[Geoserver-devel] Build failed in Jenkins: geoserver-master #4299
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4299/&gt;
[...truncated 187492 lines...]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/classes&gt;
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/ogc/org.w3.xlink/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/ogc/org.w3.xlink/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/org.w3.xlink/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/ogc/org.w3.xlink/15-SNAPSHOT/maven-metadata.xml (967 B at 3.7 KB/sec)
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-grid/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-grid/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-grid/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-grid/15-SNAPSHOT/maven-metadata.xml (958 B at 2.7 KB/sec)
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-geobuf/15-SNAPSHOT/maven-metadata.xml (960 B at 4.3 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-jni/15-SNAPSHOT/maven-metadata.xml (961 B at 4.2 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr/15-SNAPSHOT/maven-metadata.xml (572 B at 2.7 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-ogr-core/15-SNAPSHOT/maven-metadata.xml (2 KB at 4.0 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-script-groovy ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-script-groovy ---
[INFO]
[INFO] --- groovy-eclipse-compiler:2.9.2-01:add-groovy-build-paths (default-add-groovy-build-paths) @ gs-script-groovy ---
[INFO] Adding /src/main/groovy to the list of source folders
[INFO] Adding /src/test/groovy to the list of test source folders
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-script-groovy ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-script-groovy ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ gs-script-groovy ---
[INFO] Changes detected - recompiling the module!
[INFO] Using Groovy-Eclipse compiler to compile both Java and Groovy files
[INFO] Found location </var/lib/jenkins/.m2/repository/org/codehaus/groovy/groovy-eclipse-batch/2.3.7-01/groovy-eclipse-batch-2.3.7-01.jar> for className <org.eclipse.jdt.internal.compiler.batch.Main>
[INFO] no javaAgentClass seems to be set
[INFO] Compiling in a forked process using /var/lib/jenkins/.m2/repository/org/codehaus/groovy/groovy-eclipse-batch/2.3.7-01/groovy-eclipse-batch-2.3.7-01.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-script-groovy ---
[INFO] Copying 6 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.1:testCompile (default-testCompile) @ gs-script-groovy ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-script-groovy ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (default) @ gs-script-groovy ---
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO] --- maven-install-plugin:2.5.2:install (default-install) @ gs-script-groovy ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-groovy/2.12-SNAPSHOT/gs-script-groovy-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-groovy/2.12-SNAPSHOT/gs-script-groovy-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-groovy/2.12-SNAPSHOT/gs-script-groovy-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-groovy/2.12-SNAPSHOT/gs-script-groovy-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/script/groovy/target/gs-script-groovy-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-groovy/2.12-SNAPSHOT/gs-script-groovy-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [01:39 min]
[INFO] Authentication by unique url key ................... SUCCESS [03:27 min]
[INFO] WorldWind Format Module ............................ SUCCESS [ 14.791 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 32.847 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.037 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 13.186 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 51.569 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.180 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.146 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.505 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [03:19 min]
[INFO] Python Scripting Extension ......................... SUCCESS [01:02 min]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 17.401 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 6.824 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.570 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.688 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [01:02 min]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 13.486 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 6.134 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 7.456 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.395 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.890 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 18.265 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.711 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.814 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.379 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 9.327 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 13.117 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 11.092 s]
[INFO] Solr Module ........................................ SUCCESS [ 12.651 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.224 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 31.981 s]
[INFO] GeoFence Server .................................... SUCCESS [ 21.303 s]
[INFO] REST SLD service ................................... SUCCESS [ 17.766 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 7.481 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 33.955 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 10.213 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 10.085 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 6.682 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 13.592 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.062 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 14.097 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.072 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.713 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 12.288 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.057 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 8.518 s]
[INFO] GeoServer Config Backup And Restore REST Module .... FAILURE [ 2.531 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.789 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.777 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.424 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [05:06 min]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 7.898 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 7.931 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 8.618 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 6.210 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.522 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.447 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.234 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 6.530 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.419 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.094 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 8.423 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 4.379 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 8.796 s]
[INFO] BUILD FAILURE
[INFO] Total time: 13:57 min (Wall Clock)
[INFO] Finished at: 2017-03-31T14:15:33+00:00
[INFO] Final Memory: 137M/586M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-backup-restore-rest: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreStreamResource.java&gt;:\[104,44\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-backup-restore-rest
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4300/&gt;
[...truncated 181466 lines...]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.137 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
Mar 31, 2017 2:58:38 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [492 msecs]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.104 sec
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [01:42 min]
[INFO] Core Platform Module ............................... SUCCESS [ 12.700 s]
[INFO] Open Web Service Module ............................ SUCCESS [03:10 min]
[INFO] Main Module ........................................ SUCCESS [07:06 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.762 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:13 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:48 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.408 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 58.818 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 32.278 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.749 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:37 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:49 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.187 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:32 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.908 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:24 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.040 s]
