[Geoserver-devel] Build failed in Jenkins: geoserver-master #4128
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4128/changes&gt;
Changes:
[jd] Update geogig plugin to work with additional parameter options.
[...truncated 185447 lines...]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 12.345 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 26.809 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 8.317 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.323 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.210 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.380 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.579 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.876 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.677 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.035 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 22.889 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.304 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.792 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.793 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.446 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.537 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 10.891 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.479 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.431 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.633 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.787 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.529 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.185 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.049 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.805 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 5.436 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.695 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.439 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.551 s]
[INFO] Solr Module ........................................ SUCCESS [ 7.344 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.587 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.830 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.164 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.992 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.796 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.176 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.184 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.644 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.778 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.416 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.035 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.315 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.432 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.530 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 6.296 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 19.754 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.066 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 7.305 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.327 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.415 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.198 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.675 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 38.188 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.583 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.506 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.020 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.650 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.291 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.496 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.220 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 5.153 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.064 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.047 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 8.458 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.155 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.121 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:48 min (Wall Clock)
[INFO] Finished at: 2017-03-23T21:59:05+00:00
[INFO] Final Memory: 141M/724M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java&gt;:\[15,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java&gt;:\[21,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java&gt;:\[17,7\] error: constructor AbstractWebAPICommand in class AbstractWebAPICommand cannot be applied to given types;
[ERROR] actual and formal argument lists differ in length
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java&gt;:\[19,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java&gt;:\[26,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java&gt;:\[32,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java&gt;:\[34,45\] error: no suitable method found for runCommand(Variant,Request,MediaType)
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4129/&gt;
[...truncated 185435 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/test-classes&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.472 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 20.389 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 8.630 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 17.380 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 15.921 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.181 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.661 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 8.086 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.862 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.167 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 22.547 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 11.278 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.565 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.093 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.929 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.187 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 10.398 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.179 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.355 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.573 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.614 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.388 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.072 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.812 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.804 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 7.168 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.243 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.808 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.508 s]
[INFO] Solr Module ........................................ SUCCESS [ 8.898 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.375 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.751 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.292 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.536 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.881 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.066 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.896 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.975 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.655 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.116 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.053 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 9.021 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.361 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.404 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.711 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 22.081 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.042 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.445 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 7.723 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.367 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 5.117 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.927 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 23.688 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.336 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.472 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.576 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 5.152 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.332 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.248 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.307 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 4.677 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.359 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.041 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 7.547 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 4.834 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.615 s]
[INFO] Total time: 03:51 min (Wall Clock)
[INFO] Finished at: 2017-03-24T01:38:39+00:00
[INFO] Final Memory: 141M/674M
[WARNING] The requested profile "\!geogig" could not be activated because it does not exist.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4130/changes&gt;
