[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #1705
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1705/changes&gt;
Changes:
[andrea.aime] [GEOS-7031] Stop shipping old Oracle JDBC driver
[...truncated 1284 lines...]
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.531 sec
Running org.geoserver.util.DefaultCacheProviderTest
18 mag 16:49:59 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
  Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.016 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.622 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.546 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.668 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.451 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.967 sec
Results :
Failed tests: testExpireByAccess(org.geoserver.security.auth.GuavaAuthenticationCacheTest)
  testExpireByCreation(org.geoserver.security.auth.GuavaAuthenticationCacheTest)
Tests run: 658, Failures: 2, Errors: 0, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 3 second
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.922s]
[INFO] Core Platform Module .............................. SUCCESS [19.328s]
[INFO] Open Web Service Module ........................... SUCCESS [13.631s]
[INFO] Main Module ....................................... FAILURE [-19.-850s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: -12.-382s
[INFO] Finished at: Mon May 18 16:50:12 CEST 2015
[INFO] Final Memory: 42M/244M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
channel stopped
Finished Calculation of disk usage of workspace in 8 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1706/changes&gt;
Changes:
[maurobartolomeoli] GEOS-7020: additional fix to avoid overflows of hitArea outside of painted area
[...truncated 26091 lines...]
[INFO] Copying asm-util-4.1.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/asm-util-4.1.jar&gt;
[INFO] Copying encoder-1.1.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/encoder-1.1.jar&gt;
[INFO] Copying parboiled-core-1.1.6.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/parboiled-core-1.1.6.jar&gt;
[INFO] Copying parboiled-java-1.1.6.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/parboiled-java-1.1.6.jar&gt;
[INFO] Copying org.restlet-1.0.8.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/org.restlet-1.0.8.jar&gt;
[INFO] Copying org.restlet.ext.fileupload-1.0.8.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/org.restlet.ext.fileupload-1.0.8.jar&gt;
[INFO] Copying org.restlet.ext.freemarker-1.0.8.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/org.restlet.ext.freemarker-1.0.8.jar&gt;
[INFO] Copying org.restlet.ext.spring-1.0.8.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/org.restlet.ext.spring-1.0.8.jar&gt;
[INFO] Copying slf4j-api-1.6.1.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/slf4j-api-1.6.1.jar&gt;
[INFO] Copying slf4j-log4j12-1.7.10.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/slf4j-log4j12-1.7.10.jar&gt;
[INFO] Copying spring-aop-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-aop-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-asm-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-asm-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-beans-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-beans-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-context-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-context-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-context-support-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-context-support-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-core-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-core-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-expression-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-expression-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-jdbc-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-jdbc-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-orm-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-orm-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-tx-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-tx-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-web-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-web-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-webmvc-3.1.4.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-webmvc-3.1.4.RELEASE.jar&gt;
[INFO] Copying spring-security-cas-3.1.0.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-security-cas-3.1.0.RELEASE.jar&gt;
[INFO] Copying spring-security-config-3.1.0.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-security-config-3.1.0.RELEASE.jar&gt;
[INFO] Copying spring-security-core-3.1.0.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-security-core-3.1.0.RELEASE.jar&gt;
[INFO] Copying spring-security-crypto-3.1.0.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-security-crypto-3.1.0.RELEASE.jar&gt;
[INFO] Copying spring-security-web-3.1.0.RELEASE.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/spring-security-web-3.1.0.RELEASE.jar&gt;
[INFO] Copying htmlvalidator-1.2.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/htmlvalidator-1.2.jar&gt;
[INFO] Copying picocontainer-1.2.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/picocontainer-1.2.jar&gt;
[INFO] Copying postgresql-8.4-701.jdbc3.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/postgresql-8.4-701.jdbc3.jar&gt;
[INFO] Copying stax-api-1.0.1.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/stax-api-1.0.1.jar&gt;
