[Geoserver-devel] Build failed in Jenkins: geoserver-master #1919
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1919/changes&gt;
Changes:
[jdeolive] GEOS-4239, upgrading jetty to version 9.2.
[jdeolive] GEOS-4239, updating assembly to accommodate jetty upgrade.
[jdeolive] Locking down slf4j to 1.7.10
[jdeolive] GEOS-4329, updated mac installer for jetty upgrade.
[jdeolive] GEOS-4329, updated win installer for jetty upgrade.
[...truncated 11611 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wcs2_0-eo ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1301 from jdeolive/jetty-upgrade
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 27.10.2015 @ 17:04:39 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 27-Oct-2015 17:07
[INFO] [GitCommitIdMojo] build.build.time = 27.10.2015 @ 17:22:38 UTC
[INFO] [GitCommitIdMojo] build.branch = 30f8c8a987c98e6952cf2d3cafe507ebbfe153b9
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Justin Deoliveira
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 30f8c8a
[INFO] [GitCommitIdMojo] build.commit.id = 30f8c8a987c98e6952cf2d3cafe507ebbfe153b9
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1301 from jdeolive/jetty-upgrade
Upgrade jetty to version 9.2 [GEOS-4239]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.9-SNAPSHOT/gs-web-wcs2_0-eo-2.9-SNAPSHOT-test-sources.jar
GeneralEnvelope[(40.0, 10.0), (70.0, 55.0)]
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 26.826 sec
Running org.geoserver.wcs2_0.WCSNetCDFTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.025 sec
Running org.geoserver.web.netcdf.NetCDFOutSettingsPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.131 sec
Running org.geoserver.web.netcdf.layer.NetCDFOutTabPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.699 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf-out ---
[INFO] [GitCommitIdMojo] build.build.time = 27.10.2015 @ 17:22:49 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-netcdf-out ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-netcdf-out ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/target/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf-out/2.9-SNAPSHOT/gs-netcdf-out-2.9-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.088s]
[INFO] Core Platform Module .............................. SUCCESS [20.547s]
[INFO] Open Web Service Module ........................... SUCCESS [22.213s]
[INFO] Main Module ....................................... SUCCESS [2:47.386s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.173s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.857s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2:13.796s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.361s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [43.565s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [56.220s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:58.981s]
[INFO] Web Feature Service Module ........................ FAILURE [3:20.479s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [43.111s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.223s]
[INFO] Core UI Module .................................... SUCCESS [2:25.144s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.640s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.104s]
[INFO] Printing Module ................................... SUCCESS [36.192s]
[INFO] Community Space ................................... SUCCESS [0.101s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.075s]
[INFO] Application Schema Support ........................ SUCCESS [0.127s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.607s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.436s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.084s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.074s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.475s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.526s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.243s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.515s]
[INFO] OGR parent ........................................ SUCCESS [0.081s]
[INFO] OGR CORE .......................................... SUCCESS [3.866s]
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.092s]
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.240s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.767s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.296s]
[INFO] OWS request flow controller ....................... SUCCESS [28.551s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.584s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [42.199s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.183s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.909s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.138s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:39.311s]
[INFO] CSW UI Module ..................................... SUCCESS [22.389s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.089s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.112s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [42.300s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.192s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SUCCESS [45.857s]
[INFO] NetCDF Coverage format ............................ SUCCESS [36.186s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [1:37.344s]
[INFO] BUILD FAILURE
[INFO] Total time: 15:45.428s (Wall Clock)
[INFO] Finished at: Tue Oct 27 17:22:49 UTC 2015
[INFO] Final Memory: 68M/245M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1920/&gt;
