See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/2297/>
[...truncated 6924 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wms.web.data.StylePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.059 sec
Running org.geoserver.wms.web.data.WMSAdminPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.011 sec
Running org.geoserver.wms.web.data.publish.WMSLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.231 sec
Results :
Failed tests: testLegend(org.geoserver.wms.web.data.StyleNewPageTest): expected:<StylePage> but was:<GeoServerErrorPage>
Tests run: 30, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.743s]
[INFO] Core Platform Module .............................. SUCCESS [20.577s]
[INFO] Open Web Service Module ........................... SUCCESS [14.274s]
[INFO] Main Module ....................................... SUCCESS [3:30.461s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.076s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [32.484s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [13.447s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.368s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:04.194s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:11.183s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:00.027s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:04.298s]
[INFO] Web Map Service Module ............................ SUCCESS [3:55.872s]
[INFO] KML support for GeoServer ......................... SUCCESS [52.512s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:45.901s]
[INFO] REST Support Module ............................... SUCCESS [25.849s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:11.789s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.390s]
[INFO] Core UI Module .................................... SUCCESS [1:46.642s]
[INFO] WMS UI Module ..................................... FAILURE [36.926s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 24:17.338s
[INFO] Finished at: Mon Nov 02 10:50:18 CET 2015
[INFO] Final Memory: 67M/535M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/ws/src/web/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-wms
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 3 second
