[Geoserver-devel] Build failed in Jenkins: geoserver-master #47
See <http://ares.opengeo.org/jenkins/job/geoserver-master/47/changes&gt;
Changes:
[andrea.aime] Attempt to fix the build on windows in path with special chars
[...truncated 9283 lines...]
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at org.geoserver.jai.ConcurrentOperationRegistry.invokeFactory(ConcurrentOperationRegistry.java:412)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getMinX(RenderedOp.java:2161)
  at javax.media.jai.PlanarImage.getBounds(PlanarImage.java:702)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:907)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:329)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
  at org.geoserver.kml.KMLMapResponse.encodeAsKmz(KMLMapResponse.java:110)
  at org.geoserver.kml.KMLMapResponse.write(KMLMapResponse.java:62)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
  at org.geoserver.kml.KMLTest.testKMZMixed(KMLTest.java:454)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
  at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
  ... 76 more
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.106 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
Tests run: 20, Failures: 0, Errors: 0, Skipped: 2, Time elapsed: 6.998 sec
Running org.geoserver.kml.KMLWFSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.249 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.493 sec
Running org.geoserver.kml.icons.IconPropertiesTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Running org.geoserver.kml.icons.IconPropertyInjectorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.017 sec
Running org.geoserver.kml.icons.IconRendererTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.092 sec
Running org.geoserver.wps.gs.RangeLookupTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.813 sec
Running org.geoserver.kml.icons.IconServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.209 sec
Results :
Failed tests: testRasterTransformerSLD(org.geoserver.kml.KMLReflectorTest)
Tests run: 105, Failures: 1, Errors: 0, Skipped: 3
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.585 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.727s]
[INFO] Core Platform Module .............................. SUCCESS [4.165s]
[INFO] Open Web Service Module ........................... SUCCESS [12.014s]
[INFO] Main Module ....................................... SUCCESS [2:37.602s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:56.227s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.347s]
[INFO] Web Map Service Module ............................ SUCCESS [4:36.870s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.573s]
[INFO] Core UI Module .................................... SUCCESS [2:05.934s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.294s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:00.936s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:09.732s]
[INFO] KML support for GeoServer ......................... FAILURE [1:15.046s]
[INFO] REST Support Module ............................... SUCCESS [37.525s]
[INFO] WFS UI Module ..................................... SUCCESS [38.910s]
[INFO] Security UI Modules ............................... SUCCESS [0.663s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.366s]
[INFO] Printing Module ................................... SUCCESS [24.178s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.561s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.236s]
[INFO] Application Schema Support ........................ SUCCESS [0.194s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.102s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [28.576s]
[INFO] H2 DataStore Extension ............................ SUCCESS [17.016s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.299s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.922s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.534s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.621s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [5.274s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.688s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [32.608s]
[INFO] Excel Output Format ............................... SUCCESS [38.165s]
[INFO] Validation Module ................................. SUCCESS [2.336s]
[INFO] Chart external graphics support ................... SUCCESS [1.456s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.235s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.807s]
[INFO] OWS request flow controller ....................... SUCCESS [20.596s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.256s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [46.158s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.220s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.299s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [35.447s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.400s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.779s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [22.425s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15:07.653s (Wall Clock)
[INFO] Finished at: Sun Oct 27 13:39:09 UTC 2013
[INFO] Final Memory: 49M/206M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project kml: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/kml/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :kml
See <http://ares.opengeo.org/jenkins/job/geoserver-master/48/changes&gt;
