See <http://ares.opengeo.org/jenkins/job/geoserver-master/1682/>
[...truncated 13464 lines...]
[INFO] [GitCommitIdMojo] build.branch = 2dabcc2aee773c2a219d1b9f3567de3438e31062
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2dabcc2
[INFO] [GitCommitIdMojo] build.commit.id = 2dabcc2aee773c2a219d1b9f3567de3438e31062
[INFO] [GitCommitIdMojo] build.commit.message.full = recommend Resources.delete( res ) for recursive delete
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.683 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-wps ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = recommend Resources.delete( res ) for recursive delete
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.08.2015 @ 23:07:30 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-Aug-2015 15:38
[INFO] [GitCommitIdMojo] build.build.time = 12.08.2015 @ 16:00:23 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.570s]
[INFO] Core Platform Module .............................. SUCCESS [19.103s]
[INFO] Open Web Service Module ........................... SUCCESS [21.311s]
[INFO] Main Module ....................................... SUCCESS [2:37.053s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.553s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.993s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:06.711s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.704s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.011s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.393s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:54.161s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:22.333s]
[INFO] Web Map Service Module ............................ FAILURE [7:52.056s]
[INFO] REST Support Module ............................... SUCCESS [40.943s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.500s]
[INFO] Core UI Module .................................... SUCCESS [1:54.726s]
[INFO] WFS UI Module ..................................... SUCCESS [33.422s]
[INFO] Security UI Modules ............................... SUCCESS [0.288s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.349s]
[INFO] Printing Module ................................... SUCCESS [40.282s]
[INFO] Community Space ................................... SUCCESS [0.264s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.375s]
[INFO] Application Schema Support ........................ SUCCESS [0.218s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.835s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.119s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.737s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.600s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.683s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.071s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.579s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.362s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.045s]
[INFO] OGR parent ........................................ SUCCESS [0.325s]
[INFO] OGR CORE .......................................... SUCCESS [6.449s]
[INFO] OGR WFS ........................................... SUCCESS [26.353s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.447s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:10.026s]
[INFO] OGR WPS ........................................... SUCCESS [27.336s]
[INFO] Excel Output Format ............................... SUCCESS [45.159s]
[INFO] Chart external graphics support ................... SUCCESS [3.212s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.077s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.995s]
[INFO] OWS request flow controller ....................... SUCCESS [28.302s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [24.482s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.425s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.088s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.846s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.139s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.252s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.811s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.627s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:31.161s]
[INFO] CSW UI Module ..................................... SUCCESS [27.558s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.238s]
[INFO] DXF WFS output format ............................. SUCCESS [37.958s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [22.916s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.161s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [47.450s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [31.636s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:21.072s (Wall Clock)
[INFO] Finished at: Wed Aug 12 16:00:23 UTC 2015
[INFO] Final Memory: 68M/230M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
