[Geoserver-devel] Build failed in Jenkins: geoserver-master #435
See <http://ares.opengeo.org/jenkins/job/geoserver-master/435/changes&gt;
Changes:
[andrea.aime] [GEOS-6451] Allow direct raster rendering path to work against rendering transformations as well
[...truncated 3265 lines...]
  at org.eclipse.xsd.impl.XSDNamedComponentImpl.patch(XSDNamedComponentImpl.java:785)
  at org.eclipse.xsd.impl.XSDTypeDefinitionImpl.patch(XSDTypeDefinitionImpl.java:247)
  at org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.patch(XSDComplexTypeDefinitionImpl.java:1055)
  at org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcreteComponentImpl.java:535)
  at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java:1602)
  at org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchemaImpl.java:2463)
  at org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDConcreteComponentImpl.java:1154)
  at org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSchemaImpl.java:893)
  at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:763)
  at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:796)
  at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
  at org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchemaDirectiveImpl.java:363)
  at org.eclipse.xsd.impl.XSDIncludeImpl.patch(XSDIncludeImpl.java:243)
  at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
  at org.geotools.xml.Schemas.parse(Schemas.java:313)
  at org.geotools.xml.Schemas.parse(Schemas.java:285)
  at org.geotools.xml.Schemas.parse(Schemas.java:247)
  at org.geotools.xml.XSD.buildSchema(XSD.java:281)
  at org.geotools.xml.XSD.getSchema(XSD.java:232)
  at org.geotools.xml.Configuration.schema(Configuration.java:470)
  at org.geotools.xml.Encoder.<init>(Encoder.java:210)
  at org.geoserver.ows.XmlObjectEncodingResponse.write(XmlObjectEncodingResponse.java:46)
  ... 26 more
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.081 sec
Running org.geoserver.ows.kvp.ElevationKvpParserTest
Apr 16, 2014 10:34:49 AM org.geoserver.ows.kvp.ElevationKvpParser parse
INFO: Lmiting number of elements in this periodo to 100
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.075 sec
Running org.geoserver.ows.kvp.FormatOptionsKvpParserTest
Apr 16, 2014 10:34:49 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup occured, but ApplicationContext is unset.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Apr 16, 2014 10:34:49 AM org.geoserver.ows.kvp.TimeKvpParser parse
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.142 sec
Running org.geoserver.ows.util.CaseInsensitiveMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.094 sec
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.004 sec <<< FAILURE!
initializationError(org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest) Time elapsed: 1 sec <<< ERROR!
java.lang.NoClassDefFoundError: org/geotools/xml/Binding
  at java.lang.Class.getDeclaredMethods0(Native Method)
  at java.lang.Class.privateGetDeclaredMethods(Class.java:2531)
  at java.lang.Class.getDeclaredMethods(Class.java:1855)
  at org.junit.internal.MethodSorter.getDeclaredMethods(MethodSorter.java:54)
  at junit.framework.TestSuite.addTestsFromTestCase(TestSuite.java:152)
  at junit.framework.TestSuite.<init>(TestSuite.java:132)
  at org.junit.internal.runners.JUnit38ClassRunner.<init>(JUnit38ClassRunner.java:72)
  at org.junit.internal.builders.JUnit3Builder.runnerForClass(JUnit3Builder.java:11)
  at org.junit.runners.model.RunnerBuilder.safeRunnerForClass(RunnerBuilder.java:59)
  at org.junit.internal.builders.AllDefaultPossibilitiesBuilder.runnerForClass(AllDefaultPossibilitiesBuilder.java:26)
  at org.junit.internal.requests.ClassRequest.getRunner(ClassRequest.java:26)
  at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:250)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.lang.ClassNotFoundException: org.geotools.xml.Binding
  at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
  at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
  ... 24 more
Results :
Tests in error:
  testHandleServiceExceptionEncoding(org.geoserver.ows.DefaultServiceExceptionHandlerTest)
  testHandleServiceExceptionCauses(org.geoserver.ows.DefaultServiceExceptionHandlerTest)
  testHandleServiceExceptionEncodingMore(org.geoserver.ows.DefaultServiceExceptionHandlerTest)
  testHandleServiceException(org.geoserver.ows.DefaultServiceExceptionHandlerTest)
  testErrorSavedOnRequestOnGenericException(org.geoserver.ows.DispatcherTest)
  testEncode(org.geoserver.ows.XmlObjectEncodingResponseTest)
  initializationError(org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest): org/geotools/xml/Binding
Tests run: 55, Failures: 0, Errors: 7, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.576s]
[INFO] Core Platform Module .............................. SUCCESS [26.875s]
[INFO] Open Web Service Module ........................... FAILURE [34.167s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [2.334s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.467s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.304s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.562s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.933s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.757s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.931s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.937s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.000s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.120s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.490s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.251s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.629s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.647s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.548s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:17.846s (Wall Clock)
[INFO] Finished at: Wed Apr 16 10:34:49 UTC 2014
[INFO] Final Memory: 36M/387M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ows: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.opengeo.org/jenkins/job/geoserver-master/436/&gt;
