[Geoserver-devel] Build failed in Jenkins: geoserver-master #440
See <http://ares.opengeo.org/jenkins/job/geoserver-master/440/&gt;
[...truncated 22539 lines...]
Tests run: 19, Failures: 4, Errors: 10, Skipped: 1
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping GWC UI Module
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<html xmlns="http://www.w3.org/1999/xhtml&quot; lang="en" xml:lang="en">
<head>
    <title>GeoServer Configuration</title>
    <meta content="NOINDEX, NOFOLLOW" name="ROBOTS"/>
</head>
<body>
<h2>About:</h2>
<ul>
  <li>
        <h3>Resource name: GeoServer</h3>
      <ul>
        <li>
            <b>Build-Timestamp</b> : 18-Apr-2014 09:11</li>
        <li>
            <b>Git-Revision</b> : 08cb5b0c68c9a051f9155e80ecf4ca9789afc8ac</li>
        <li>
            <b>Version</b> : 2.6-SNAPSHOT</li>
    </ul>
  </li>
  <li>
        <h3>Resource name: GeoTools</h3>
      <ul>
        <li>
            <b>Build-Timestamp</b> : 18-Apr-2014 08:54</li>
        <li>
            <b>Git-Revision</b> : 694822e07824705b99730e9cc432838e501fa400</li>
        <li>
            <b>Version</b> : 12-SNAPSHOT</li>
    </ul>
  </li>
</ul>
</body>
</html>
<head>
</head>
<body>
<h2>About:</h2>
<ul>
  <li>
        <h3>Resource name: freemarker-2.3.18</h3>
      <ul>
        <li>
            <b>Manifest-Version</b> : 1.0</li>
        <li>
            <b>Specification-Title</b> : FreeMarker</li>
        <li>
            <b>Main-Class</b> : freemarker.core.CommandLine</li>
        <li>
            <b>Specification-Version</b> : 2.3.18</li>
        <li>
            <b>Ant-Version</b> : Apache Ant 1.8.1</li>
        <li>
            <b>Specification-Vendor</b> : Visigoth Software Society</li>
        <li>
            <b>Extension-name</b> : FreeMarker</li>
        <li>
            <b>Implementation-Version</b> : 2.3.18</li>
        <li>
            <b>Implementation-Vendor</b> : Visigoth Software Society</li>
        <li>
            <b>Implementation-Title</b> : VSS Java FreeMarker</li>
        <li>
            <b>Created-By</b> : 1.6.0_22-b04 (Sun Microsystems Inc.)</li>
    </ul>
  </li>
</ul>
</body>
</html>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.077 sec
Running org.geoserver.rest.FontListTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.358 sec
Running org.geoserver.rest.GlobalContactTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.313s]
[INFO] Core Platform Module .............................. SUCCESS [16.211s]
[INFO] Open Web Service Module ........................... SUCCESS [16.437s]
[INFO] Main Module ....................................... SUCCESS [2:53.938s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.901s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:14.567s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [49.015s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.445s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:13.555s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.029s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:59.040s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:25.500s]
[INFO] Web Map Service Module ............................ SUCCESS [4:55.097s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.027s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:59.958s]
[INFO] REST Support Module ............................... SUCCESS [45.916s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.359s]
[INFO] Core UI Module .................................... SUCCESS [2:28.238s]
[INFO] WMS UI Module ..................................... SUCCESS [1:08.272s]
[INFO] WFS UI Module ..................................... SUCCESS [44.388s]
[INFO] Demoes Module ..................................... FAILURE [1:46.629s]
[INFO] Security UI Modules ............................... SUCCESS [0.299s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.251s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.590s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.166s]
[INFO] Printing Module ................................... SUCCESS [43.771s]
[INFO] Application Schema Support ........................ SUCCESS [0.196s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.922s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.637s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.522s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.193s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.970s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.447s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.466s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.814s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.560s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [39.126s]
[INFO] Excel Output Format ............................... SUCCESS [42.569s]
[INFO] Validation Module ................................. SUCCESS [3.420s]
[INFO] Chart external graphics support ................... SUCCESS [1.970s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.672s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.399s]
[INFO] OWS request flow controller ....................... SUCCESS [28.376s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.367s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:23.963s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.510s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.233s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.329s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [47.346s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.548s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [30.413s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.687s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.477s]
[INFO] DXF output format ................................. SUCCESS [37.654s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.185s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 24:47.722s (Wall Clock)
[INFO] Finished at: Fri Apr 18 09:36:18 UTC 2014
[INFO] Final Memory: 61M/334M
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.838 sec
Running org.geoserver.rest.GlobalSettingsTest
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-demo: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/demo/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-demo
See <http://ares.opengeo.org/jenkins/job/geoserver-master/441/&gt;
[...truncated 8355 lines...]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO] Skipping Catalog Services for the Web interfaces
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping ogr2ogr Output Format
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping DXF output format
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.853 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-h2 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-h2 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-h2 >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-h2 ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #567 from dromagnoli/GEOS-6455
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.04.2014 @ 10:25:59 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Apr-2014 10:04
[INFO] [GitCommitIdMojo] build.build.time = 18.04.2014 @ 10:16:35 UTC
[INFO] [GitCommitIdMojo] build.branch = 08cb5b0c68c9a051f9155e80ecf4ca9789afc8ac
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 08cb5b0
[INFO] [GitCommitIdMojo] build.commit.id = 08cb5b0c68c9a051f9155e80ecf4ca9789afc8ac
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #567 from dromagnoli/GEOS-6455
GEOS-6455: Updating GeoServerInitStartupListener
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-h2 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-h2 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-h2 >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-h2 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-h2 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-h2 ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.6-SNAPSHOT/gs-h2-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.6-SNAPSHOT/gs-h2-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.6-SNAPSHOT/gs-h2-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.6-SNAPSHOT/gs-h2-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/h2/target/gs-h2-2.6-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.6-SNAPSHOT/gs-h2-2.6-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.587s]
[INFO] Core Platform Module .............................. SUCCESS [13.376s]
[INFO] Open Web Service Module ........................... SUCCESS [16.055s]
[INFO] Main Module ....................................... SUCCESS [3:03.302s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.248s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.370s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [42.056s]
[INFO] Web Coverage Service Module ....................... SUCCESS [8.451s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.457s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.711s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [5:20.134s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [1:08.094s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.422s]
[INFO] Core UI Module .................................... SUCCESS [2:44.294s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.257s]
[INFO] Community Space ................................... SUCCESS [0.186s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.507s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.171s]
[INFO] Printing Module ................................... FAILURE [53.464s]
[INFO] Application Schema Support ........................ SUCCESS [0.247s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.027s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.362s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.360s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.731s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.395s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.504s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.958s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.511s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [4.456s]
[INFO] Chart external graphics support ................... SUCCESS [1.565s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.036s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.861s]
[INFO] OWS request flow controller ....................... SUCCESS [26.871s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.254s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.208s]
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.295s]
[INFO] DXF output format ................................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.224s]
[INFO] Total time: 11:49.731s (Wall Clock)
[INFO] Finished at: Fri Apr 18 10:16:35 UTC 2014
[INFO] Final Memory: 49M/291M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-printing: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/printing/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-printing
See <http://ares.opengeo.org/jenkins/job/geoserver-master/442/changes&gt;
