[Geoserver-devel] Build failed in Jenkins: geoserver-master #1985
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1985/&gt;
[...truncated 122168 lines...]
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-colormap ---
[INFO] Compiling 6 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-colormap ---
[INFO] Copying 4 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-colormap ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-colormap ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-colormap ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-colormap ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-colormap >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-colormap ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1330 from ridethepenguin/fix-GEOS-7306
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.11.2015 @ 18:59:21 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Nov-2015 12:01
[INFO] [GitCommitIdMojo] build.build.time = 13.11.2015 @ 12:08:22 UTC
[INFO] [GitCommitIdMojo] build.branch = 2e19a4ebe7f9c3698ac3eecf002da76bff0aa506
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2e19a4e
[INFO] [GitCommitIdMojo] build.commit.id = 2e19a4ebe7f9c3698ac3eecf002da76bff0aa506
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1330 from ridethepenguin/fix-GEOS-7306
[GEOS-7306] Stored Queries don't work on App-Schema layers backed by DB
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-colormap <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-colormap ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-colormap >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-colormap <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-colormap ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-colormap ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.9-SNAPSHOT/gs-colormap-2.9-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.9-SNAPSHOT/gs-colormap-2.9-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.9-SNAPSHOT/gs-colormap-2.9-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.9-SNAPSHOT/gs-colormap-2.9-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/community/colormap/target/gs-colormap-2.9-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.9-SNAPSHOT/gs-colormap-2.9-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-colormap ---
Downloading: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/community/gs-colormap/2.9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.community:gs-colormap:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/snapshot/): boundless.artifactoryonline.com: Name or service not known
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.411s]
[INFO] Core Platform Module .............................. SUCCESS [5.280s]
[INFO] Open Web Service Module ........................... SUCCESS [7.934s]
[INFO] Main Module ....................................... SUCCESS [17.981s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.225s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [4.250s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4.765s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.291s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [4.918s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [4.534s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [4.784s]
[INFO] Web Feature Service Module ........................ SUCCESS [5.381s]
[INFO] Web Map Service Module ............................ SUCCESS [6.841s]
[INFO] KML support for GeoServer ......................... SUCCESS [4.494s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.189s]
[INFO] REST Support Module ............................... SUCCESS [4.279s]
[INFO] REST Configuration Service Module ................. SUCCESS [5.780s]
[INFO] GeoServer Web Modules ............................. SUCCESS [2.375s]
[INFO] Core UI Module .................................... SUCCESS [6.536s]
[INFO] WMS UI Module ..................................... SUCCESS [4.554s]
[INFO] GWC UI Module ..................................... SUCCESS [4.474s]
[INFO] WFS UI Module ..................................... SUCCESS [3.874s]
[INFO] Demoes Module ..................................... SUCCESS [4.532s]
[INFO] WCS UI Module ..................................... SUCCESS [4.159s]
[INFO] Security UI Modules ............................... SUCCESS [1.976s]
[INFO] Security UI Core Module ........................... SUCCESS [4.687s]
[INFO] Security UI JDBC Module ........................... SUCCESS [4.071s]
[INFO] Security UI LDAP Module ........................... SUCCESS [4.000s]
[INFO] REST UI Module .................................... SUCCESS [4.620s]
[INFO] GeoServer Web Application ......................... SUCCESS [28.524s]
[INFO] Community Space ................................... SUCCESS [2.986s]
[INFO] Authentication by unique url key .................. SUCCESS [11.728s]
[INFO] WorldWind Format Module ........................... SUCCESS [11.583s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [6.154s]
[INFO] SpatiaLite Extension .............................. SUCCESS [9.640s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [14.336s]
[INFO] Simple Feature Service ............................ SUCCESS [10.445s]
[INFO] Aggregating Data Store ............................ SUCCESS [6.683s]
[INFO] GeoServer Extensions .............................. SUCCESS [2.230s]
[INFO] Web Processing Service parent ..................... SUCCESS [2.012s]
[INFO] Web Processing Service Module ..................... SUCCESS [8.058s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [2.125s]
[INFO] Core Scripting Extension .......................... SUCCESS [11.442s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [10.636s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [9.833s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [41.222s]
[INFO] H2 DataStore Extension ............................ SUCCESS [3.878s]
[INFO] Python Scripting Extension ........................ SUCCESS [15.293s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [13.763s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [9.797s]
[INFO] WMS-EO ............................................ SUCCESS [13.195s]
[INFO] ColorMap .......................................... FAILURE [7.304s]
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] Resumable REST Upload module ...................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] GeoFence Server ................................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GWC Distributed Caching Plugin .................... SKIPPED
[INFO] GeoWebCache S3 .................................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] GDAL translate parent ............................. SKIPPED
[INFO] GDAL translate WCS ................................ SKIPPED
[INFO] GDAL translate WPS ................................ SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:52.498s
[INFO] Finished at: Fri Nov 13 12:08:23 UTC 2015
[INFO] Final Memory: 98M/339M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-colormap: Failed to retrieve remote metadata org.geoserver.community:gs-colormap:2.9-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.community:gs-colormap:2.9-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/snapshot/): boundless.artifactoryonline.com: Name or service not known: Unknown host boundless.artifactoryonline.com: Name or service not known -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-colormap
See <http://ares.opengeo.org/jenkins/job/geoserver-master/1986/&gt;
