[Geoserver-devel] Build failed in Jenkins: geoserver-master #438
See <http://ares.opengeo.org/jenkins/job/geoserver-master/438/changes&gt;
Changes:
[daniele.romagnoli] GEOS-6455: Updating GeoServerInitStartupListener
[...truncated 8494 lines...]
[INFO] Skipping Catalog Services for the Web interfaces
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping ogr2ogr Output Format
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping DXF output format
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-teradata ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-teradata ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-teradata ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-teradata ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/target/gs-teradata-2.6-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-teradata ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/target/gs-teradata-2.6-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-teradata >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-teradata ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #567 from dromagnoli/GEOS-6455
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.04.2014 @ 10:25:59 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Apr-2014 10:28
[INFO] [GitCommitIdMojo] build.build.time = 17.04.2014 @ 10:39:39 UTC
[INFO] [GitCommitIdMojo] build.branch = 08cb5b0c68c9a051f9155e80ecf4ca9789afc8ac
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 08cb5b0
[INFO] [GitCommitIdMojo] build.commit.id = 08cb5b0c68c9a051f9155e80ecf4ca9789afc8ac
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #567 from dromagnoli/GEOS-6455
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-teradata <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-teradata ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/target/gs-teradata-2.6-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-teradata >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-teradata <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-teradata ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-teradata ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/target/gs-teradata-2.6-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-teradata/2.6-SNAPSHOT/gs-teradata-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-teradata/2.6-SNAPSHOT/gs-teradata-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/target/gs-teradata-2.6-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-teradata/2.6-SNAPSHOT/gs-teradata-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/teradata/target/gs-teradata-2.6-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-teradata/2.6-SNAPSHOT/gs-teradata-2.6-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.267s]
[INFO] Core Platform Module .............................. SUCCESS [13.202s]
[INFO] Open Web Service Module ........................... SUCCESS [17.002s]
[INFO] Main Module ....................................... SUCCESS [2:51.882s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.883s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:21.052s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [46.946s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.874s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.972s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.340s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [4:36.253s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [45.236s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.483s]
[INFO] Core UI Module .................................... SUCCESS [2:34.106s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.371s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.302s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.465s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.181s]
[INFO] Printing Module ................................... FAILURE [55.668s]
[INFO] Application Schema Support ........................ SUCCESS [0.177s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.254s]
[INFO] H2 DataStore Extension ............................ SUCCESS [17.166s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.260s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.626s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.354s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.667s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.906s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.476s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [3.353s]
[INFO] Chart external graphics support ................... SUCCESS [2.066s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.609s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.853s]
[INFO] OWS request flow controller ....................... SUCCESS [25.149s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.223s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.788s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.433s]
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [1.312s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.378s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:08.303s (Wall Clock)
[INFO] Finished at: Thu Apr 17 10:39:39 UTC 2014
[INFO] Final Memory: 49M/363M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-printing: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/printing/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-printing
See <http://ares.opengeo.org/jenkins/job/geoserver-master/439/&gt;
