[Geoserver-devel] Build failed in Jenkins: geoserver-master #2505
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2505/changes&gt;
Changes:
[ben] [GEOT-5428] Support NetCDF rotated pole projection
[...truncated 2808 lines...]
[INFO]
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO] Skipping GWC UI Module
[INFO]
[INFO]
[INFO] Skipping REST UI Module
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO]
[INFO] Skipping OGR WPS
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.611 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.228 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.547 s]
[INFO] Main Module ........................................ FAILURE [02:12 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.072 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.035 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.052 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.143 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.787 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.266 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.264 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.463 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.692 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.863 s]
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.135 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.034 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 02:52 min (Wall Clock)
[INFO] Finished at: 2016-06-09T19:14:47+00:00
[INFO] Final Memory: 121M/392M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2506/&gt;
