See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3580/changes>
Changes:
[afabiani] - enable oauth2 community release dep
[...truncated 24679 lines...]
[INFO] Building WMTS Multi Dimensional 2.10-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-wmts-multi-dimensional ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wmts-multi-dimensional ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wmts-multi-dimensional ---
[INFO] Compiling 18 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wmts-multi-dimensional ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wmts-multi-dimensional ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wmts-multi-dimensional ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wmts-multi-dimensional ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wmts-multi-dimensional ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wmts-multi-dimensional ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wmts-multi-dimensional ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wmts-multi-dimensional ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/wmts-multi-dimensional/target/gs-wmts-multi-dimensional-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-wmts-multi-dimensional ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 25.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341.jar (56 KB at 386.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341.pom (3 KB at 20.7 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/maven-metadata.xml (388 B at 7.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 17.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/maven-metadata.xml (342 B at 4.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341-tests.jar (24 KB at 240.8 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 18.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341-sources.jar (29 KB at 290.6 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341-test-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-wmts-multi-dimensional/2.10-SNAPSHOT/gs-wmts-multi-dimensional-2.10-20161007.100832-341-test-sources.jar (14 KB at 136.1 KB/sec)
[INFO]
[INFO] Building GeoServer Community Release Module 2.10-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/gs-sec-oauth2-google-2.10-SNAPSHOT.pom
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/gs-sec-oauth2-google-2.10-SNAPSHOT.pom
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/gs-sec-oauth2-google-2.10-SNAPSHOT.pom
[WARNING] The POM for org.geoserver.community:gs-sec-oauth2-google:jar:2.10-SNAPSHOT is missing, no dependency information available
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/gs-sec-oauth2-google-2.10-SNAPSHOT.jar
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/gs-sec-oauth2-google-2.10-SNAPSHOT.jar
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/community/gs-sec-oauth2-google/2.10-SNAPSHOT/gs-sec-oauth2-google-2.10-SNAPSHOT.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.739 s]
[INFO] Core Platform Module ............................... SUCCESS [ 3.076 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.174 s]
[INFO] Main Module ........................................ SUCCESS [ 12.617 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.864 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.205 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.290 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.129 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.728 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.656 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.732 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.882 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.693 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.655 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 8.900 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.144 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.088 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.620 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.425 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.776 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.602 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.087 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.631 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.451 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.625 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.794 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.642 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.407 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.111 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 35.325 s]
[INFO] Community Space .................................... SUCCESS [ 1.897 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.138 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.191 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.319 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.740 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.573 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.583 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.572 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.485 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 1.865 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.201 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.619 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.861 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.939 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.077 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.404 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.176 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.732 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.906 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.667 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 5.981 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.008 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.309 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.708 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.604 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.332 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.696 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.557 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 6.395 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 22.787 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.419 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 7.576 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.872 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.712 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.214 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.637 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.284 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.269 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.428 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.676 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.786 s]
[INFO] Importer Core Module ............................... SUCCESS [ 3.126 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.031 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.418 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.467 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.194 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.441 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.734 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.891 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.573 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.399 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.323 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.338 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.365 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.510 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 13.077 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.640 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 7.433 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.729 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.558 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.828 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.714 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 1.583 s]
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer Security Community Modules ............... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:17 min
[INFO] Finished at: 2016-10-07T10:08:35+00:00
[INFO] Final Memory: 183M/429M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.10-SNAPSHOT: Could not find artifact org.geoserver.community:gs-sec-oauth2-google:jar:2.10-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