[INFO] Copying jasper-compiler-5.5.15.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/jasper-compiler-5.5.15.jar&gt;
[INFO] Copying jasper-compiler-jdt-5.5.15.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/jasper-compiler-jdt-5.5.15.jar&gt;
[INFO] Copying jasper-runtime-5.5.15.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/jasper-runtime-5.5.15.jar&gt;
[INFO] Copying serializer-2.7.1.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/serializer-2.7.1.jar&gt;
[INFO] Copying xalan-2.7.0.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xalan-2.7.0.jar&gt;
[INFO] Copying xercesImpl-2.11.0.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xercesImpl-2.11.0.jar&gt;
[INFO] Copying xml-apis-1.0.b2.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xml-apis-1.0.b2.jar&gt;
[INFO] Copying xml-apis-ext-1.3.04.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xml-apis-ext-1.3.04.jar&gt;
[INFO] Copying xml-apis-xerces-2.7.1.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xml-apis-xerces-2.7.1.jar&gt;
[INFO] Copying xmlpull-1.1.3.1.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xmlpull-1.1.3.1.jar&gt;
[INFO] Copying xmlunit-1.3.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xmlunit-1.3.jar&gt;
[INFO] Copying xpp3-1.1.3.4.O.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xpp3-1.1.3.4.O.jar&gt;
[INFO] Copying xpp3_min-1.1.4c.jar to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/release/target/dependency/xpp3_min-1.1.4c.jar&gt;
[INFO] gt-api-14-SNAPSHOT.jar already exists in destination.
[INFO] gwc-core-1.8-SNAPSHOT.jar already exists in destination.
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (default) @ gs-release ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[INFO] Executed tasks
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.344s]
[INFO] Core Platform Module .............................. SUCCESS [19.255s]
[INFO] Open Web Service Module ........................... SUCCESS [15.176s]
[INFO] Main Module ....................................... SUCCESS [3:36.685s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.718s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.927s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [12.781s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.577s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:01.984s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.193s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:56.000s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:58.092s]
[INFO] Web Map Service Module ............................ SUCCESS [3:57.563s]
[INFO] KML support for GeoServer ......................... SUCCESS [53.276s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [-11.-658s]
[INFO] REST Support Module ............................... SUCCESS [2:50:21.794s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:03.086s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.281s]
[INFO] Core UI Module .................................... SUCCESS [1:51.059s]
[INFO] WMS UI Module ..................................... SUCCESS [35.750s]
[INFO] GWC UI Module ..................................... SUCCESS [51.761s]
[INFO] WFS UI Module ..................................... SUCCESS [17.908s]
[INFO] Demoes Module ..................................... SUCCESS [33.260s]
[INFO] WCS UI Module ..................................... SUCCESS [26.341s]
[INFO] Security UI Modules ............................... SUCCESS [0.593s]
[INFO] Security UI Core Module ........................... SUCCESS [2:13.807s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:29.461s]
[INFO] Security UI LDAP Module ........................... SUCCESS [23.842s]
[INFO] REST UI Module .................................... SUCCESS [20.243s]
[INFO] GeoServer Web Application ......................... SUCCESS [13.859s]
[INFO] Community Space ................................... SUCCESS [0.765s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.312s]
[INFO] Application Schema Support ........................ SUCCESS [0.375s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:23.293s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [18.236s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [17.205s]
[INFO] GeoSearch Index Module ............................ SUCCESS [20.133s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.302s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.391s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.421s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.422s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.391s]
[INFO] ImageMap Output Format ............................ SUCCESS [13.896s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.718s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.469s]
[INFO] OGR parent ........................................ SUCCESS [0.390s]
[INFO] OGR WFS ........................................... SUCCESS [15.175s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.296s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:57.013s]
[INFO] OGR WPS ........................................... SUCCESS [19.702s]
[INFO] Excel Output Format ............................... SUCCESS [23.277s]
[INFO] Chart external graphics support ................... SUCCESS [0.453s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.794s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.562s]
[INFO] OWS request flow controller ....................... SUCCESS [19.999s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.657s]
