[Geoserver-devel] Build failed in Jenkins: geoserver-master #324
See <http://ares.opengeo.org/jenkins/job/geoserver-master/324/changes&gt;
Changes:
[Ben.Caradoc-Davies] [GEOS-6354] Polar stereographic projections broken
[...truncated 13135 lines...]
24 Feb 11:01:16 WARN [geoserver.ows] - OWS20SEH: handling org.geoserver.wcs2_0.exception.WCS20Exception: Could not locate coverage notThereBaby
HTTPcode:404
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Mon Feb 24 11:01:14 UTC 2014]; root of context hierarchy
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.601 sec
Running org.geoserver.wcs2_0.kvp.InterpolationKvpParserTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.wcs2_0.kvp.RangeSubsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.wcs2_0.kvp.RangeSubsetKvpTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Mon Feb 24 11:01:16 UTC 2014]; root of context hierarchy
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs20Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs111Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Bean 'extensions' of type [class org.geoserver.platform.GeoServerExtensions] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Bean 'dataDirectory' of type [class org.geoserver.config.GeoServerDataDirectory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Feb 11:01:16 INFO [test.GeoServerTestApplicationContext] - Bean 'authenticationManager' of type [class org.geoserver.security.GeoServerSecurityManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
24 Feb 11:01:16 INFO [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/./target/default1856687303982720130data&gt;
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'Streams'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'MapNeatline'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'Forests'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'Bridges'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'RoadSegments'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'raster'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'BasicPolygons'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'NamedPlaces'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'Lakes'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'DividedRoutes'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'Default'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'Buildings'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded style 'Ponds'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded default workspace gs
24 Feb 11:01:16 INFO [org.geoserver] - Loaded workspace 'sf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded workspace 'wcs'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded workspace 'cite'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded workspace 'cgf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded workspace 'cdf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded workspace 'gs'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded data store 'sf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded feature type 'sf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'GenericEntity'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'PrimitiveGeoFeature'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'AggregateGeoFeature'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage store 'RotatedCad'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage 'RotatedCad'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'RotatedCad'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage store 'World'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage 'World'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'World'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage store 'multiband'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage 'multiband'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'multiband'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage store 'BlueMarble'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage 'BlueMarble'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'BlueMarble'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage store 'DEM'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage 'DEM'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'DEM'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded data store 'cite'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded feature type 'cite'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'RoadSegments'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Geometryless'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Forests'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'DividedRoutes'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'NamedPlaces'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Lakes'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Bridges'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Buildings'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Ponds'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'BasicPolygons'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'MapNeatline'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Streams'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded data store 'cgf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded feature type 'cgf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Polygons'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'MPolygons'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'MPoints'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Lines'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Points'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'MLines'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage store 'usa'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded coverage 'usa'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'usa'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded data store 'cdf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded feature type 'cdf'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Nulls'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Inserts'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Locks'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Fifteen'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Other'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Deletes'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Updates'
24 Feb 11:01:16 INFO [org.geoserver] - Loaded layer 'Seven'
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.052s]
[INFO] Core Platform Module .............................. SUCCESS [4.811s]
[INFO] Open Web Service Module ........................... SUCCESS [12.819s]
[INFO] Main Module ....................................... SUCCESS [2:27.617s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.381s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:06.569s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [42.234s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.203s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.444s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.439s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [3:37.271s]
[INFO] Web Map Service Module ............................ FAILURE [4:34.357s]
[INFO] REST Support Module ............................... SUCCESS [35.863s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.643s]
[INFO] Core UI Module .................................... SUCCESS [2:02.653s]
[INFO] WFS UI Module ..................................... SUCCESS [37.439s]
[INFO] Security UI Modules ............................... SUCCESS [0.434s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.312s]
[INFO] Printing Module ................................... SUCCESS [20.441s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.343s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.259s]
[INFO] Application Schema Support ........................ SUCCESS [0.338s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.532s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [26.133s]
[INFO] H2 DataStore Extension ............................ SUCCESS [20.271s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.538s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.834s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.619s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.648s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.584s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [2.457s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [30.381s]
[INFO] Excel Output Format ............................... SUCCESS [34.454s]
[INFO] Validation Module ................................. SUCCESS [2.187s]
[INFO] Chart external graphics support ................... SUCCESS [1.529s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.580s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.031s]
[INFO] OWS request flow controller ....................... SUCCESS [19.943s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.345s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [42.912s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.410s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [33.339s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.650s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.989s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.273s]
[INFO] DXF output format ................................. SUCCESS [31.713s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.293s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 14:01.327s (Wall Clock)
[INFO] Finished at: Mon Feb 24 11:01:16 UTC 2014
24 Feb 11:01:16 INFO [org.geoserver] - Loaded service 'WCSInfoImpl-674dd9e5:144638d96d3:-7c7e', enabled
24 Feb 11:01:16 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
24 Feb 11:01:16 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
24 Feb 11:01:16 INFO [org.geoserver] - GeoServer configuration lock is enabled
24 Feb 11:01:16 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
24 Feb 11:01:16 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
24 Feb 11:01:16 WARN [geoserver.security] - Strong cryptography is NOT available
Download and install of policy files recommended
from http://www.oracle.com/technetwork/java/javase/downloads/jce-6-download-429243.html
24 Feb 11:01:17 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
24 Feb 11:01:17 INFO [geoserver.security] - End encrypting configuration passwords
[INFO] Final Memory: 54M/180M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-master/325/&gt;
