See <http://ares.opengeo.org/jenkins/job/geoserver-master/478/>
[...truncated 24586 lines...]
[INFO] Building Catalog Services for the Web core module 2.6-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Catalog Services for the Web core module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-csw-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-csw-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-csw-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Removing xerces from the bin package, attempt to fix some cite failures while putting the bit on a diet
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 01.05.2014 @ 19:55:26 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 02-May-2014 21:06
[INFO] [GitCommitIdMojo] build.build.time = 02.05.2014 @ 21:51:22 UTC
[INFO] [GitCommitIdMojo] build.branch = 96c5f083021c97500a6f9fde28a81deeabe2a70f
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 96c5f08
[INFO] [GitCommitIdMojo] build.commit.id = 96c5f083021c97500a6f9fde28a81deeabe2a70f
[INFO] [GitCommitIdMojo] build.commit.message.full = Removing xerces from the bin package, attempt to fix some cite failures while putting the bit on a diet
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-csw-core ---
[INFO] Copying 1 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-csw-core ---
[INFO] Compiling 56 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-csw-core ---
[INFO] Copying 0 resource
[INFO] Copying 23 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-csw-core ---
[INFO] Compiling 23 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/test-classes>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 28.785 sec
Running org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.753 sec
Results :
Failed tests: testFill(org.geoserver.security.web.user.EditUserPageTest): (..)
Tests run: 92, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-csw-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/csw/core/target/surefire-reports>
T E S T S
Running org.geoserver.csw.CSWRecordResponseTest
May 02, 2014 9:51:46 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.122s]
[INFO] Core Platform Module .............................. SUCCESS [22.584s]
[INFO] Open Web Service Module ........................... SUCCESS [31.664s]
[INFO] Main Module ....................................... SUCCESS [4:43.050s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.981s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:32.967s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [52.740s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.162s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:35.673s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:55.205s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [3:01.941s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:58.536s]
[INFO] Web Map Service Module ............................ SUCCESS [7:07.848s]
[INFO] KML support for GeoServer ......................... SUCCESS [2:29.651s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [4:35.450s]
[INFO] REST Support Module ............................... SUCCESS [1:00.528s]
[INFO] REST Configuration Service Module ................. SUCCESS [6:40.009s]
[INFO] GeoServer Web Modules ............................. SUCCESS [2.344s]
[INFO] Core UI Module .................................... SUCCESS [3:06.074s]
[INFO] WMS UI Module ..................................... SUCCESS [2:19.183s]
[INFO] WFS UI Module ..................................... SUCCESS [57.221s]
[INFO] Demoes Module ..................................... SUCCESS [1:57.513s]
[INFO] Security UI Modules ............................... SUCCESS [0.483s]
[INFO] Security UI Core Module ........................... FAILURE [7:47.552s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.593s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.301s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.479s]
[INFO] Printing Module ................................... SUCCESS [51.583s]
[INFO] Application Schema Support ........................ SUCCESS [0.450s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [50.469s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [42.194s]
[INFO] H2 DataStore Extension ............................ SUCCESS [35.342s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.753s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.194s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.957s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.779s]
[INFO] ImageMap Output Format ............................ SUCCESS [33.381s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.918s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [2.168s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [49.746s]
[INFO] Excel Output Format ............................... SUCCESS [57.577s]
[INFO] Validation Module ................................. SUCCESS [5.818s]
[INFO] Chart external graphics support ................... SUCCESS [2.175s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.576s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.316s]
[INFO] OWS request flow controller ....................... SUCCESS [32.010s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.396s]
[INFO] Web Processing Service Module ..................... SUCCESS [8:57.834s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [1:05.993s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.776s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.551s]
[INFO] Core Monitor Extension ............................ SUCCESS [46.305s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:36.281s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [50.100s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.457s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [35.057s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [51.150s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.516s]
[INFO] DXF output format ................................. SUCCESS [51.410s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.618s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [1:28.958s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [1:09.534s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.588s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 45:00.390s (Wall Clock)
[INFO] Finished at: Fri May 02 21:51:47 UTC 2014
[INFO] Final Memory: 66M/347M
May 02, 2014 9:51:48 PM org.geoserver.platform.GeoServerExtensions checkContext
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-sec-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
