[Geoserver-devel] Build failed in Jenkins: geoserver-master #5379
See <https://build.geoserver.org/job/geoserver-master/5379/display/redirect?page=changes&gt;
Changes:
[noreply] Add MBStyle Styling workshop (#2658)
[...truncated 9.04 MB...]
Dec 11, 2017 7:05:16 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1]
Members [1] {
  Member [127.0.0.1]:5012 this
Dec 11, 2017 7:05:16 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Dec 11, 2017 7:05:16 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 15 ms.
Dec 11, 2017 7:05:16 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 10 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.841 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.13-SNAPSHOT/gs-wps-cluster-hazelcast-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.13-SNAPSHOT/gs-wps-cluster-hazelcast-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.13-SNAPSHOT/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.13-SNAPSHOT/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.13-SNAPSHOT/gs-wps-cluster-hazelcast-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Dec 11, 2017 7:05:17 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.257 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.13-SNAPSHOT/gs-web-csw-2.13-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.079 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.952 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.548 s]
[INFO] Main Module ........................................ SUCCESS [ 57.221 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:10 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.386 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.122 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.837 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.860 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 20.033 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.071 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:33 min]
[INFO] Web Map Service Module ............................. FAILURE [01:57 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 15.668 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:13 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 15.912 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.788 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.056 s]
[INFO] Core UI Module ..................................... SUCCESS [01:05 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.130 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.039 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:27 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:00 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.078 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.025 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] Printing Module .................................... SUCCESS [ 11.266 s]
[INFO] Community Space .................................... SUCCESS [ 0.034 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.740 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.502 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.588 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.896 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.373 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.207 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.214 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.104 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.287 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.034 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.740 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.236 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.039 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:04 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.387 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.012 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.474 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.092 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.532 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.392 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 25.943 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.232 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.888 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.035 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.637 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.279 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.875 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.983 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.863 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 34.148 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.326 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.065 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.634 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.830 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.069 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.583 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.411 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.532 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:49 min (Wall Clock)
[INFO] Finished at: 2017-12-11T19:05:20+00:00
[INFO] Final Memory: 129M/1013M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/5380/display/redirect&gt;
[INFO] Building GeoServer Security Extension Web Modules 2.13-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.13-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.13-SNAPSHOT/gs-web-sec-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.13-SNAPSHOT/gs-web-sec-2.13-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Dec 11, 2017 7:18:46 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Dec 11, 2017 7:18:46 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Dec 11, 2017 7:18:46 PM com.hazelcast.initializer
Dec 11, 2017 7:18:46 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 17 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 7 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.92 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.528 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.455 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.035 s]
[INFO] Main Module ........................................ SUCCESS [ 54.996 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.053 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.835 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.851 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.802 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.057 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.268 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 36.388 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:30 min]
[INFO] Web Map Service Module ............................. FAILURE [01:49 min]
[INFO] gs-rest ............................................ SUCCESS [ 15.084 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.160 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.413 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.086 s]
[INFO] Core UI Module ..................................... SUCCESS [01:03 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.163 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:28 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:03 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.132 s]
[INFO] REST UI Module ..................................... SUCCESS [ 9.942 s]
[INFO] Printing Module .................................... SUCCESS [ 11.226 s]
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.468 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.466 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.500 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.887 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.371 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.227 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.199 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.884 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.263 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.035 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.556 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.474 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:07 min]
[INFO] OGR WPS ............................................ SUCCESS [ 7.909 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.834 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.514 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.214 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.531 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.732 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.096 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.768 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.898 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.561 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.021 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.680 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.765 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.033 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.147 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.201 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 30.740 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.744 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.036 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.228 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.037 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.026 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.492 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.937 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.231 s]
[INFO] Total time: 10:34 min (Wall Clock)
[INFO] Finished at: 2017-12-11T19:18:46+00:00
[INFO] Final Memory: 129M/1004M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-master/5381/display/redirect&gt;
