See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4508/>
[...truncated 105106 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.408 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Apr 09, 2017 2:46:55 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Apr 09, 2017 2:46:55 AM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Seven', enabled
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.392 sec
Results :
Failed tests: testAsyncExecutionLimit(org.geoserver.wps.InputLimitsTest): Expecting to find matches for Xpath //ows:ExceptionText[contains(., 'maxExecutionTime 2 seconds, maxTotalTime 3 seconds')]
Tests run: 247, Failures: 1, Errors: 0, Skipped: 2
[INFO]
[INFO]
[INFO] Skipping OGR WPS
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO] Skipping Web Processing Service GUI
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 17.195 s]
[INFO] Core Platform Module ............................... SUCCESS [ 17.755 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.923 s]
[INFO] Main Module ........................................ SUCCESS [02:29 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.090 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.669 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [05:02 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.771 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.843 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.548 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.183 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. FAILURE [02:36 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 16.796 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 2.429 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.055 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.279 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 12.995 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.104 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 15.185 s]
[INFO] Community Space .................................... SUCCESS [ 0.056 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.305 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.392 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.133 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.450 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.295 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.710 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.353 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.292 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.961 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.061 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:34 min]
[INFO] Excel Output Format ................................ SUCCESS [ 16.565 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.488 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.078 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.515 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.372 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.310 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.162 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.102 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.065 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.350 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.386 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 45.810 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.508 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.020 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 16.477 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.020 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.194 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 15.281 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.677 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 13:38 min (Wall Clock)
[INFO] Finished at: 2017-04-09T02:46:56+00:00
[INFO] Final Memory: 116M/630M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
