[Geoserver-devel] Build failed in Jenkins: geoserver-master #1879
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1879/&gt;
[...truncated 3147 lines...]
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Revert "[GEOS-7204] Integrated geofence odd path for db under Windows"
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.10.2015 @ 13:36:20 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Oct-2015 19:04
[INFO] [GitCommitIdMojo] build.build.time = 16.10.2015 @ 19:04:56 UTC
[INFO] [GitCommitIdMojo] build.branch = 4f5e0df1f640901a18a795beaf059a8889c566e4
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4f5e0df
[INFO] [GitCommitIdMojo] build.commit.id = 4f5e0df1f640901a18a795beaf059a8889c566e4
[INFO] [GitCommitIdMojo] build.commit.message.full = Revert "[GEOS-7204] Integrated geofence odd path for db under Windows"
This reverts commit 55ab5a568bd448fe9ae8f4ea5bc9cf413ceb7626.
Not really working on windows, must revisit
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/target/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0-eo ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0-eo ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/target/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo/2.9-SNAPSHOT/gs-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [13.091s]
[INFO] Core Platform Module .............................. SUCCESS [16.261s]
[INFO] Open Web Service Module ........................... FAILURE [6.645s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.443s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.372s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.243s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.204s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.635s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.984s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.760s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.737s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.460s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.793s]
[INFO] OGR parent ........................................ SUCCESS [0.213s]
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.176s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.271s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.469s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.290s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.285s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 42.301s (Wall Clock)
[INFO] Finished at: Fri Oct 16 19:04:56 UTC 2015
[INFO] Final Memory: 41M/262M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ows: Compilation failure
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1880/changes&gt;
Changes:
[tbarsballe] Patch to allow an ExternalGraphic to be used instead of the GetLegendGraphic service in the WMS GetCapabilities LegendURL
[...truncated 2956 lines...]
[INFO]
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-shapefile/15-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-shapefile/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-shapefile/15-SNAPSHOT/maven-metadata.xml
968/968 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-shapefile/15-SNAPSHOT/maven-metadata.xml (968 B at 0.6 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-imagemosaic-jdbc ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-imagemosaic-jdbc ---
[INFO] [GitCommitIdMojo] build.commit.message.short = Patch to allow an ExternalGraphic to be used instead of the GetLegendGraphic service in the WMS GetCapabilities LegendURL
[INFO] [GitCommitIdMojo] build.commit.time = 16.10.2015 @ 23:55:56 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Oct-2015 00:37
[INFO] [GitCommitIdMojo] build.build.time = 17.10.2015 @ 00:38:10 UTC
[INFO] [GitCommitIdMojo] build.branch = 83bb4d6ca9e1e20a196e81a419d82fafcc8e84d1
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 83bb4d6
[INFO] [GitCommitIdMojo] build.commit.id = 83bb4d6ca9e1e20a196e81a419d82fafcc8e84d1
[INFO] [GitCommitIdMojo] build.commit.message.full = Patch to allow an ExternalGraphic to be used instead of the GetLegendGraphic service in the WMS GetCapabilities LegendURL
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-imagemosaic-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-imagemosaic-jdbc ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-imagemosaic-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-imagemosaic-jdbc ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-imagemosaic-jdbc ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-imagemosaic-jdbc ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemosaic-jdbc ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-imagemosaic-jdbc ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemosaic-jdbc/2.9-SNAPSHOT/gs-imagemosaic-jdbc-2.9-SNAPSHOT-tests.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.891s]
[INFO] Core Platform Module .............................. SUCCESS [18.519s]
[INFO] Open Web Service Module ........................... FAILURE [6.841s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.296s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.232s]
[INFO] Community Space ................................... SUCCESS [0.516s]
[INFO] Application Schema Support ........................ SUCCESS [0.775s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.390s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.452s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [2.040s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.473s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.938s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.745s]
[INFO] OGR parent ........................................ SUCCESS [0.148s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.120s]
[INFO] Chart external graphics support ................... SUCCESS [1.336s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [4.102s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.080s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.112s]
[INFO] Total time: 41.196s (Wall Clock)
[INFO] Finished at: Sat Oct 17 00:38:11 UTC 2015
[INFO] Final Memory: 43M/236M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1881/changes&gt;
Changes:
[jody.garnett] Added the ability to compute bounds from the CRS bounds
[...truncated 3341 lines...]
[INFO]
[INFO] [INFO]
[INFO] Skipping GeoSearch Index Module
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO]
[INFO] Skipping GWC UI Module
[INFO] Skipping REST UI Module
[INFO]
[INFO]
[INFO] Skipping WCS UI Module
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO]
[INFO] Skipping Importer Core Module
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO] [INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO] Skipping OGR WPS
[INFO]
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.628s]
[INFO] Core Platform Module .............................. SUCCESS [17.208s]
[INFO] Open Web Service Module ........................... FAILURE [4.162s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.522s]
[INFO] GeoServer Extensions .............................. SUCCESS [1.023s]
[INFO] Community Space ................................... SUCCESS [0.187s]
[INFO] Application Schema Support ........................ SUCCESS [0.229s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.117s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.762s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.619s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.591s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.188s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.897s]
[INFO] OGR parent ........................................ SUCCESS [0.310s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.221s]
[INFO] Chart external graphics support ................... SUCCESS [0.694s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.731s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.324s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.205s]
[INFO] Total time: 35.584s (Wall Clock)
[INFO] Finished at: Sat Oct 17 00:47:59 UTC 2015
[INFO] Final Memory: 41M/288M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1882/&gt;