[INFO] Core UI Module ..................................... SUCCESS [01:11 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 36.608 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 36.169 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 47.046 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 14.982 s]
[INFO] Demos Module ....................................... SUCCESS [ 23.335 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.801 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:17 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:41 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:41 min]
[INFO] REST UI Module ..................................... SUCCESS [ 14.413 s]
[INFO] Printing Module .................................... SUCCESS [ 15.549 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.604 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:06 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 14.123 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 39.516 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.378 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [01:04 min]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 33.490 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 15.919 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 15.961 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 12.234 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 40.102 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 15.878 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.041 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.982 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.354 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.043 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:58 min]
[INFO] Excel Output Format ................................ SUCCESS [ 16.398 s]
[INFO] Chart external graphics support .................... SUCCESS [ 31.854 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 16.656 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 29.846 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.190 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 26.266 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 5.189 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.218 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 11.033 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 9.091 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.207 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 23.416 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 34.303 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.041 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 17.440 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.394 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.659 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 15.359 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.019 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 16.061 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.003 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 16.737 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 12.165 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.558 s]
[INFO] Importer Core Module ............................... SUCCESS [ 47.821 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 40.971 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.475 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 19.446 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 32.629 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.596 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 48.710 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.874 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 11.665 s]
[INFO] Total time: 33:23 min (Wall Clock)
[INFO] Finished at: 2017-03-31T14:58:42+00:00
[INFO] Final Memory: 121M/630M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4301/&gt;
[...truncated 187462 lines...]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer notification event system 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-notification ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-notification ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-notification ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-notification ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-notification ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Community Space .................................... SUCCESS [ 9.896 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 12.790 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.611 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.454 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.390 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.487 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.481 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.718 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 7.606 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.707 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [01:01 min]
[INFO] Python Scripting Extension ......................... SUCCESS [ 42.519 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 8.174 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 6.529 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.104 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.346 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 11.073 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 15.860 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.406 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.631 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.770 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.675 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.374 s]
[INFO] DownloadProcess .................................... SUCCESS [ 7.810 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.792 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.800 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.790 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 15.783 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 9.709 s]
[INFO] Solr Module ........................................ SUCCESS [ 8.519 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.226 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.280 s]
[INFO] GeoFence Server .................................... FAILURE [ 35.113 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.908 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.050 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.154 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.720 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 15.559 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.578 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 7.152 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.030 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 28.722 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.945 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.715 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 7.662 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.042 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 8.781 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 7.748 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.112 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 4.948 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.185 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 21.579 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.055 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 6.823 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 6.758 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 5.494 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.542 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.314 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 8.017 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 4.428 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.408 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.015 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 10.178 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 6.065 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.619 s]
[INFO] Total time: 04:47 min (Wall Clock)
[INFO] Finished at: 2017-03-31T15:26:26+00:00
[INFO] Final Memory: 141M/611M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geofence-server: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java&gt;:\[35,29\] error: cannot access GeoServerExtensions
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4302/&gt;