[INFO] Web Processing Service GUI ........................ SUCCESS [48.829s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [29.802s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [-53.-380s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.609s]
[INFO] Core Monitor Extension ............................ SUCCESS [21.798s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [12.061s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.749s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [9.971s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.686s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [3.526s]
[INFO] XLST based WFS output format ...................... SUCCESS [2:50:29.405s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [33.391s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [24.094s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.530s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [44.095s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [17.711s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:03.525s]
[INFO] CSW UI Module ..................................... SUCCESS [16.680s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.280s]
[INFO] DXF WFS output format ............................. SUCCESS [22.374s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [-38.-796s]
[INFO] Printing Module ................................... SUCCESS [23.064s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.296s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [2:50:32.344s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [22.736s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [16.907s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.687s]
[INFO] Importer Core Module .............................. SUCCESS [1:12.551s]
[INFO] Importer REST Api Module .......................... SUCCESS [58.486s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [32.532s]
[INFO] Importer Web UI Module ............................ SUCCESS [6.334s]
[INFO] GeoServer Release Module .......................... SUCCESS [3.511s]
[INFO] BUILD SUCCESS
[INFO] Total time: 54:05.723s
[INFO] Finished at: Mon May 18 22:35:37 CEST 2015
[INFO] Final Memory: 110M/337M
Finished Calculation of disk usage of workspace in 5 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1707/changes&gt;
Changes:
[ksmith] GEOS-6874 Resolve conflation of catalog and native coverage names.
[...truncated 1943 lines...]
Caused by: java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.jdbc.Util.sqlException(Unknown Source)
  at org.hsqldb.jdbc.JDBCConnection.<init>(Unknown Source)
  at org.hsqldb.jdbc.JDBCDriver.getConnection(Unknown Source)
  at org.hsqldb.jdbc.JDBCDataSource.getConnection(Unknown Source)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.getConnection(DirectEpsgFactory.java:3210)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.prepareStatement(DirectEpsgFactory.java:726)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createBursaWolfParameters(DirectEpsgFactory.java:1407)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createDatum(DirectEpsgFactory.java:1584)
  ... 56 more
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.error.Error.error(Unknown Source)
  at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
  at org.hsqldb.DatabaseManager.newSession(Unknown Source)
  ... 64 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.108 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.093 sec
Results :
Tests in error:
  testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): Database failure while creating a 'Datum' object for code "6326".
Tests run: 658, Failures: 0, Errors: 1, Skipped: 2
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.330s]
[INFO] Core Platform Module .............................. SUCCESS [20.173s]
[INFO] Open Web Service Module ........................... SUCCESS [14.370s]
[INFO] Main Module ....................................... FAILURE [3:25.511s]
[INFO] Total time: 4:44.263s
[INFO] Finished at: Tue May 19 23:45:12 CEST 2015
[INFO] Final Memory: 45M/359M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 6 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/1708/changes&gt;
Changes:
[tbarsballe] [GEOS-7025] Stopped GeoServerDataDirectory.parsedStyle from creating files for nonexistant URLs
[...truncated 1129 lines...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.453 sec
20 mag 07:35:46 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.625 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.969 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.406 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.234 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.11 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.094 sec
Results :
Failed tests: testExpireByCreation(org.geoserver.security.auth.LRUAuthenticationCacheTest)
Tests run: 659, Failures: 1, Errors: 0, Skipped: 2
Finished Calculation of disk usage of workspace in 2 second
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.291s]
[INFO] Core Platform Module .............................. SUCCESS [21.091s]
[INFO] Open Web Service Module ........................... SUCCESS [14.483s]
[INFO] Main Module ....................................... FAILURE [3:25.774s]
[INFO] Total time: 4:41.457s
[INFO] Finished at: Wed May 20 07:35:54 CEST 2015
[INFO] Final Memory: 44M/316M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
channel stopped
