See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1701/changes>
Changes:
[niels] Complex features refactoring: update csw & app-schema
[...truncated 22693 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8814145
[INFO] [GitCommitIdMojo] build.commit.id = 8814145bcd69ffb707bad078d250cdce2cc92bf2
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1064 from NielsCharlier/complexrefact
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-csw-api ---
[INFO] Copying 0 resource
[INFO] Copying 90 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-csw-api ---
[INFO] Compiling 29 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/extension/csw/api/target/classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\RecordFeatureTypeRegistryConfiguration.java:[9,31] error: package org.geotools.xml.complex does not exist
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\RecordFeatureTypeRegistryConfiguration.java:[18,63] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\CSWRecordDescriptor.java:[154,50] error: no suitable constructor found for FeatureTypeRegistry(NamespaceSupport,FeatureTypeFactory,RecordFeatureTypeRegistryConfiguration)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\RecordFeatureTypeRegistryConfiguration.java:[26,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\RecordFeatureTypeRegistryConfiguration.java:[31,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\RecordFeatureTypeRegistryConfiguration.java:[36,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\RecordFeatureTypeRegistryConfiguration.java:[41,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\RecordFeatureTypeRegistryConfiguration.java:[46,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\src\main\java\org\geoserver\csw\records\iso\MetaDataDescriptor.java:[85,50] error: no suitable constructor found for FeatureTypeRegistry(NamespaceSupport,FeatureTypeFactory,RecordFeatureTypeRegistryConfiguration,boolean)
[INFO] 9 errors
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [13.196s]
[INFO] Core Platform Module .............................. SUCCESS [22.610s]
[INFO] Open Web Service Module ........................... SUCCESS [15.212s]
[INFO] Main Module ....................................... SUCCESS [3:35.473s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.842s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [35.252s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [12.325s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.353s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.151s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.735s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.087s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:00.585s]
[INFO] Web Map Service Module ............................ SUCCESS [3:52.160s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.477s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:47.071s]
[INFO] REST Support Module ............................... SUCCESS [25.849s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:00.767s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.327s]
[INFO] Core UI Module .................................... SUCCESS [1:42.804s]
[INFO] WMS UI Module ..................................... SUCCESS [36.832s]
[INFO] GWC UI Module ..................................... SUCCESS [51.827s]
[INFO] WFS UI Module ..................................... SUCCESS [17.441s]
[INFO] Demoes Module ..................................... SUCCESS [33.415s]
[INFO] WCS UI Module ..................................... SUCCESS [27.020s]
[INFO] Security UI Modules ............................... SUCCESS [0.686s]
[INFO] Security UI Core Module ........................... SUCCESS [2:10.557s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:59.293s]
[INFO] Security UI LDAP Module ........................... SUCCESS [24.194s]
[INFO] REST UI Module .................................... SUCCESS [19.780s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.203s]
[INFO] Community Space ................................... SUCCESS [0.297s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.468s]
[INFO] Application Schema Support ........................ SUCCESS [0.312s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:38.738s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [17.834s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.472s]
[INFO] GeoSearch Index Module ............................ SUCCESS [21.016s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.898s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.437s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.374s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.421s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.421s]
[INFO] ImageMap Output Format ............................ SUCCESS [13.556s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.608s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.453s]
[INFO] OGR parent ........................................ SUCCESS [0.405s]
[INFO] OGR WFS ........................................... SUCCESS [16.146s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.577s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:57.384s]
[INFO] OGR WPS ........................................... SUCCESS [18.954s]
[INFO] Excel Output Format ............................... SUCCESS [23.259s]
[INFO] Chart external graphics support ................... SUCCESS [2.012s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.823s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.483s]
[INFO] OWS request flow controller ....................... SUCCESS [18.631s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [31.871s]
[INFO] Web Processing Service GUI ........................ SUCCESS [46.628s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [31.449s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.901s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.608s]
[INFO] Core Monitor Extension ............................ SUCCESS [21.559s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [11.747s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.702s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.249s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.733s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.604s]
[INFO] XLST based WFS output format ...................... SUCCESS [31.559s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [34.835s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [23.322s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.515s]
[INFO] Catalog Services for the Web interfaces ........... FAILURE [4.867s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 47:24.002s
[INFO] Finished at: Sat May 16 10:32:49 CEST 2015
[INFO] Final Memory: 93M/232M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-csw-api: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-csw-api
channel stopped
Finished Calculation of disk usage of workspace in 6 second
